    Sketchup+VrayMax
    70 Posts 20 Posters 16.9k Views 20 Watching
    • holmes1977H
      holmes1977
      Nomer you are the SHADOW KING 😎
      Exaggeration makes a dull story better.
      • stefanqS
        stefanq
        Max it's awesome....and you, of course!
        • N
          nomeradona
          thnaks holmes.. i think i like that name πŸ˜„
          • N
            nomeradona
            @stefanq said:
            :shock:
            funny while learning max, i begin to find something and apply them with vraysu
            http://farm3.static.flickr.com/2582/3788678590_dbf179061e_b.jpg
            http://farm4.static.flickr.com/3569/3787880794_de7906c1dc_b.jpg
            • urgenU
              urgen
              ....πŸ‘ πŸ‘ πŸ‘ β˜€
              --pupil forever...------
                steelers05
                Great work Nomer. I am currently working on a model to render in max, and seeing your images is inspiring me...your making it look it easy. I hope I find the process as easy as you have been saying.
                • N
                  nomeradona
                  thanks urgen...
                  • N
                    nomeradona
                    i should say, with this process, i am now more keen to produce my output in vraymax since my modelling soft is still SU. as again it has 0 parsing time.
                      alex luu
                      these are very fantatis!
                      the lighting is great and meterials are wonderfull!
                      i like them!
                      i am only jealous of your ability
                      πŸ‘ πŸ‘Š
                      Everyone has limit,let try your best to cross this limit!
                      please contact with me when you need help to show your idea!
                      Hope to work with you!
                      archpaint1711@gmail.com
                      skype: alex_luu1711
                      • massimoM
                        massimo Moderator
                        Great images indeed. Only a little question, did you model the wood planks in last two images or is just a texture?
                        • N
                          nomeradona
                          i like them!
                          πŸ‘ πŸ‘Š
                          thanks alex.. now that must be a flattery cause i know your ability...
                          • N
                            nomeradona
                            i used bump texture, but i have to do my own bump.
                            i only higlighted further the groove by painting black. then I applied a suttle gaussian blur to have a softer transition.
                            • massimoM
                              massimo Moderator
                              Ok, thanks and congratulations. πŸ‘
                              • N
                                nomeradona
                                you are welcome massimo..
                                • N
                                  nomeradona
                                  here is a WIP render with a Sketchup Scene model imported directly to Max. the reason i love the workflow between SU and Vray Max could be seen in this WIP. Im SU texturing like this is so efficient. In max i am still having difficulty with UVW unwrapped in order to texture this nicely. therefore by preserving the UVW during import i could preserve 100 PErcent of my texture. and i dont have to use the UVW unwrap. then in Max i could load those high poly trees that i love which su has difficulty to handle.
                                  • N
                                    nomeradona
                                    later i will apply bump, displacement, specular maps for rain puddles and trees.
                                    • N
                                      nomeradona
                                      here is the SU scene
                                      • michaliszissiouM
                                        michaliszissiou
                                        Just great nomer! Great calm compositions (the greek word is "synthesis"), great lighting.
                                        Did you used an pp? I don't see much of it. (lol)
                                        IMO UV mapping is superb if you get used to it. If you want to paint directly to surfaces, then its the only way. Especially in complicated structures.
                                        • N
                                          nomeradona
                                          thanks michael, PP..some has a little bit but some has no even PP.
                                          Painting on surface now with SU7 is possibble also. and you can link SU directly with Photoshop and to see the effect of the texture to the surface. on the other hand you are right that paintign the UNWRAP UV map still one of the best. do you do the same in blender?
                                          • michaliszissiouM
                                            michaliszissiou
                                            The winner in painting the unwrap UVs is (IMO) zbrush.
                                            • 2 / 4
