    Sketchup+VrayMax
    70 Posts 20 Posters 16.4k Views 20 Watching
      silver_shadow
      A W E S O M E dude! love it. You are really talented
      • marked001M Offline
        marked001
        wow... missed this post before.....this is just beautiful! great great great image..
        http://www.revision21vis.com
        instagram: revi21on
        • N Offline
          nomeradona
          thanks buddy.. happy to hear it from you jacques..
          • N Offline
            nomeradona
            thanks mark that you found it.. hehehe.
            • 9 Offline
              9fly
              Very good image and lighting. How long did it take for you to complete this scene. I meant only for render compare with VR4SU
              • N Offline
                nomeradona
                honestly i found vray max much faster than vray for su in terms of render. the rendering of this higher subdivision is about 31 minutes as you can read below the image. and im really tweak this with higher render time of maximising the image sampler subdivision. my minimu material subdivion is 24.. comparing with vraySU i would say that the scene will be around an hour or more. not including the parsing time. with a huge number of polygons. VraySU parsing time will be longer inspite of the fact that texture are applied inside the group or even using the remove CGmaterials ruby.Because of this you will see more and more that i will render using VRAYmax. because i found the trick of exporting my SU model at ease with the workflow explained previously.
                • N Offline
                  nomeradona
                  some more images
                  http://farm3.static.flickr.com/2505/3786819231_510bc06e8b_b.jpg
                  http://farm4.static.flickr.com/3504/3786822255_dd872c69a9_b.jpg
                  http://farm3.static.flickr.com/2550/3787637872_7158214131_b.jpg
                  • N Offline
                    nomeradona
                    my girls bedroom
                    http://farm3.static.flickr.com/2525/3787660584_ccce88b32e_b.jpg
                    • N Offline
                      nomeradona
                      new stuff
                      http://farm3.static.flickr.com/2540/3787882674_e58212c6fb_b.jpg
                      http://farm3.static.flickr.com/2633/3787883816_a16ba083ac_b.jpg
                      http://farm4.static.flickr.com/3591/3787077265_a14a1a315c_b.jpg
                      • N Offline
                        nomeradona
                        last one rerendering old su model, exported to max and finally rendered with VrayMax 1.5
                        http://farm4.static.flickr.com/3576/3787971784_9d6468cf92_b.jpg
                        http://farm4.static.flickr.com/3457/3787160953_10d0ace27c_b.jpg
                        • holmes1977H Offline
                          holmes1977
                          Nomer you are the SHADOW KING 😎
                          Exaggeration makes a dull story better.
                          • stefanqS Offline
                            stefanq
                            Max it's awesome....and you, of course!
                            • N Offline
                              nomeradona
                              thnaks holmes.. i think i like that name πŸ˜„
                              • N Offline
                                nomeradona
                                @stefanq said:
                                :shock:
                                funny while learning max, i begin to find something and apply them with vraysu
                                http://farm3.static.flickr.com/2582/3788678590_dbf179061e_b.jpg
                                http://farm4.static.flickr.com/3569/3787880794_de7906c1dc_b.jpg
                                • urgenU Offline
                                  urgen
                                  ....πŸ‘ πŸ‘ πŸ‘ β˜€
                                  --pupil forever...------
                                    steelers05
                                    Great work Nomer. I am currently working on a model to render in max, and seeing your images is inspiring me...your making it look it easy. I hope I find the process as easy as you have been saying.
                                    • N Offline
                                      nomeradona
                                      thanks urgen...
                                      • N Offline
                                        nomeradona
                                        i should say, with this process, i am now more keen to produce my output in vraymax since my modelling soft is still SU. as again it has 0 parsing time.
                                          alex luu
                                          these are very fantatis!
                                          the lighting is great and meterials are wonderfull!
                                          i like them!
                                          i am only jealous of your ability
                                          πŸ‘ πŸ‘Š
                                          Everyone has limit,let try your best to cross this limit!
                                          please contact with me when you need help to show your idea!
                                          Hope to work with you!
                                          archpaint1711@gmail.com
                                          skype: alex_luu1711
                                          • massimoM Offline
                                            massimo Moderator
                                            Great images indeed. Only a little question, did you model the wood planks in last two images or is just a texture?
                                            • 2 / 4
