    [Plugin] Sculpt Tools (help)
    207 Posts 48 Posters 112.9k Views 48 Watching
    • romboutR
      rombout
      @solo said:
      With a bit of playing, your code will be able to produce this faster than I did using SDS.
      http://img19.imageshack.us/img19/982/1solocurtain4.png
      ehhh sorry SDS???
      • Chris FullmerC
        SDS is SubDivide and Smooth by Dale Martens, also known as Whaat on this forum.
        File Not Found
        (www.smustard.com)
        costs $22USD.
        Chris
        All my Plugins I've written
        • romboutR
          rombout
          oke chris,
          thanks for explaining it to me... feel so dumb. Really want this script for a long time and still need to find someone with a credit card which can buy it for me!!! šŸ˜ž
          • Chris FullmerC
            Smustard does take paypal if you have an account with them. They are nice, they will hook up directly to your bank account, so you don't need a credit card at all. And you can also recieve payments from other people via paypal.
            Chris
            • L
              lapx
              Does sculpt tools work with v 8?
              • P
                popfunky
                NEED PLUGIN NOW THANK YOU SO MUCH
                • BoxB
                  http://i155.photobucket.com/albums/s296/storeben/Bike/caps-lock.jpg
                  • KrisidiousK
                    Krisidious
                    Yes, Smustard has always honored my hatred of Paypal with google checkout invoices for products I want.
                    By: Kristoff Rand
                    • KrassK
                      Krass
                      This post is deleted!
                      • KrassK
                        Krass
                        Thanks a lot, a lot for this plugin ! !
                        Would it be possible to increase the strength and radius using keyboard shortcuts, rather than having to open the settings window?
                        It’s not very convenient when using it frequently.
                        Perhaps this feature is already available?
                        Thanks.
                        TIGT 1 Reply Last reply
                        • TIGT
                          TIG Moderator @Krass
                          @Krass
                          You are reading and asking on a 13 year old thread...
                          I think this tool is no longer under development.
                          there might be other newer similar tools around ?
                          • KrassK
                            Krass
                            Thanks,
                            if somone knows about a better free tool like this.... Anyway its very good and works on SU 2024. iS it open source so that we can modify it?
                            • TIGT
                              The tool is actually 17 years since it was written. It stuck at v1.0 and never advanced. The author did add a 'copyright' notice into the start of the main code RB files. There is an email address for him there too. I suspect that he is no longer interested in it. If you were to 'tweak' some files purely for your own use [without publishing them with his permission] I'd think that's probably OK... But please note that the Ruby coding is the files is 'archaic' and might not work on newer SketchUp versions - and it's poorly formed without modules/classes etc and uses the now much frowned upon $ global variables... So use [and edit] with caution...
                              • KrassK
                                Krass
                                I got help modifying the .rb code and achieved what I wanted: the ability to adjust brush strength and radius using keyboard shortcuts. A pop-up appears when I click, displaying the current value. However, I do need to adjust the radius "step" size depending on whether I'm working on a large scale—like for terrain—or doing fine detail work, such as on a face.
                                Combined with the Mesh Tools plugin, I now have a free kit that’s on par with Artisan (or close to it!).
                                1 Reply Last reply šŸ‘
                                • KrassK
                                  Krass
                                  yes, I think the good way would be to propose him the modified version, if he agrees, let him publish this or let us do it. For now, yes we are two users of this custom Sculpt tools.
                                  • KrassK
                                    Krass
                                    sorry for my "froggy" english, I didn't use a translator (french to english)
                                    Didier BurD 1 Reply Last reply
                                    • Didier BurD
                                      Didier Bur @Krass
                                      @Krass
                                      I use SculptTools to adjust the shape of AI-generated medieval characters. The problem is that the UV coordinates are lost as soon as the shape is modified. Preserving these coordinates would be a significant improvement.
                                      DB
                                      • KrassK
                                        Krass
                                        Hello, that usual, I think the best way tu recover your mapping after modifying geometry is to select only the ugly faces and project your material with Fredo6 thrupaint
                                        • KrassK
                                          Krass
                                          but I think you won't be able to do this with AI generted UV
                                          • KrassK
                                            Krass
                                            One solution is to repair the damaged areas—like applying patches—using new material created from a screenshot of the figure taken before the modifications, and then applying it in "projected" mode using Thrupaint.
                                            KrassK 1 Reply Last reply
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 10 / 11
