    Sketchup+VrayMax
    70 Posts 20 Posters 16.9k Views 20 Watching
      9fly
      Very good image and lighting. How long did it take for you to complete this scene. I meant only for render compare with VR4SU
      • N
        nomeradona
        honestly i found vray max much faster than vray for su in terms of render. the rendering of this higher subdivision is about 31 minutes as you can read below the image. and im really tweak this with higher render time of maximising the image sampler subdivision. my minimu material subdivion is 24.. comparing with vraySU i would say that the scene will be around an hour or more. not including the parsing time. with a huge number of polygons. VraySU parsing time will be longer inspite of the fact that texture are applied inside the group or even using the remove CGmaterials ruby.Because of this you will see more and more that i will render using VRAYmax. because i found the trick of exporting my SU model at ease with the workflow explained previously.
        • N
          nomeradona
          some more images
          http://farm3.static.flickr.com/2505/3786819231_510bc06e8b_b.jpg
          http://farm4.static.flickr.com/3504/3786822255_dd872c69a9_b.jpg
          http://farm3.static.flickr.com/2550/3787637872_7158214131_b.jpg
          • N
            nomeradona
            my girls bedroom
            http://farm3.static.flickr.com/2525/3787660584_ccce88b32e_b.jpg
            • N
              nomeradona
              new stuff
              http://farm3.static.flickr.com/2540/3787882674_e58212c6fb_b.jpg
              http://farm3.static.flickr.com/2633/3787883816_a16ba083ac_b.jpg
              http://farm4.static.flickr.com/3591/3787077265_a14a1a315c_b.jpg
              • N
                nomeradona
                last one rerendering old su model, exported to max and finally rendered with VrayMax 1.5
                http://farm4.static.flickr.com/3576/3787971784_9d6468cf92_b.jpg
                http://farm4.static.flickr.com/3457/3787160953_10d0ace27c_b.jpg
                • holmes1977H
                  holmes1977
                  Nomer you are the SHADOW KING 😎
                  Exaggeration makes a dull story better.
                  • stefanqS
                    stefanq
                    Max it's awesome....and you, of course!
                    • N
                      nomeradona
                      thnaks holmes.. i think i like that name πŸ˜„
                      • N
                        nomeradona
                        @stefanq said:
                        :shock:
                        funny while learning max, i begin to find something and apply them with vraysu
                        http://farm3.static.flickr.com/2582/3788678590_dbf179061e_b.jpg
                        http://farm4.static.flickr.com/3569/3787880794_de7906c1dc_b.jpg
                        • urgenU
                          urgen
                          ....πŸ‘ πŸ‘ πŸ‘ β˜€
                          --pupil forever...------
                            steelers05
                            Great work Nomer. I am currently working on a model to render in max, and seeing your images is inspiring me...your making it look it easy. I hope I find the process as easy as you have been saying.
                            • N
                              nomeradona
                              thanks urgen...
                              • N
                                nomeradona
                                i should say, with this process, i am now more keen to produce my output in vraymax since my modelling soft is still SU. as again it has 0 parsing time.
                                  alex luu
                                  these are very fantatis!
                                  the lighting is great and meterials are wonderfull!
                                  i like them!
                                  i am only jealous of your ability
                                  πŸ‘ πŸ‘Š
                                  Everyone has limit,let try your best to cross this limit!
                                  please contact with me when you need help to show your idea!
                                  Hope to work with you!
                                  archpaint1711@gmail.com
                                  skype: alex_luu1711
                                  • massimoM
                                    massimo Moderator
                                    Great images indeed. Only a little question, did you model the wood planks in last two images or is just a texture?
                                    • N
                                      nomeradona
                                      i like them!
                                      πŸ‘ πŸ‘Š
                                      thanks alex.. now that must be a flattery cause i know your ability...
                                      • N
                                        nomeradona
                                        i used bump texture, but i have to do my own bump.
                                        i only higlighted further the groove by painting black. then I applied a suttle gaussian blur to have a softer transition.
                                        • massimoM
                                          massimo Moderator
                                          Ok, thanks and congratulations. πŸ‘
                                          • N
                                            nomeradona
                                            you are welcome massimo..
                                            • 2 / 4
