    Let's have a Hardware speed test for SU
    132 Posts 72 Posters 88.7k Views 72 Watching
    • P Offline
      pmolsen
      Ran it successfully on SU7.1 and SU8. Medion akoya MD97310 (from Aldi). 15.4 fps on SU7.1. 27.6 fps on SU8.
      • N Offline
        naikrovek
        SketchUp 8:
        Not bad for a $500 PC and $50 video card.
        • Wo3DanW Offline
          Wo3Dan
          How come my old dusty machine is performing rather well? / what am I doing "wrong"?
          (PC=5.5 years of age, almost retired)
          Micromaxx/Medion
          AMD Athlon 64/3000+
          Clockspeed 2.00GHz 1.5GB
          NVIDIA GeForce FX5700
          With SU8 pro (didn't test SU7) and testing the original file:
          1. nothing changed (hidden geometry and shadows off) => around ~62.7 frames/second
            (shadows on didn't seem to matter that much, same results => ~62.5 frames/second)
            2)edges+profiles on, hidden geometry (and shadows) displayed => ~35.8 frames/second
          ~ indicates that I did run the code line multiple times.
          After changes to settings like 'hidden geometry' only the first run drops down frame rate.
          After that a constant higher rate as stated above.
          • fuzzionF Offline
            fuzzion
            To lazy to cut n paste.
            72 frames displayed in 3.963sev
            Avg. frames = 0.055 seconds
            18.3 frames/sec
            System spec
            2 year old FX gateway laptop
            64bit VIsta
            6gb 1066mhz dual chan ram
            centrino 2, dual core 2.33ghz , not sure about fsb
            9800 GTS 1GB Nvidia card
            Intel Chipset
            "Only the dead have seen the end of war" - Plato
              mac1
              wo3dan
              So much for all the hype about new machines. Are you running on a AGP_ bus also? Try toggling the transparency select on the face styles and see if it makes much difference. It did for me
              fussion
              It appears you are running too slow for these test conditions. Do you have problems with model display?? Suggest you run the GLview 322.exe and see what type of OpenGL you really have. Also toggle the transparency on the face styles and see if that makes any difference for you. My testing showed the extents of the model play a roll. Make sure to hit zoom extents before running test
              • jujuJ Offline
                juju
                SU 8.0.4811
                • KrisidiousK Offline
                  Krisidious
                  mine... I'm depressed, although I do have 4 monitors.
                  By: Kristoff Rand
                    bentleykfrog
                    Wow, some unusual results here. I've had some discrepancy between Sketchup v.8.0.4811 and Sketchup v.7.1.6860
                    Under v.7.1.6860 I got:
                    Sketchup 7.1.6860 test result
                    But under v.8.0.4811 I got:
                    Sketchup 8.0.4811 test result
                    After some troubleshooting, I found that disabling "Enable Transparency" in the Styles window gave this result in v.8.0.4811:
                    Sketchup 8.0.4811 (No Transparency) test result
                    Its unusual, I disabled "Enable Transparency" under 7.1.6860 and there was no noticable difference in the animations performance, but this is different for 8.0.4811. I'm not sure what is going on here but for consistency in results I think the style in the file should be updated to disable the transparency.
                    Here's my stats:
                    Mac Pro (1,1) with a modified 8 core x5355 @ 2.66 GHz (2 processors)
                    16gb DDR2 ECC ram
                    Ati Radeon HD 5770 (apple version)
                    SATA II
                    Windows 7 Ultimate 64bit
                      Masta Squidge
                      since i like this kind of stuff...
                      Q6600 quad core @ 3.2 GHZ.
                      EVGA GTX465SC core unlocked to 448 cores and overclocked 10%
                      No shadows:
                      Shadows:
                        masrulpilami
                        does anyone know how to test it in SU8?=D
                          Exactly the same as in SketchUp 7
                            Krisidious
                            new upgrade... I5 2500k with 2 GTX 470s
                            1 gtx 470
                            2 gtx 470 running sli
                            stats
                            By: Kristoff Rand
                            • bazB Offline
                              baz
                              New puter. I think the graphics card is letting me down cos results are similiar to older machines.
                                Krisidious
                                well baz that perplexed me. becuase if I'm not mistaken the GeForce 210 is a rather low end card right? like $50.00? and your score is smoking mine. so I figuired it had to be the I7 2600... but I'm running the I52500k unlocked at like 4.8ghz... although you seem to have 8 cores... you'll have to inform me on how that is? but anyway. I went into the nvidia control panel under 3D settings and turned everything up on the global settings...
                                this improved my score by 100%
                                I would be interested to know if the rest of you have these settings turned on... if my assumption is correct, the FPS in SketchUp comes more from the CPU than the video card.
                                Baz, do you have hardware acceleration on?
                                By: Kristoff Rand
                                • bazB Offline
                                  baz
                                  Hi Kris, yes h/ware acceleration is on. Also I never touch the card properties, I choose 'let the application decide'. I have no idea why it's showing 8 cores. And yes the card is budget.
                                  baz
                                  • jarynzlesaJ Offline
                                    jarynzlesa
                                    I think I am a winner 😄 .
                                    http://www.vizualizaceschodiste.mypage.cz/
                                    • bazB Offline
                                      baz
                                      That was with shadows off? It looks like it.
                                      In Australia we'd probly call you 'a battler' 😄
                                      Which is a good thing, but it means you are doing it hard.
                                      Re: your avatar, which I've only just noticed... "mieowww". ☀
                                      baz
                                      • bazB Offline
                                        baz
                                        While we are at it, shall we try this test as well?
                                        This topic, http://forums.sketchucation.com/viewtopic.php?p=18909#p18909 gets into it.
                                        But basically its an expotential increase in entities and materials thru scenes 1 to 11.
                                        The referenced post reports wireframing at varied scenes and 'choppiness' when orbiting.
                                        This 4yo lappie cuts grass on the animation but it wireframed on scene 7 in orbit or hand. So I reckon it needs another 13 scenes to give it a real whirl. (I just tried to add scene 12 with a doubling of those lost people but SU has frozen).
                                        (still frozen).
                                        This test seems a bit subjective, for example, wireframing when orbiting is dependent on mouse speed, but p'raps someone could come up with an empirical test.
                                        I guess I'm interested in 'Best performance' settings.
                                        Screen shot at Scene 11.
                                        Open and 'PLAY ANIMATION' in scene tabs. Also 'orbit' in tabs.
                                        • brodieB Offline
                                          brodie
                                          I wonder if the behavior I'm seeing in the speed test model is the same as what anyone else getting...
                                          If I open the model and run the test a few times, I get around 25fps.
                                          Then I turn on shadows and get around 62fps.
                                          Then I turn off shadows and get around 62fps.
                                          Anyone else see this? Maybe this has something to do with SU 8? With shadows on when I run the ruby it basically turns the shadows off and zooms around it's orbit and then pops them back on. The even weirder thing though is when I turn the shadows back off, so it's in the same state as it was originally and the fps goes from 25 up to 62.
                                          [computer specs are in my signature below]
                                          -Brodie
                                            Krisidious
                                            yes Brodie... after retesting I get the same results... my jump to 63 frames was not the 3D settings config... it was shadows on and off.
                                            By: Kristoff Rand
                                            • 6
                                            • 7
                                            • 5 / 7
