    Tools on surface not working
    28 Posts 7 Posters 3.9k Views 7 Watching
    • KrassK Offline
      Krass
      yes, i need to paint high poly surfaces, hard edges painting, but no way
      Krass
      • KrassK Offline
        Krass
        no this zone is not selectable as it should
        Krass
          SketchUp has limitations healing edges when they are below 1mm. Are you encountering that limit?
          If yes, scale the object 10 - 100x and try drawing.
          • KrassK Offline
            Krass
            yes you are right! I forgot to scale the object... But at the end, I did it manualy
            Krass
            • KrassK Offline
              Krass
              I enlarged it by a factor of 100, but it doesn't work.
              Krass
              • KrassK Offline
                Krass
                Actually, it works better; I tested it elsewhere and the rectangle isolated the face well.
                Krass
                  In 90% of edges not healing or holes not filling or missing it is edge size.
                  If you are importing scans it is best to x100 the scale to avoid this behaviour.
                    I often work with a scale of 1000x. I can treat millmeters as meters that way.
                      The simplest way to deal with many errors, imho.
                      • KrassK Offline
                        Krass
                        Thank you: multiplied by a thousand, it's perfect!
                        Krass
                        • 2 / 2
