    [Plugin] Sculpt Tools (help)
    188 Posts 46 Posters 100.2k Views 46 Watching
      chango70
      What method do people use to create the initial grid? Is there a Ruby that can do it? I know Subdivide and smooth does it however in this case the surface only need to be divided into squares not triangles.
      • Chris FullmerC Offline
        I use the sandbox tools to make a grid. Or I make a sphere, and I think it does need to be in triangles.
        Have you seen the other thread with the official release? This thread is now outdated.
        • mitcorbM Offline
          mitcorb
          chango70:
          Try the plugin Triangulate by TIG (I believe this is what it is called and the author), then select the geometry and apply Sandbox "Add Detail". This in effect doubles, or subdivides the selection by one "degree". Continue adding detail to suit, but be mindful of Sketchup's low poly tolerance.
          I have found this to work in the couple of experiments I have done. This is just my experience. I do not have Subdivide and Smooth.
          Others may use some other methods.
          • mitcorbM Offline
            mitcorb
            By the way, if you were not already aware, Sculpt Tools is now at Version 1.0 with a separate thread, here http://forums.sketchucation.com/viewtopic.php?f=180&t=20781
            I am guessing any further discussion should occur in that thread. And sorry that the url is not a link. I will figure out how to do that eventually.
            Edit: nevermind, it turned into a link when I viewed my post.
              chango70
              Cheers I will check the other thread.
              • majidM Offline
                majid
                how that "lock" feature works?
                I've tried several times and the result was, 2times of crash, and 2 times "nothing happening".. 😄
                • romboutR Offline
                  rombout
                  @solo said:
                  With a bit of playing, your code will be able to produce this faster than I did using SDS.
                  http://img19.imageshack.us/img19/982/1solocurtain4.png
                  ehhh sorry SDS???
                    SDS is SubDivide and Smooth by Dale Martens, also known as Whaat on this forum.
                    File Not Found
                    (www.smustard.com)
                    costs $22USD.
                    • romboutR Offline
                      rombout
                      oke chris,
                      thanks for explaining it to me... feel so dumb. Really want this script for a long time and still need to find someone with a credit card which can buy it for me!!! 😞
                        Smustard does take paypal if you have an account with them. They are nice, they will hook up directly to your bank account, so you don't need a credit card at all. And you can also recieve payments from other people via paypal.
                          lapx
                          Does sculpt tools work with v 8?
                            popfunky
                            NEED PLUGIN NOW THANK YOU SO MUCH
                            • BoxB Offline
                              http://i155.photobucket.com/albums/s296/storeben/Bike/caps-lock.jpg
                              • KrisidiousK Offline
                                Krisidious
                                Yes, Smustard has always honored my hatred of Paypal with google checkout invoices for products I want.
                                By: Kristoff Rand
                                • 10 / 10
