    Haste makes waste
    31 Posts 9 Posters 3.7k Views 9 Watching
    • david57D
      david57
      This house looks miniature, have to scale down the trees or leafs.
      • J
        john.warburton
        ... and add windows and doors ... πŸ˜„
        Life's a reach, and then you gybe.
        • C
          cadmunkey
          Nice trees tho, are those the google warehouse smart trees?
          • david57D
            david57
            No, this are not the smart trees but i did try them and i found that when
            they were rendered, that some leafs were distorted horizontally.
            • david57D
              david57
              Trees scaled down. All trees were made with ngPlant version 0.9.7.
              http://forums.sketchucation.com/viewtopic.php?f=169&t=17162
              • Chris FullmerC
                Still not big eoungh. The front tree is a sort of gangly teen-age tree. It should be just taller than your arch. The trees in the background look liike they might be closer to full size. The could be a little taller than the house itself. I would say you could still make the house 2x larger at least, and then make the front tree smaller so its not even 1/2 as tall as the back ones. See how that works,
                Chris
                All my Plugins I've written
                • david57D
                  david57
                  Thanks Chris, I agree about the one in the front and it looks like a young and and should be much smaller. I'm trying to imitate the pros like on this gallery from Russia.
                  Some examples:
                  http://www.archvis.ru/portfolio/exteriors/lot26/
                  • pbacotP
                    Some examples:
                    Although that is intense modeling on that referenced page, I would say they also have a scale or rendering problem. You can imagine that house as 5' high model in a bunch of bushes.
                    • david57D
                      david57
                      Yup, none of this is reality we just imagine all of this sizes.
                      Trees scaled down again and buildings were left untouched because i wanted to use
                      the roof tiles as a gauge. Each tile is one foot wide in SU.
                      • EscapeArtistE
                        EscapeArtist
                        I like those tiles and the stucco textures, they are very clean and even. Are they available for free or are they part of some render package?
                          All these facades without windows are very mysterious! 😎
                          • david57D
                            david57
                            Roof tiles, You can find them here.
                            http://forums.sketchucation.com/viewtopic.php?f=40&t=20379
                            Texture not included and made with http://www.mapzoneeditor.com/.
                            • pbacotP
                              Nice roof tiles and roofs. Isn't that a LOT of work to lay them out?
                              • david57D
                                david57
                                No, I think its easy, the hard part is cutting them and takes long.
                                In real life you have to do this in the hot sun and takes days. πŸ˜„
                                • david57D
                                  david57
                                  To cut down the time just use the mover tool. Copy and move.
                                  • david57D
                                    david57
                                    • david57D
                                      david57
                                      • david57D
                                        david57
                                        This take forever to render and its unfinished.
                                        • S
                                          Sir
                                          what renderer are you using? and on what settings? its a very simple scene it shoudln't take too long
                                          • david57D
                                            david57
                                            Using Kerkythea and rendering this last one with BiPT.
                                            Others Kerkythea and rendered using MLT.
                                            • 1 / 2
