    [Plugin] Sculpt Tools (help)
    188 Posts 46 Posters 88.4k Views 46 Watching
      BTM
      @chris fullmer said:
      Charly, you don't have duplicate icons and your on Windows. Are most people still getting double set of toolbar icons? I am running Vista 64bit and I still get ther double icons. Anyone else?
      Chris
      … I don't think anybody else said they were getting duplicate icons but you. ( Though, in an older version of the script there were duplicates in the plugins menu; there shouldn't be anymore. )
      It's a bit weird. does anyone else with vista have the same problem as Chris? 😕
      • majidM Offline
        majid
        this is not Sketchup...you are kidding me this is skerinobrush **U**P, .... thanx this is working fine....
        • majidM Offline
          majid
          It is definetely a great plugin... it workes fine with SU6 ,but bulge tool sometimes doesn't works with SU7...and I must choose another tool , then comeback to sculp tool, to force it working.is it a bug or interfere with other plugs...something abou SU7 or...?
            tomasz
            Thank you BTM. It is a great addition to SU!
            Tomasz
            Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
              BTM
              I don't know.
              When it doesn't work, what exactly do you mean? Does it stop working altogether? try keeping the ruby console open and tell me what pops up in it when the tool stops working.
                dacad
                hi btm
                I've been playing with the plugin, which as you know already it's great (can imagine the smove tool stop being used that much now for land sculpting...) but i have some suggestions if you don't mind.
                • i'm also one that would like to have visual helpers like a circle showing the radios when sculpting;
                • is possible so have an option to have a "symmetry option" on? Because when i know i can use 2 components for half of each face but that won't really work that well because the faces in the extremities will move too making a hole in the middle (see pic below);
                • an option that i can turn off or on for when sculpting if i keep pressing the mouse he will keep smoothing/bulging/etc or will just do it once for each stroke (hope I'm making myself clear).
                Again thanks for this plugin and i hope you don't think i'm being ungrateful and asking for too much.
                thanks
                David
                  BTM
                  hi btm
                  thanks
                  David
                  Visual help is what I'm working on 😎 I just need to figure out how to draw a circle with view.draw 😒
                  Symmetry… I know what you mean. Right now, I use JS Align to make things I sculpt symmetrical, but it's a bit of a pain. As for a symmetry script, possibly, although it wouldn't be that easy.
                  Lastly, I don't understand your third question. can you clarify?
                    dacad
                    hi BTM
                    to my third question what i meant is that right now when sculpting if i dont move the mouse but keep pressing the mouse button in the same spot in the model the plugin keeps "sculpting" that spot, but if possible it would be great to turn that off or on has we need, so that spot wouldn't be just continusly pushed/bulged/smooth by the sculpt tools independently of the time we keep pressing the mouse button. If i'm not mistaken in blender this is called airbrush in the sculpt menu and that can be turn on or off.
                    Sorry if i can not make myself more clear...😞 my english sucks lol
                    David
                      MrWip
                      Thanks BTM, really, many many thanks ! That's the tool many people where waiting for, without even the smallest hope to see it coming... so, that's great.
                      For terrain / site modelling it's a must have. In just a few minutes you can get a nice result from a simple grid, and adapt it sooo quickly :
                      (the altitude lines have been added after the sculpting operation )
                      Also it's really cool to use it to 'age' elements , by adding a bit of 'random' distortion to their shape at some point.
                      I'm just a bit wondering on the purpose of the push tool. In fact, it does a kind of flatten effect, and often creates intersection bugs between triangles... so I'm not sure of the real interest of it, but maybe I'm not using it in the right way.
                      With some visual control and dynamic adjustment it will be a perfect script ! (and please keep the Mudbox icones, they're really efficient )
                      http://www.wip-archi.com
                        BTM
                        Push just pushes vertices (points) away from the tool. When holding shift, it does the opposite. Depending on whether you use it on or next to the mesh, it will give fairly different results. It's best to have the push tool at a lower strength if you're using it on a mesh.
                          dacad
                          BTM
                          This plugin it's getting better and better 😄. using the push with shift pressed gives and effect similar to pinch that is great to accentuate wrinkles in head models or holes and sort in landscape. THANKS!!!
                          About the 3rd point i explained, i said the oposite that hapens in your plugin (if i let the mouse pressed he doesn't keep pushing), but anyway it's the same thing that's pretended: turning that on and off.
                          Back to playing with the plugin 🎉
                          David
                            AcesHigh
                            where are you guys downloading the plugin to test it??? There is no download link anywhere!
                            • MALAISEM Offline
                              MALAISE
                              Hi AcesHigh
                              Just have look on the same topic ( page 4 ), if not here is the link http://forums.sketchucation.com/download/file.php?id=30086
                              MALAISE 😄
                                BTM
                                it's on page 4 😉
                                • BurkhardB Offline
                                  Burkhard
                                  Please BTM use page 1 for posting the updates. The thread shows 1....6,7,8,9,10. It's a pain to get page 4 😉
                                  [http://www.ia-plus.de(http://www.ia-plus.de)]
                                    BTM
                                    … And that's the point 😎 I don't need everyone downloading it yet, it's not the finished version. Right now I just need the people who really want to download it to, so that I can get feedback from those people on what should be done. When I think I can release a version 1.0, I'll make a new thread for it. 😉
                                    Also, I'm trying to get entities.add_circle to draw the circle for view.draw, but I don't know how to get the resulting points to use, without actually making the circle. Anyone have any ideas? 😄
                                    • soloS Offline
                                      solo
                                      Sounds fair enough, looking forward to final release.
                                      http://www.solos-art.com
                                        You can't mix the circles in geometry and stuff drawn on the screen with view temporarily...
                                        You couldmake a circle as a component that's faceMe ans erase/delete-definition afterwards... BUT the proper way is to gets the points for a circle...
                                        def circleArray(center,normal,radius,numseg)
                                            # Get the x and y axes
                                            axes = Geom;;Vector3d.new(normal).axes
                                            center = Geom;;Point3d.new(center)
                                            xaxis = axes[0]
                                            yaxis = axes[1]
                                            xaxis.length = radius
                                            yaxis.length = radius
                                            # compute the points
                                            da = (Math;;PI * 2) / numseg
                                            pts = []
                                            for i in 0...numseg do
                                                angle = i * da
                                                cosa = Math.cos(angle)
                                                sina = Math.sin(angle)
                                                vec = Geom;;Vector3d.linear_combination(cosa,xaxis,sina,yaxis)
                                                pts.push(center + vec)
                                            # close the circle
                                            pts.push(pts[0].clone)
                                            pts
                                        end#def
                                        then you set values for center, normal, radius and numseg
                                        then make array
                                        circleArray=circleArray(center,normal,radius,numseg)
                                        then use it in view ?
                                        view.draw_polyline(circleArray)
                                        It should ignore any Zs...
                                        This is 'untried'....
                                          BTM
                                          Thanks TIG 👍
                                          …Anyways, since an admin changed the name of thread to include [Plugin] just a little while ago, I'll put a link to the download on the first page to avoid confusion. Still, when I release v.1, I'll make a new thread.
                                          • MALAISEM Offline
                                            MALAISE
                                            Hi BTM
                                            Very interesting plugin for deformation ( geological cut., impact, metal casting.)
                                            Suggestion : would it be possible to make visible the "stress vector" before calculation
                                            while drawing to set the direction and module easier ?
                                            Here a picture :Sculpt_idea.png
                                            MALAISE 👍 👍
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 7 / 10
