Haste makes waste
This house looks miniature, have to scale down the trees or leafs.
... and add windows and doors ...
Nice trees tho, are those the google warehouse smart trees?
No, this are not the smart trees but i did try them and i found that when
they were rendered, that some leafs were distorted horizontally. -
Trees scaled down. All trees were made with ngPlant version 0.9.7.
Still not big eoungh. The front tree is a sort of gangly teen-age tree. It should be just taller than your arch. The trees in the background look liike they might be closer to full size. The could be a little taller than the house itself. I would say you could still make the house 2x larger at least, and then make the front tree smaller so its not even 1/2 as tall as the back ones. See how that works,
Thanks Chris, I agree about the one in the front and it looks like a young and and should be much smaller. I'm trying to imitate the pros like on this gallery from Russia.
Some examples:
http://www.archvis.ru/portfolio/exteriors/lot26/ -
Some examples:
http://www.archvis.ru/portfolio/exteriors/lot26/Although that is intense modeling on that referenced page, I would say they also have a scale or rendering problem. You can imagine that house as 5' high model in a bunch of bushes.
Yup, none of this is reality we just imagine all of this sizes.
Trees scaled down again and buildings were left untouched because i wanted to use
the roof tiles as a gauge. Each tile is one foot wide in SU.
I like those tiles and the stucco textures, they are very clean and even. Are they available for free or are they part of some render package?
All these facades without windows are very mysterious!
Roof tiles, You can find them here.
http://forums.sketchucation.com/viewtopic.php?f=40&t=20379Texture not included and made with http://www.mapzoneeditor.com/.
Nice roof tiles and roofs. Isn't that a LOT of work to lay them out?
No, I think its easy, the hard part is cutting them and takes long.
In real life you have to do this in the hot sun and takes days.
To cut down the time just use the mover tool. Copy and move.
This take forever to render and its unfinished.
what renderer are you using? and on what settings? its a very simple scene it shoudln't take too long
Using Kerkythea and rendering this last one with BiPT.
Others Kerkythea and rendered using MLT.
