    [Plugin][$] RoundCorner - v3.4a - 31 Mar 24
    1.5k Posts 476 Posters 3.9m Views 476 Watching
    • BoxB Offline
      Do you mean like this?
      Round corner will often fill in faces and you just need to remove them.
      • N Offline
        numerobis
        @numerobis said:
        The edges are showing up correctly (hard edges) but the shading is messed up in display and rendering.
        I have to use the smoothing controls after the beveling and set it to hard egdes again to get this fixed.
        Any chance to get this fixed? Here is an example how it looks like in SU. Just like smoothing >45° + hard edges.
        The left cube is the direct result of the beveling. The right one is the same model with corrected normals (0°).
        https://abload.de/img/chamfer017fu3y.png
        (The lighting is the same)
          cowboyathome
          Fredo, is this an unavoidable side effect which can't be fixed?
          • K Offline
            keyudits
            yes! didnt think to try that. I appreciate the speedy response.
            • W Offline
              whitelock
              Hi any ideas what combination of edge filters i need on round corner in order to just see the border lines. look at the image. On the left is how I would like to see it on the right is the best I can get and I end up having to do loads of clean up. any help greatly appreciated
              • BoxB Offline
                Could you attach that model so we can look at it, as I can't replicate your problem.
                • deaneauD Offline
                  deaneau
                  @whitelock
                  Try to select your lines and then use hide (from context-menu)
                  MADE, BORN AND LIVING IN BERLIN
                  Big Thank You to all Programmers
                  Some German words are so long that they have a perspective. M.Twain
                  • fredo6F Offline
                    fredo6
                    NEW RELEASE: RoundCorner v3.1b - 04 Sep 16
                    RoundCorner 3.1b is a maintenance release. It fixes a bug preventing to make a sphere and a dome from a cube, as shown in the video below.
                    See main post of this thread for Download.
                    Fredo
                    • pep75P Offline
                      pep75
                      Great Fredo!!! Thanks!
                      • sicksickisckS Offline
                        sicksickisck
                        hmm 3.1b so You mean there are no overlaps problem now ?!
                        • fredo6F Offline
                          fredo6
                          Actually overlaps are just detected and signaled (since v3.0). But you need to sort out the issue in the model (reducing the offset or modifying the model).
                          Fredo
                            Thanks for the updates Fredo. You do marvelous work.
                              sicksickisck
                              yep; thanks for the plugin anyway;
                                Ben Ritter
                                Thank you Fredo!
                                  LucasBarbos4
                                  Wow. Thanks for this Fredo.
                                  • P Offline
                                    pedrinalex
                                    Many Thanks Freddo ¡¡¡
                                    MB ASUS x99M-WS, Xeon e5 2695 v3, 64 GB RAM 2400, 2x gforce gtx 1060, 1 SSDH 1 tb & 3 HD 1 TB c/u
                                      rolopolo
                                      roundcorner will not work! i cant get the palette to load.
                                      i have installed roundcorner via the extension store.
                                      all other fredo tools are working correctly
                                      libfredo6 is all up to date
                                      the footprint is correct - see upload attach
                                      win10 sketchup2016pro
                                      I cant think what to try next after reinstalling multiple times
                                      Can anybody help?
                                      thanks
                                      • N Offline
                                        namelessone
                                        Hey fredo,
                                        I'm having difficulties with getting round corners correct on some edges of my model. To make things simpler, I can provide screenshots of selected problematic edges and .skp file of model part I'm working on. Is it just limitation or perhaps plugin is confused?
                                        http://tonic-art.com/round1.jpg
                                        http://tonic-art.com/round2.jpg
                                        http://tonic-art.com/round.skp
                                        • gillesG Offline
                                          gilles
                                          First thing, SU does not manage too small faces; so make your part a component, create a copy, scale up the copy X1000, work on the copy.
                                            Can anybody help?
                                            thanks
                                            According to your screenshot you have round Corner disabled by the addition of ! to the file extension. Try changing it to just .rb
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 74
                                            • 75
                                            • 56 / 75
