    Tools on surface not working
    28 Posts 7 Posters 5.0k Views 7 Watching
      SketchUp has limitations healing edges when they are below 1mm. Are you encountering that limit?
      If yes, scale the object 10 - 100x and try drawing.
      • KrassK
        Krass
        yes you are right! I forgot to scale the object... But at the end, I did it manualy
        Krass
        • KrassK
          Krass
          I enlarged it by a factor of 100, but it doesn't work.
          Krass
          • KrassK
            Krass
            Actually, it works better; I tested it elsewhere and the rectangle isolated the face well.
            Krass
            1 Reply Last reply πŸ‘
              In 90% of edges not healing or holes not filling or missing it is edge size.
              If you are importing scans it is best to x100 the scale to avoid this behaviour.
                I often work with a scale of 1000x. I can treat millmeters as meters that way.
                  The simplest way to deal with many errors, imho.
                  • KrassK
                    Krass
                    Thank you: multiplied by a thousand, it's perfect!
                    Krass
                    • 2 / 2
