    [Plugin][$] RoundCorner - v3.4a - 31 Mar 24
    1.5k Posts 476 Posters 3.9m Views 476 Watching
      chromecatz
      Ok, so I have to wait for the next release?
      I am sorry but I am not using Windows anymore -)
      I was used to work with sketchup 7 and the round corner plugin without any problems.
      I have download and install curviloft, it works really fine and quick.
      I have retry roundcorner, still having the same problem.
      thanks fredo
      Then, it would be helpful if other Mac users could tell if they have similar performance issues.
      Fredo
      Hi Fredo,
      I would really love to use your plugin, but am having similar problems involving the round corner plugin being very slow to load, selecting edges/faces, executing and using the RC interface. When I open the RC tool palette, SU and the entire computer slows considerably. The cursor freezes and I am unable to select out of the SU program and I am unable to use the cursor to select options in the RC or SU tool palette. This occurs regardless of how complex the geometry is i.e. box, or multifaceted solid. Permissions are set to read & write in the plugins folder on the Mac HD. I've browsed this thread, but don't know if this issue has been resolved yet. Thanks for your help.
      DETAILS:
      Mac OS 10.6.4, Intel Core i7
      Round Corner 2.2c and LibFredo6 loaded in plugins folder
      Best.
      • fredo6F Offline
        fredo6
        Chromecatz,
        No progress so far, because I cannot reproduce the problem.
        Could you drop the two attached files into the ROUNDCORNER_Dir_22 folder, then, after restarting Sketchup, exercise one the laynch of the plugin, the selection of edges and the generation of geometry.
        RoundCorner_Tool.rb
        RoundCorner_Algo.rb
        Also, could you have the Ruby console open during this process, just in case you would see a message.
        There is a trace file generated, FredoTraceRoundCorner.txt in the SU Plugin directory. Could you post it back or send it by PM.
        Thanks very much.
        Fredo
          deanlegg
          Hi Fredo
          I just downloaded this but i didnt get LIBFREDO_Dir_36 or Libfredo6.rb
          Have I missed something
          • TIGT Online
            @deanlegg said:
            Hi Fredo
            Re-read the first post from whence you downloaded the main tool... It tells you that the you need to download the Lib AND has a link to get it...Capture.PNG
              deanlegg
              😳 Doh!!
              Thanks Tig
                Tikva2
                Hi, i have a problem, and i really don`t know what to do...
                http://s009.radikal.ru/i308/1103/87/efabcbbcf61d.jpg
                  axiaosnail
                  wonderful!It improves my efficiency.Thanks!
                  • fredo6F Offline
                    fredo6
                    Tikva2,
                    Could you post the model.
                    It looks like you have an extra edge on the face.
                    fredo
                      Tikva2
                      Fredo, do you mean this?sorry, i dont speak english quite well))
                      http://i017.radikal.ru/1103/f6/0da6ec16c106.jpg
                      http://i065.radikal.ru/1103/92/56978e7d3afb.jpg
                      beforehand thank you.
                      • fredo6F Offline
                        fredo6
                        I was just asking if you could post the SKP file of your model so that I have a closer look.
                        Fredo
                          Tikva2
                          Ok
                          http://depositfiles.com/files/au8d700qi
                          • ArchiblogA Offline
                            Archiblog
                            Thank you for this very useful plugin.
                            • fredo6F Offline
                              fredo6
                              @tikva2 said:
                              Ok
                              I cannot download the file.
                              Could you attach it to your answer (via upload attachment)
                              Thanks very much
                              Fredo
                                Tikva2
                                @tikva2 said:
                                Ok
                                Thanks very much
                                Fredo
                                Here it is)
                                thanks a lot
                                123.skp
                                • fredo6F Offline
                                  fredo6
                                  Tikva,
                                  I had a look at the model and now understand what happens.
                                  The offset border (in green) on the large face must cross an edge which is contiguous to the main edge (in red) at its extremity in order to be prolonged.
                                  This is the case if the offset is small enough:
                                  However, if the offset is larger, then there is NO intersection of the green border with an edge which is contiguous to the red edge you want to round. In this case, RoundCorner simply defaults to terminating the offset border at the orthogonal projection of the edge to round.
                                  I can try to do something about it, but anyway, it will create problems on the shape which have no easy solution.
                                  You may want to redraw the shaping so that you arrange the first edge on the curved part is longer than the offset.
                                  As an alternative, you can try to use Subdivide and Smooth, which operates on a different approach and is less sensitive to the geometry of edge and faces.
                                  Fredo
                                    Tikva2
                                    ok,I understand))
                                    thank you very much for this plugin)))
                                      shredder7753
                                      how can i download? it says i dont have the permissions?
                                      • I Offline
                                        inna.newyork
                                        i downloaded all per instruction,restarted computer, but my sketchup( pro6) says can't find those two plugins! what's wrong????
                                        • fredo6F Offline
                                          fredo6
                                          Did you download LibFredo6 and follow the instructions which are in the main post (in particular about the unzip operation)?
                                          Fredo
                                            Tamp
                                            thanks a lot, it's really be usefull. πŸ˜„
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 74
                                            • 75
                                            • 19 / 75
