    Tools on surface not working
    28 Posts 7 Posters 4.4k Views 7 Watching
    • KrassK
      Krass
      ce serait tellement bien si Γ§a pouvait marcher un jour....
      Krass
        Rich O Brien Moderator @Krass
        @Krass said in Tools on surface not working:
        the line tool doesn't work
        Can you expand on this? Is it that the enclosed area is not selectable?
        • KrassK
          Krass
          yes, i need to paint high poly surfaces, hard edges painting, but no way
          Krass
          • KrassK
            Krass
            no this zone is not selectable as it should
            Krass
              SketchUp has limitations healing edges when they are below 1mm. Are you encountering that limit?
              If yes, scale the object 10 - 100x and try drawing.
              • KrassK
                Krass
                yes you are right! I forgot to scale the object... But at the end, I did it manualy
                Krass
                • KrassK
                  Krass
                  I enlarged it by a factor of 100, but it doesn't work.
                  Krass
                  • KrassK
                    Krass
                    Actually, it works better; I tested it elsewhere and the rectangle isolated the face well.
                    Krass
                    1 Reply Last reply πŸ‘
                      In 90% of edges not healing or holes not filling or missing it is edge size.
                      If you are importing scans it is best to x100 the scale to avoid this behaviour.
                        I often work with a scale of 1000x. I can treat millmeters as meters that way.
                          The simplest way to deal with many errors, imho.
                          • KrassK
                            Krass
                            Thank you: multiplied by a thousand, it's perfect!
                            Krass
                            • 2 / 2
