    [Plugin] SectionCutFace
    569 Posts 171 Posters 445.9k Views 170 Watching
    • N Offline
      nickdk
      Thank you for this great tool!! πŸ˜„
      Sometimes when I use it it's very slow, it can take 10mins on a large model, is there any tips on speeding things up?
      I have a current model with many round shapes and circles with 500 sides and so on, it takes forever.
      I'm not trying to sound non-thankful, I just wondering if I can do something to make it go faster πŸ˜„
        I think the answer is in your question. Circles with 500 sides? Whatever for? Surely you don't need that many.
        • N Offline
          nickdk
          Hehe πŸ˜„ yeah 500 sides might be a lot, the reason for the many sides is that I just recently found out how to make smooth circles in SU and I didn't really think to much about the amount of sides I entered when model ling, I assumed that it would take a lot of sides to get a really smooth result? I need to import the SU model in 3Ds max when it's done and I wanted all circular shapes to be perfect. It might be overkill though, it is making my life hard with this complex geometry that's for sure! πŸ˜•
          thank you for the insight!
            It's surely overkill and you've kind of shot yourself in the foot, metaphorically speaking. You can get smooth curves with far fewer sides and increase performance.
            • N Offline
              nickdk
              how many sides do you think I'll need? I have attached WIP to give an idea of the shapes involved and the detailing πŸ˜„
              I did a test with 100 sides and the polygons were visible so I guess it does require quite a lot :S
                I don't know. It's kind of dark so it's hard to see.
                Does this look like it is smooth enough?
                http://farm7.staticflickr.com/6223/6318648290_530026a3b2_z.jpg
                That's 50 segments going around the long way.
                • N Offline
                  nickdk
                  yes it looks perfect:) My problem is that the circular shapes I'm using in my design are differently scaled - some of them are 20meters in diameter so the 'jagged' faces are much more visible.
                    That ring is drawn at a bit over 5 meters in diameter but I doubt it would look any different at 20m or 200m.
                      ayik37
                      thanks sir,that plugin working very well in my sketchup πŸ‘
                        petroulac
                        Thanks!!!
                        • I Offline
                          ilaliberte
                          Hello! I've downloaded this pluggin several times and just did again with this version, and it just won't work: I don't get the context menu option at all!
                          My friends at uni are using it on the same version of SketchUp Pro (7.1.6859) without a problem... Here are some screenshots to try to explain. The context menu screenshot is from when I clicked on the section cut plane - there isn' anything missing from that menu, I only cut the screenshot a bit too close.
                          Does it make a difference that I am still on the trial version of V-Ray?
                          many thanks.
                          Best wishes
                          Isabelle
                            Looks like you've got your plugins in the incorrect folder. Plugins for SketchUp should be in Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/Plugins.
                            If I had to guess, I'd say Zorro 2 doesn't work either.
                            • I Offline
                              ilaliberte
                              Thank you so much for this, it works now! How embarrassing - but it's good that it was this easy to solve. Thank you, thank you, thank you!!!
                              (And yes, of course Zorro wasn't working either!)
                                chalky
                                I'm sorry but am I the only one having problems..?
                                seems like everytime I run the plugin SU freezes, tried on various projects and simple cube..same thing
                                SU8 Pro Lion 10.7.3 latest version of plugin, any suggestions?
                                  I know of no issues causing 'freezing'...
                                  Open the Ruby Console.
                                  Run the tool.
                                  Any error messages in the Console or otherwise ?
                                  Report back...
                                  πŸ˜•
                                    chalky
                                    Tried what you said but no messages in ruby console reported. ❓ ❓
                                      I see you are on v7 with Lion.
                                      I know there were some fixes with v8M2 to address problems with Lion, perhaps that's the issue πŸ˜•
                                      So... any Lion users out there [with v7/v8] who are getting error free use from this tool ??
                                      I'm also now wondering if you have one of the problem scripts loading that can affect core class/methods ill-advisedly - these include SketchyPhysics, DrivingDimensions, MatchBox and some 'Solar' tool I cant bring to mind... Although some of these are PC only I think... This tool should workaround potential pitfalls made in its legitimate code by these files, but there might still be a trip-up somewhere. If you have any of these other scripts try to disable them and restart [move the .rb/.rbs files out of the Plugins folder temporarily].
                                      Does this do anything better ?
                                        chalky
                                        Sorry wrong info in profile i'm running v8
                                        double checked if had those plugs and I don't
                                          Do you have the latest v8 = v8M2 ?
                                          This specifically addressed some issues with Lion...
                                            chalky
                                            problem solved πŸ˜„
                                            • 28
                                            • 29
                                            • 7 / 29
