    [Plugin][$] RoundCorner - v3.4a - 31 Mar 24
    1.5k Posts 477 Posters 4.3m Views 477 Watching
      I was just telling you what a number of people have found to be the cause of plugins not working. Vray has been causing problems for a lot of users with more than just the Round Corners plugin.
      • ShyamscoolS
        Shyamscool
        ... earlier on another system, vray1.6+ su8+win7 gave bugsplat. Is SU7 the only stable place to run vray 1.6 for now??
        well you suggested to disable vray and i accidentally uninstalled it.... however even that didnt work...
        😞 its actually depressing
        • ShyamscoolS
          Shyamscool
          but hey! i uninstalled vray and RC still didnt work...
          rc Su13 vray 1.6 win7 issue
          • fredo6F
            fredo6
            The cause of the crash between Vray 1.6 Beta and RoundCorner has been identified. So I guess there will be an update of Vray 1.6 anytime soon.
            There are other reasons for problems with RoundCorner
            1. Wrong installation or missing LibFredo6
            2. The Plugins directory is not in full Write access mode. The Access rights are needed due to a remaining trace and the implicit savings of parameters.
            In all cases, epening the Ruby console before launching RC may show the kind of problems and thus guide toward a solution.
            Fredo
            • ShyamscoolS
              Shyamscool
              Sweet! now i need to learn how to launch ruby control...hello google
              sometimes i wish this was the matrix and I could just download all info in my head.
                Not Ruby "Control". Try Window>Ruby CONSOLE
                • ShyamscoolS
                  Shyamscool
                  yes yes yes! fixed it!
                  first one was
                  Error: #<Errno::EACCES: Permission denied - C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Fredo6Trace.txt>
                  C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LIBFREDO6_Dir_49/Lib6Core_49.rb:713:in
                  so u have to go n give permission to every file? I thought giving permission to the main plugin folder solved it all.. any way, now back to installing vray 1.6. hope it works.. if not i have to disable it in the extensions menu every time I model, right?
                    So you didn't set full permissions to .../SketchUp 2013/Plugins until now and now it works?
                    • ShyamscoolS
                      Shyamscool
                      i did that for the SketchUp 2013 plugins folder but not the individual extension folders and files inside it..
                      • TIGT
                        When you give FULL security permissions to the Plugins folder for all who are listed then these changes should ripple down to all contained subfolders and files...
                        How are you setting these permissions ?
                          Your Windows installation must be different. I didn't have to do that with any folders installed inside Plugins.
                          • N
                            naginarch
                            Thanks alot . Its very usefull plugins
                            • ShyamscoolS
                              Shyamscool
                              hmmm yeah maybe stuff is always the difficult way for me 😞..booo
                              any way.. installed vray 1.6 again, as soon as i click on the green click, BUGSPLAT!
                              guess we just have to wait for the next release of 1.6
                                No surprises there.
                                • ShyamscoolS
                                  Shyamscool
                                  the usual.. right click, properties, security, admin/ users way... isnt that right?
                                  • TIGT
                                    Yes... BUT did you give FULL permissions in turn to everyone on the list ?
                                    • fredo6F
                                      fredo6
                                      NEW RELEASE: RoundCorner v2.4c - 06 Jul 13
                                      RoundCorner 2.4 is a major technical release implementing the new naming conventionsintroduced by LibFredo6 5.0.
                                      RoundCorner footprint will now be based on one file and one subfolder, as shown in the footprint below:
                                      There is no functional changes in RoundCorner 2.4. However, this new version because circumvents some problems of security restrictions that were often met with version 2.3.
                                      See main post of this thread for Download.
                                      Fredo
                                      • fredo6F
                                        fredo6
                                        @juanv.soler said:
                                        fredo6
                                        thanks for your work
                                        Did it work OK for you?
                                        Fredo
                                        • J
                                          JuanV.Soler
                                          Fredo
                                          • J
                                            JuanV.Soler
                                            yes 👍
                                            its working OK with the new release located as you told
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 74
                                            • 75
                                            • 38 / 75
