    Haste makes waste
    31 Posts 9 Posters 3.5k Views 9 Watching
    • david57D Offline
      david57
      Trees scaled down. All trees were made with ngPlant version 0.9.7.
      404 Not Found
      (forums.sketchucation.com)
      • Chris FullmerC Offline
        Still not big eoungh. The front tree is a sort of gangly teen-age tree. It should be just taller than your arch. The trees in the background look liike they might be closer to full size. The could be a little taller than the house itself. I would say you could still make the house 2x larger at least, and then make the front tree smaller so its not even 1/2 as tall as the back ones. See how that works,
        • david57D Offline
          david57
          Thanks Chris, I agree about the one in the front and it looks like a young and and should be much smaller. I'm trying to imitate the pros like on this gallery from Russia.
          Some examples:
          http://www.archvis.ru/portfolio/exteriors/lot26/
          • pbacotP Offline
            Some examples:
            Although that is intense modeling on that referenced page, I would say they also have a scale or rendering problem. You can imagine that house as 5' high model in a bunch of bushes.
            • david57D Offline
              david57
              Yup, none of this is reality we just imagine all of this sizes.
              Trees scaled down again and buildings were left untouched because i wanted to use
              the roof tiles as a gauge. Each tile is one foot wide in SU.
              • EscapeArtistE Offline
                EscapeArtist
                I like those tiles and the stucco textures, they are very clean and even. Are they available for free or are they part of some render package?
                  All these facades without windows are very mysterious! 😎
                  • david57D Offline
                    david57
                    Roof tiles, You can find them here.
                    http://forums.sketchucation.com/viewtopic.php?f=40&t=20379
                    Texture not included and made with http://www.mapzoneeditor.com/.
                    • pbacotP Offline
                      Nice roof tiles and roofs. Isn't that a LOT of work to lay them out?
                      • david57D Offline
                        david57
                        No, I think its easy, the hard part is cutting them and takes long.
                        In real life you have to do this in the hot sun and takes days. πŸ˜„
                        • david57D Offline
                          david57
                          To cut down the time just use the mover tool. Copy and move.
                          • david57D Offline
                            david57
                            • david57D Offline
                              david57
                              • david57D Offline
                                david57
                                This take forever to render and its unfinished.
                                  Sir
                                  what renderer are you using? and on what settings? its a very simple scene it shoudln't take too long
                                  • david57D Offline
                                    david57
                                    Using Kerkythea and rendering this last one with BiPT.
                                    Others Kerkythea and rendered using MLT.
                                      Sir
                                      ill wait for a kerky expert to pop by then, but does each tree have a separate leaf?
                                        Connor
                                        If this is an outdoor scene lit only by the sun you should try the Progressive Path Tracing setting. See if that speeds things up.
                                        It also looks like a healthy amount of geometry with the modelled roof tiles and trees. That is probably contributing to the speed.
                                        • david57D Offline
                                          david57
                                          Yes, PPT, using that now. I have to remove also lots of twigs, stems not seen and unnecessary geometry. Will also try reducing translucency on all trees. I tryed pseudo translucency and doesn't look right.
                                          • david57D Offline
                                            david57
                                            Palm tree and small plant from Gooogle Warehouse.
