    [Plugin] SectionCutFace
    569 Posts 171 Posters 478.2k Views 170 Watching
      That ring is drawn at a bit over 5 meters in diameter but I doubt it would look any different at 20m or 200m.
        ayik37
        thanks sir,that plugin working very well in my sketchup πŸ‘
          petroulac
          Thanks!!!
          • I Offline
            ilaliberte
            Hello! I've downloaded this pluggin several times and just did again with this version, and it just won't work: I don't get the context menu option at all!
            My friends at uni are using it on the same version of SketchUp Pro (7.1.6859) without a problem... Here are some screenshots to try to explain. The context menu screenshot is from when I clicked on the section cut plane - there isn' anything missing from that menu, I only cut the screenshot a bit too close.
            Does it make a difference that I am still on the trial version of V-Ray?
            many thanks.
            Best wishes
            Isabelle
              Looks like you've got your plugins in the incorrect folder. Plugins for SketchUp should be in Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/Plugins.
              If I had to guess, I'd say Zorro 2 doesn't work either.
              • I Offline
                ilaliberte
                Thank you so much for this, it works now! How embarrassing - but it's good that it was this easy to solve. Thank you, thank you, thank you!!!
                (And yes, of course Zorro wasn't working either!)
                  chalky
                  I'm sorry but am I the only one having problems..?
                  seems like everytime I run the plugin SU freezes, tried on various projects and simple cube..same thing
                  SU8 Pro Lion 10.7.3 latest version of plugin, any suggestions?
                    I know of no issues causing 'freezing'...
                    Open the Ruby Console.
                    Run the tool.
                    Any error messages in the Console or otherwise ?
                    Report back...
                    πŸ˜•
                      chalky
                      Tried what you said but no messages in ruby console reported. ❓ ❓
                        I see you are on v7 with Lion.
                        I know there were some fixes with v8M2 to address problems with Lion, perhaps that's the issue πŸ˜•
                        So... any Lion users out there [with v7/v8] who are getting error free use from this tool ??
                        I'm also now wondering if you have one of the problem scripts loading that can affect core class/methods ill-advisedly - these include SketchyPhysics, DrivingDimensions, MatchBox and some 'Solar' tool I cant bring to mind... Although some of these are PC only I think... This tool should workaround potential pitfalls made in its legitimate code by these files, but there might still be a trip-up somewhere. If you have any of these other scripts try to disable them and restart [move the .rb/.rbs files out of the Plugins folder temporarily].
                        Does this do anything better ?
                          chalky
                          Sorry wrong info in profile i'm running v8
                          double checked if had those plugs and I don't
                            Do you have the latest v8 = v8M2 ?
                            This specifically addressed some issues with Lion...
                              chalky
                              problem solved πŸ˜„
                                @chalky said:
                                problem solved πŸ˜„
                                How? WE would like to know πŸ˜•
                                  artsnot
                                  I am new to this forum and seem to be experiencing a Sketchup crash every time I try to use section cut face. I am using Sketchup Pro 8 on a MacBook Pro i7 2.0 GHz with 8 MB RAM. I am not sure what the problem is. Has anyone else experience this?
                                    What MAC OS are you using ?
                                    OSX ?
                                    • bmikeB Offline
                                      bmike
                                      Running fine on mine:
                                        artsnot
                                        I am running Snow Leopard 10.6.8.
                                          SUFractal has reported a clash/crash with SectionCutFace [and some other scripts] if BIMtools is installed - we suspect that new tool might be inadvertently messing with native class/methods used correctly by other scripts, OR it has faulty observers that are messing with things like group creation...
                                          Do any of you experiencing problems have BIMtools installed ?
                                          If so, try disabling it and retry/report back...
                                            artsnot
                                            How does one do that? Sorry, I am totally new and have no idea what that means. I appreciate your help.
                                            • 28
                                            • 29
                                            • 7 / 29
