    [Plugin] triangulateFaces.rb v1.2 20101120
    97 Posts 21 Posters 117.7k Views 21 Watching
    • TIGT Online
      @coronel said:
      Could you please clarify for a 3D newie the purpose of triangulation in this case?
      Does it means the model will be correct or will work better or is merely a way of get more detail?
      If you have a mesh that's rectangular it won't deform consistently. If you triangulate the faces they will... etc.
        CPhillips
        I needed the triangulation to prepare a model for export.
        Thanks for incorporating it into your script TIG! Why is it that back facing UV's didn't work?
          CPhillips
          There is only a method to 'place material textures on a face' - and that assumes a 'front_face' - there's no 'back_face' method...
          Do you mean position_material? It takes a bool for front or back material
          Error 404 (Not Found)!!1
          (code.google.com)
          • I Offline
            ideas_arte
            Thanx really useful!
            where download? 😳
              Jim
              @ideas_arte said:
              where download?
              That's a valid question; it is not clear which version is the latest, and it is harder than necessary to locate the download.
              The download is about 5 posts before this one.
              • TIGT Online
                There is only a method to 'position material textures on a face' - and that assumes a 'front_face' - there's no 'back_face' method ? ...
                • TIGT Online
                  (code.google.com)
                  Duh! 😳 I'll adjust the code and re-post...
                  • TIGT Online
                    There's something afoot... What I posted before worked - on keeping the front face texture mapping but not on the back_face... Now when I try it it fails to map both faces ? Any ideas - CPhillips's idea worked fine in tests but now seems to fail...
                      CPhillips
                      Post the code and I'll have a look. It might be the face.mesh(1). I think you need to use a different number when you want back uv's as well.
                      • honoluludesktopH Offline
                        honoluludesktop
                        Hi TIG, Any way to convert this kind of mesh into its component triangles?
                        Drapery05.skp
                        • TIGT Online
                          I wrote an example script a few weeks ago to do something like this... http://forums.sketchucation.com/viewtopic.php?p=186068#p186068 ❓
                            honoluludesktop
                            TIG, Thanks for the link, it works. Now I can make small edits to the (mesh?).
                            • jeff hammondJ Offline
                              jeff hammond
                              @tig said:
                              Result: it triangulates a face... front Texture UVs are kept.
                              hey TIG,
                              if i run the script on this sphere, the UVs go haywire.
                              am i misunderstanding or misusing the script?
                              thanks
                              [edit] ok, wait.. i just read the rest of the thread and i guess this hasn't been sorted out ?
                              sorry about the size.. i guess i could of used a smaller texture πŸ™‚
                              dotdotdot
                              • TIGT Online
                                hey TIG,
                                thanks
                                It's broken... the UV mapping was CJP's but it still needs fixing...
                                  jeff hammond
                                  ah, ok..
                                  too bad πŸ˜„
                                  [fwiw - i can manually triangulate the sphere using and everything turns out ok.. i guess this script is doing something other than just drawing lines to cut quads in half?]
                                  dotdotdot
                                  • TIGT Online
                                    ah, ok..
                                    too bad πŸ˜„
                                    It triangulates the quads and tries to fix the UV mapping - obviously very badly !!!! CJP help! ❗
                                    • TIGT Online
                                      See this new script just for selected quad faces - it keeps UV mapping etc...
                                      http://forums.sketchucation.com/viewtopic.php?p=201025#p201025
                                        @tig said:
                                        Known Issues: Back Materials are kept, but these Texture UVs cannot be re-used;
                                        there's a Ruby Console warning message if this problem is found...
                                        Solution: use the front faces only for textures IF you might be triangulating later.
                                        Why is it that you can't preserve the UVs of the backfaces?
                                        • TIGT Online
                                          We tried [CJP+me] but we couldn't get it to work - any ideas on fixing the whole issue of triangulation and keep UV mapping to front and back faces would be appreciated...
                                            hm... looking at the code:
                                            mesh=face.mesh(1)
                                            This will give you a PolygonMesh with only the FrontUV.
                                            mesh=face.mesh(3) will give you front and back.
                                            but you need to change this as well: uvs=mesh.uvs(true) true will give you set of front UVs, false will give you back UVs if you specified that in the .mesh method.
                                            I'm not quite sure I understand the purpose of this:
                                            outmesh = Geom::PolygonMesh.new faces.each{|f|outmesh.add_polygon(verts[f[0].abs-1],verts[f[1].abs-1],verts[f[2].abs-1])}
                                            Why create a new PolygonMesh? Rearranging the polygons?
                                            • 2 / 5
