    Haste makes waste
    31 Posts 9 Posters 2.8k Views 9 Watching
      Sir
      ill wait for a kerky expert to pop by then, but does each tree have a separate leaf?
        Connor
        If this is an outdoor scene lit only by the sun you should try the Progressive Path Tracing setting. See if that speeds things up.
        It also looks like a healthy amount of geometry with the modelled roof tiles and trees. That is probably contributing to the speed.
        • david57D Offline
          david57
          Yes, PPT, using that now. I have to remove also lots of twigs, stems not seen and unnecessary geometry. Will also try reducing translucency on all trees. I tryed pseudo translucency and doesn't look right.
          • david57D Offline
            david57
            Palm tree and small plant from Gooogle Warehouse.
            • david57D Offline
              david57
              To Mat B: Yes, All trees are using the same leaf.
              Here's a front view with the palm. PPT render. I need bushes. Dont like the plant and will check warehouse to see what else they have, there.
              • david57D Offline
                david57
                Couldn't find one but I tried one called Cycas Palm from: http://blender-archi.tuxfamily.org/Greenhouse#European_Oak
                Something went wrong and plant looks like it growing something.
                • david57D Offline
                  david57
                  Palm next to the rocks also from Google warehouse.
                  • david57D Offline
                    david57
                    Trying out the light green one to the left and also from google warehouse.
                    • david57D Offline
                      david57
                      Not satisfied, i still feel that i need to do more work on it.
                      • david57D Offline
                        david57
                        I over did it.
                        • david57D Offline
                          david57
                          Made a hedge with a free software named Bantam3DGrass.
                          • 2 / 2
