    [Plugin][$] RoundCorner - v3.4a - 31 Mar 24
    1.5k Posts 477 Posters 4.1m Views 477 Watching
      @Olivér
      Why have you not installed that Lib?
      The correct for v2013 is Lib 5.0c or newer, like it says on the download page... [5.1c IS newer!]...
      http://sketchucation.com/forums/viewtopic.php?p=171721#p171721
      The updated tool needs a newer Lib to work properly in v2013 !
      Please reread the instructions carefully... 😕
      • fredo6F Offline
        fredo6
        @maxioli said:
        I have run into a problem.
        I use SketchUp Make 13.0 and after installing both "LIBFREDO6.37" and "RoundCorner 2.4"
        I have the following error message:
        "Module RoundCorner requires Sketchup version grater than 5.0.160.
        Current version is 13.0.4812"
        I could not figure out what could be the problem.
        Please help!
        Thanks in advance!
        Olivér
        You need to install LibFredo6 5.1. See this post.
        Fredo
          rayc
          Hi Fredo---
          My screen definition is 1440 x 900.
          • fredo6F Offline
            fredo6
            NEW RELEASE: RoundCorner v2.5a - 30 Aug 13
            RoundCorner 2.5 is a major technical release implementing the new naming conventionsintroduced by LibFredo6 5.2.
            RoundCorner footprint will now be based on one file and one subfolder, as shown in the footprint below:
            There is no functional changes in RoundCorner 2.5. However, this new version circumvents some problems of security restrictions that were often met with version 2.3.
            See main post of this thread for Download.
            Fredo
            • W Offline
              wgallo
              I've been trying for over three week now to get round corner to work. I wasnt going to write to the post, but I surrender!!! I need this. Really need it. I am attaching some jepgs of my plugin folder, round corner folder and libfreddo so any soul can look at it and i know it is a mess, but this is the result of several attempts following instructions to the letter from sketchup site, from here, etc.
              Please someone can take a look at those?? ive already fixed the permission of windows. The plugin icons are available in the toolbar, but they do "nothing at all". Windows 7.
              • W Offline
                wgallo
                Please someone look into those folders and tell me what I can do to fix it. Windows 7. Ive already worked on permissions for the plugin folder. I need this to work. Bad.
                Thank you soooo much for any good soul.
                • fredo6F Offline
                  fredo6
                  @Wgallo,
                  You have a wrong installation.
                  You have exploded all RoundCorner files in the SU PLugin directories. You should read the post.
                  Please reconsider a full installation, with the installing the SCF PluginStore as the first step and then installing all scripts (latest versions) via the Plugin Store.
                  Also, make sure you install the latest version of AdditionalPluginFolders (v3.1).
                  Fredo
                    Looks to me as if LibFredo6 got the same exploding treatment, too.
                    I think the easiest first step to fixing this would be to delete the Plugins folder entirely. Then reinstall/repair SketchUp and start over beginning with correctly installing the SCF Plugin Store.
                      You need to do a big tidy up.
                      Remove all of the files currently in the Plugins folder that should have been left inside subfolders.
                      Then reinstall those plugins again - from scratch.
                      I see you have already got the SketchUcation toolset.
                      Why oh why, have you not been using that to AutoInstall your plugins from within SketchUp itself ?
                      Doing a manual installation wrongly is the quick route to a broken SketchUp, especially if you can't find, read and follow simple instructions and the accumulated wisdom of SCF [this has been discussed endlessly over the years], and of course that's why the relatively foolproof AutoInstallers were invented - especially for people like you 😉
                      • W Offline
                        wgallo
                        I know guys, I know...I started manually, then got the installer, and thats when things went nuts...I will work it all over again...thx for all!!!!! Thank you sooo much!!!
                          celinehayman
                          I am trying to install round corners on my SU8 on Mac OSX 10.8.4.
                          I have installed:
                          • Fredo6_RoundCorner.rb
                          • Fredo6_!LibFredo6.rb
                          They are both clicked in my preferences but it is still not loading in my plugins.
                          Any help welcome! thanks
                          • fredo6F Offline
                            fredo6
                            Celine
                            Do you see the menus
                            • in Windows for LibFredo6
                            • In Tools > Fredo6 Collection for RoundCorner
                            If so, open the Ruby console before launching a command.
                            Otherwise, you may have a faulty installation.
                            I really recommend you take time to install the SCF Plugin Store tool, and then install my plugins with this tool.
                            Fredo
                            • LanaL Offline
                              Lana
                              Very, very, very thanks. I love yours plugins.
                                Sébastien
                                Hello,
                                I work under mac, I have the sketchup 8, the libfredo 5.2, I installed(settled) round to fold 2.5 in its skecthup / Plugin location, I restarted Skecthup but Round hook does not appear in my toolbar... What is that somebody can help me.
                                Thank you very much
                                  Have you activated its Extension and then its Toolbar ?
                                  • Y Offline
                                    Yoghurt
                                    Hi Everyone, hi Fredo.
                                    First of all, thanks for the hard work Fredo, you are great! Much of what, to me, makes the SketchUp experience are things that would not be possible without your work. Keep it up!
                                    I have run into a problem with RoundCorner. I have used the plugin before, but since I clean installed Windows 8 on my Computer, it won't work properly anymore. I use SketchUp 13 and I installed LibFredo and RoundCorner over the SketchUcation Plugin Store Extension.
                                    My Problem is that everything is "Invalid" when trying to select edges or faces. When hovering over faces, the cursor simply states "Invalid", but when hovering over an edge it specificaly states "Invalid (Property filter)" (what does that even mean?). I am trying to edit a simple 200cm x 90cm x 14cm box inside a component (while editing the component), which should't be a problem shapewise, since it is pretty much the simplest shape one could edit.
                                    Strangely this problem only occurs when selecting the "Round corners" option. "Sharp corners" and "Bevel edges and corners" work just fine.
                                    Thanks in advance.
                                    Yoghurt
                                    • fredo6F Offline
                                      fredo6
                                      RoundCorner does not work across component or group boundaries. So it should say 'Invalid (Group or Component). Also, make sure you select the proper edge property (plain, smooth, soft, hidden) to match your selected edges (otherwise it says Invalid (Edge properties).
                                      Finally, if you have edges with more than 2 connected faces, it will also say Invalid.
                                      I don't have Windows 8 and I don't think this is related. Possibly you may want to post a model where you encounter the problem so that I have a look.
                                      Fredo
                                      • Y Offline
                                        Yoghurt
                                        Fredo
                                        Thanks, I solved the problem!
                                        I was within the editing mode of the component while using RoundCorner, so that was not the problem. It was a simple box, so the number of faces per edge was no concern either.
                                        The problem was indeed the edge property, I switched that and then it worked perfectly. Thanks a lot for the quick reply 😄.
                                        • F Offline
                                          fmoyer
                                          I'm new to plugins and to Sketchup. And I gather you have created these plugins for free. So I hate to sound ungrateful. But your documentation is really unclear.
                                            What part of it is unclear to you? It doesn't seem right to criticize the author's work without being clear yourself.
                                            There are plenty of folks here, myself included, who would be happy to help you out.
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 74
                                            • 75
                                            • 40 / 75
