    [Plugin] SectionCutFace
    569 Posts 171 Posters 541.1k Views 170 Watching
    • N
      nickdk
      how many sides do you think I'll need? I have attached WIP to give an idea of the shapes involved and the detailing πŸ˜„
      I did a test with 100 sides and the polygons were visible so I guess it does require quite a lot :S
        I don't know. It's kind of dark so it's hard to see.
        Does this look like it is smooth enough?
        http://farm7.staticflickr.com/6223/6318648290_530026a3b2_z.jpg
        That's 50 segments going around the long way.
        • N
          nickdk
          yes it looks perfect:) My problem is that the circular shapes I'm using in my design are differently scaled - some of them are 20meters in diameter so the 'jagged' faces are much more visible.
            That ring is drawn at a bit over 5 meters in diameter but I doubt it would look any different at 20m or 200m.
            • A
              ayik37
              thanks sir,that plugin working very well in my sketchup πŸ‘
              • P
                petroulac
                Thanks!!!
                • I
                  ilaliberte
                  Hello! I've downloaded this pluggin several times and just did again with this version, and it just won't work: I don't get the context menu option at all!
                  My friends at uni are using it on the same version of SketchUp Pro (7.1.6859) without a problem... Here are some screenshots to try to explain. The context menu screenshot is from when I clicked on the section cut plane - there isn' anything missing from that menu, I only cut the screenshot a bit too close.
                  Does it make a difference that I am still on the trial version of V-Ray?
                  many thanks.
                  Best wishes
                  Isabelle
                    Looks like you've got your plugins in the incorrect folder. Plugins for SketchUp should be in Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/Plugins.
                    If I had to guess, I'd say Zorro 2 doesn't work either.
                    • I
                      ilaliberte
                      Thank you so much for this, it works now! How embarrassing - but it's good that it was this easy to solve. Thank you, thank you, thank you!!!
                      (And yes, of course Zorro wasn't working either!)
                      • C
                        chalky
                        I'm sorry but am I the only one having problems..?
                        seems like everytime I run the plugin SU freezes, tried on various projects and simple cube..same thing
                        SU8 Pro Lion 10.7.3 latest version of plugin, any suggestions?
                        • TIGT
                          I know of no issues causing 'freezing'...
                          Open the Ruby Console.
                          Run the tool.
                          Any error messages in the Console or otherwise ?
                          Report back...
                          πŸ˜•
                          • C
                            chalky
                            Tried what you said but no messages in ruby console reported. ❓ ❓
                            • TIGT
                              I see you are on v7 with Lion.
                              I know there were some fixes with v8M2 to address problems with Lion, perhaps that's the issue πŸ˜•
                              So... any Lion users out there [with v7/v8] who are getting error free use from this tool ??
                              I'm also now wondering if you have one of the problem scripts loading that can affect core class/methods ill-advisedly - these include SketchyPhysics, DrivingDimensions, MatchBox and some 'Solar' tool I cant bring to mind... Although some of these are PC only I think... This tool should workaround potential pitfalls made in its legitimate code by these files, but there might still be a trip-up somewhere. If you have any of these other scripts try to disable them and restart [move the .rb/.rbs files out of the Plugins folder temporarily].
                              Does this do anything better ?
                              • C
                                chalky
                                Sorry wrong info in profile i'm running v8
                                double checked if had those plugs and I don't
                                • TIGT
                                  Do you have the latest v8 = v8M2 ?
                                  This specifically addressed some issues with Lion...
                                  • C
                                    chalky
                                    problem solved πŸ˜„
                                    • TIGT
                                      @chalky said:
                                      problem solved πŸ˜„
                                      How? WE would like to know πŸ˜•
                                      • A
                                        artsnot
                                        I am new to this forum and seem to be experiencing a Sketchup crash every time I try to use section cut face. I am using Sketchup Pro 8 on a MacBook Pro i7 2.0 GHz with 8 MB RAM. I am not sure what the problem is. Has anyone else experience this?
                                        • TIGT
                                          What MAC OS are you using ?
                                          OSX ?
                                          • bmikeB
                                            bmike
                                            Running fine on mine:
                                            mike beganyi design + consulting llc
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 28
                                            • 29
                                            • 7 / 29
