    Haste makes waste
    31 Posts 9 Posters 2.6k Views 9 Watching
    • pbacotP Offline
      @david57 said:
      Thanks Chris, I agree about the one in the front and it looks like a young and and should be much smaller. I'm trying to imitate the pros like on this gallery from Russia.
      Some examples:
      http://www.archvis.ru/portfolio/exteriors/lot26/
      Although that is intense modeling on that referenced page, I would say they also have a scale or rendering problem. You can imagine that house as 5' high model in a bunch of bushes.
      • david57D Offline
        david57
        Yup, none of this is reality we just imagine all of this sizes.
        Trees scaled down again and buildings were left untouched because i wanted to use
        the roof tiles as a gauge. Each tile is one foot wide in SU.
        • EscapeArtistE Offline
          EscapeArtist
          I like those tiles and the stucco textures, they are very clean and even. Are they available for free or are they part of some render package?
            All these facades without windows are very mysterious! 😎
            • david57D Offline
              david57
              Roof tiles, You can find them here.
              http://forums.sketchucation.com/viewtopic.php?f=40&t=20379
              Texture not included and made with http://www.mapzoneeditor.com/.
              • pbacotP Offline
                Nice roof tiles and roofs. Isn't that a LOT of work to lay them out?
                • david57D Offline
                  david57
                  No, I think its easy, the hard part is cutting them and takes long.
                  In real life you have to do this in the hot sun and takes days. πŸ˜„
                  • david57D Offline
                    david57
                    To cut down the time just use the mover tool. Copy and move.
                    • david57D Offline
                      david57
                      • david57D Offline
                        david57
                        • david57D Offline
                          david57
                          This take forever to render and its unfinished.
                            Sir
                            what renderer are you using? and on what settings? its a very simple scene it shoudln't take too long
                            • david57D Offline
                              david57
                              Using Kerkythea and rendering this last one with BiPT.
                              Others Kerkythea and rendered using MLT.
                                Sir
                                ill wait for a kerky expert to pop by then, but does each tree have a separate leaf?
                                  Connor
                                  If this is an outdoor scene lit only by the sun you should try the Progressive Path Tracing setting. See if that speeds things up.
                                  It also looks like a healthy amount of geometry with the modelled roof tiles and trees. That is probably contributing to the speed.
                                  • david57D Offline
                                    david57
                                    Yes, PPT, using that now. I have to remove also lots of twigs, stems not seen and unnecessary geometry. Will also try reducing translucency on all trees. I tryed pseudo translucency and doesn't look right.
                                    • david57D Offline
                                      david57
                                      Palm tree and small plant from Gooogle Warehouse.
                                      • david57D Offline
                                        david57
                                        To Mat B: Yes, All trees are using the same leaf.
                                        Here's a front view with the palm. PPT render. I need bushes. Dont like the plant and will check warehouse to see what else they have, there.
                                        • david57D Offline
                                          david57
                                          Couldn't find one but I tried one called Cycas Palm from: http://blender-archi.tuxfamily.org/Greenhouse#European_Oak
                                          Something went wrong and plant looks like it growing something.
                                          • david57D Offline
                                            david57
                                            Palm next to the rocks also from Google warehouse.
