    Particle FX preview
    46 Posts 12 Posters 5.5k Views 12 Watching
    • W Offline
      Wacov
      This is a new particle effects system I'm developing. I'm going to be mean, and not post the model, but I assure you all these pics are from a real-time simulation, running happily at around 40FPS. Enjoy!
        chango70
        LOL how cool is that! Can't wait!
          JaViXP
          Wow! Looks awesome, can't wait! 🎉
          "Giving up is way harder than trying"
          JaViXP's Rendering
            BTM
            nice idea 👍
            • P Offline
              phy
              Good going wacov. svn?
              Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
              • P Offline
                Physicsguy1
                That looks nice 😄. Now we need sparks and such for metal grinding, and some other characteristics.
                • P Offline
                  phy
                  You want to know whats best, it hardly slows the simulation at all since it's not using the physics engine.
                  • P Offline
                    Physicsguy1
                    I cant wait! Are those bubbles in the water actual moving bubbles, or are they just random, and appear for a jiffy and depart without movement?
                    • W Offline
                      Wacov
                      Glad to see it's popular 😄 ... all the particles move, scale, and fade out. They can be given starting velocity, which will deminish after a few frames, and have some random values attached to keep it all interesting. @Physicsguy, the bubbles are created randomly, but they still move towards the surface.
                      This should all be added into SP in the near future, with a different method system. Until then, here's the demo for you all to try out (Feedback on performance would be great)
                      particle FX demo.skp
                      • W Offline
                        Wacov
                        Okay, just heard about a very slow simulation. Before you run the sim, please open the ruby console (Window/Ruby Console). Play the sim for a bit, reset, and post the last number in the array (after "Fps"). If you can run a normal sim ok, it should be at least 20. Thanks!
                        • P Offline
                          phy
                          Great 👍
                          • P Offline
                            phy
                            I got this
                            Inspecting model for errors
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5da3d08>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5d90b38>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5d847c0>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5d78370>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5d6c3d0>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5d60418>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5d59e30>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5d547f0>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x58268a8>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5769a28>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5fb2730>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5fad078>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5fa79a8>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5f8c870>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5f72c38>
                            #<MSketchyPhysics3;;SP3xBodyContext;0x5f64070>
                            initializing joint controllers
                            ["Time", 2.875, "Frames", 82, "Fps", 28.5217391304348]
                            • W Offline
                              Wacov
                              28 FPS is fine... keep 'em coming guys!
                                JaViXP
                                Here is mine.
                                ["Time", 7.551, "Frames", 72, "Fps", 9.53516090584029]
                                But... Why only 9.5!? 😢
                                JaViXP's Rendering
                                • P Offline
                                  phy
                                  Maybe it's vista, what's the specs on your computer Javi?
                                    JaViXP
                                    I don't think it is Vista (Wacov uses Vista as well). Anyway, here we go:
                                    Pentium Dual-Core CPU E5300 @ 2.6 GHz
                                    2GB RAM
                                    ATI Radeon HD 4850
                                    JaViXP's Rendering
                                    • P Offline
                                      phy
                                      2GB RAM
                                      ATI Radeon HD 4850
                                      Yeah but Wacov has a gaming computer. But then with the specs you have it shouldn't be slowing down that much cause I only have 512 MB ram.
                                        JaViXP
                                        Mine is a gaming computer too, (I can run TS3, max quality, no lag). It is 5.2 / 5.9 in Vista's Perfomance Test. It might be SketchUp.
                                        JaViXP's Rendering
                                        • P Offline
                                          phy
                                          I see, I guess I was just going by how much ram you had.
                                          • Roguer1R Offline
                                            Roguer1
                                            Great showcase Wacov!
                                            I am running:
                                            1.86GHz Intel
                                            2GB Ram
                                            358MB Mobile Intel 965 Express Chipset
                                            I get anywhere from 20 - 30FPS with no problem 😄
                                            Find all my models on the 3D Warehouse
                                            • 1 / 3
