    Sketchup+VrayMax
    70 Posts 20 Posters 16.9k Views 20 Watching
    • N
      nomeradona
      @9fly said:
      Very good image and lighting. How long did it take for you to complete this scene. I meant only for render compare with VR4SU
      honestly i found vray max much faster than vray for su in terms of render. the rendering of this higher subdivision is about 31 minutes as you can read below the image. and im really tweak this with higher render time of maximising the image sampler subdivision. my minimu material subdivion is 24.. comparing with vraySU i would say that the scene will be around an hour or more. not including the parsing time. with a huge number of polygons. VraySU parsing time will be longer inspite of the fact that texture are applied inside the group or even using the remove CGmaterials ruby.Because of this you will see more and more that i will render using VRAYmax. because i found the trick of exporting my SU model at ease with the workflow explained previously.
      • N
        nomeradona
        some more images
        http://farm3.static.flickr.com/2505/3786819231_510bc06e8b_b.jpg
        http://farm4.static.flickr.com/3504/3786822255_dd872c69a9_b.jpg
        http://farm3.static.flickr.com/2550/3787637872_7158214131_b.jpg
        • N
          nomeradona
          my girls bedroom
          http://farm3.static.flickr.com/2525/3787660584_ccce88b32e_b.jpg
          • N
            nomeradona
            new stuff
            http://farm3.static.flickr.com/2540/3787882674_e58212c6fb_b.jpg
            http://farm3.static.flickr.com/2633/3787883816_a16ba083ac_b.jpg
            http://farm4.static.flickr.com/3591/3787077265_a14a1a315c_b.jpg
            • N
              nomeradona
              last one rerendering old su model, exported to max and finally rendered with VrayMax 1.5
              http://farm4.static.flickr.com/3576/3787971784_9d6468cf92_b.jpg
              http://farm4.static.flickr.com/3457/3787160953_10d0ace27c_b.jpg
              • holmes1977H
                holmes1977
                Nomer you are the SHADOW KING 😎
                Exaggeration makes a dull story better.
                • stefanqS
                  stefanq
                  Max it's awesome....and you, of course!
                  • N
                    nomeradona
                    thnaks holmes.. i think i like that name πŸ˜„
                    • N
                      nomeradona
                      @stefanq said:
                      :shock:
                      funny while learning max, i begin to find something and apply them with vraysu
                      http://farm3.static.flickr.com/2582/3788678590_dbf179061e_b.jpg
                      http://farm4.static.flickr.com/3569/3787880794_de7906c1dc_b.jpg
                      • urgenU
                        urgen
                        ....πŸ‘ πŸ‘ πŸ‘ β˜€
                        --pupil forever...------
                          steelers05
                          Great work Nomer. I am currently working on a model to render in max, and seeing your images is inspiring me...your making it look it easy. I hope I find the process as easy as you have been saying.
                          • N
                            nomeradona
                            thanks urgen...
                            • N
                              nomeradona
                              i should say, with this process, i am now more keen to produce my output in vraymax since my modelling soft is still SU. as again it has 0 parsing time.
                                alex luu
                                these are very fantatis!
                                the lighting is great and meterials are wonderfull!
                                i like them!
                                i am only jealous of your ability
                                πŸ‘ πŸ‘Š
                                Everyone has limit,let try your best to cross this limit!
                                please contact with me when you need help to show your idea!
                                Hope to work with you!
                                archpaint1711@gmail.com
                                skype: alex_luu1711
                                • massimoM
                                  massimo Moderator
                                  Great images indeed. Only a little question, did you model the wood planks in last two images or is just a texture?
                                  • N
                                    nomeradona
                                    i like them!
                                    πŸ‘ πŸ‘Š
                                    thanks alex.. now that must be a flattery cause i know your ability...
                                    • N
                                      nomeradona
                                      i used bump texture, but i have to do my own bump.
                                      i only higlighted further the groove by painting black. then I applied a suttle gaussian blur to have a softer transition.
                                      • massimoM
                                        massimo Moderator
                                        Ok, thanks and congratulations. πŸ‘
                                        • N
                                          nomeradona
                                          you are welcome massimo..
                                          • N
                                            nomeradona
                                            here is a WIP render with a Sketchup Scene model imported directly to Max. the reason i love the workflow between SU and Vray Max could be seen in this WIP. Im SU texturing like this is so efficient. In max i am still having difficulty with UVW unwrapped in order to texture this nicely. therefore by preserving the UVW during import i could preserve 100 PErcent of my texture. and i dont have to use the UVW unwrap. then in Max i could load those high poly trees that i love which su has difficulty to handle.
                                            • 2 / 4
