    Haste makes waste
    31 Posts 9 Posters 3.7k Views 9 Watching
    • Chris FullmerC
      Still not big eoungh. The front tree is a sort of gangly teen-age tree. It should be just taller than your arch. The trees in the background look liike they might be closer to full size. The could be a little taller than the house itself. I would say you could still make the house 2x larger at least, and then make the front tree smaller so its not even 1/2 as tall as the back ones. See how that works,
      • david57D
        david57
        Thanks Chris, I agree about the one in the front and it looks like a young and and should be much smaller. I'm trying to imitate the pros like on this gallery from Russia.
        Some examples:
        http://www.archvis.ru/portfolio/exteriors/lot26/
        • pbacotP
          Some examples:
          Although that is intense modeling on that referenced page, I would say they also have a scale or rendering problem. You can imagine that house as 5' high model in a bunch of bushes.
          • david57D
            david57
            Yup, none of this is reality we just imagine all of this sizes.
            Trees scaled down again and buildings were left untouched because i wanted to use
            the roof tiles as a gauge. Each tile is one foot wide in SU.
            • EscapeArtistE
              EscapeArtist
              I like those tiles and the stucco textures, they are very clean and even. Are they available for free or are they part of some render package?
                All these facades without windows are very mysterious! 😎
                • david57D
                  david57
                  Roof tiles, You can find them here.
                  http://forums.sketchucation.com/viewtopic.php?f=40&t=20379
                  Texture not included and made with http://www.mapzoneeditor.com/.
                  • pbacotP
                    Nice roof tiles and roofs. Isn't that a LOT of work to lay them out?
                    • david57D
                      david57
                      No, I think its easy, the hard part is cutting them and takes long.
                      In real life you have to do this in the hot sun and takes days. πŸ˜„
                      • david57D
                        david57
                        To cut down the time just use the mover tool. Copy and move.
                        • david57D
                          david57
                          • david57D
                            david57
                            • david57D
                              david57
                              This take forever to render and its unfinished.
                                Sir
                                what renderer are you using? and on what settings? its a very simple scene it shoudln't take too long
                                • david57D
                                  david57
                                  Using Kerkythea and rendering this last one with BiPT.
                                  Others Kerkythea and rendered using MLT.
                                    Sir
                                    ill wait for a kerky expert to pop by then, but does each tree have a separate leaf?
                                    • C
                                      Connor
                                      If this is an outdoor scene lit only by the sun you should try the Progressive Path Tracing setting. See if that speeds things up.
                                      It also looks like a healthy amount of geometry with the modelled roof tiles and trees. That is probably contributing to the speed.
                                      • david57D
                                        david57
                                        Yes, PPT, using that now. I have to remove also lots of twigs, stems not seen and unnecessary geometry. Will also try reducing translucency on all trees. I tryed pseudo translucency and doesn't look right.
                                        • david57D
                                          david57
                                          Palm tree and small plant from Gooogle Warehouse.
                                          • david57D
                                            david57
                                            To Mat B: Yes, All trees are using the same leaf.
                                            Here's a front view with the palm. PPT render. I need bushes. Dont like the plant and will check warehouse to see what else they have, there.
