    Let's have a Hardware speed test for SU
    132 Posts 72 Posters 98.9k Views 72 Watching
      SnowTiger
      I hate to say it.. but I will.
      I seem to be "smoking" all you fellers.
      Here's my score.
      BTW - I am running Vista Ultimate with 4 Gigs Ram and 2x (PCIE SLI) Nvidea 8800GT's
      "EDIT" .. I guess I haven't "smoked" everyone. I didn't notice there are 6 pages to this Thread ..... DOH !
        SnowTiger
        And this is with Shadows ON
        PS> Sorry I don't know how to post multiple images in the same Reply Post. !!!
          You just add another one...
          BTW Chris; you must have given some wrong email address the other day as it was returned to me...
            glenn
            Hey,
            Anyone try this test with SU8 yet?
            I"m interested to see speed compared to 7.1
            Thanks,
            Glenn
            • bmikeB Offline
              bmike
              @glenn said:
              Hey,
              Thanks,
              Glenn
              tried. does not work, get an argument error.
              looks like the file / code will need to tweak.
                pmolsen
                Ran it successfully on SU7.1 and SU8. Medion akoya MD97310 (from Aldi). 15.4 fps on SU7.1. 27.6 fps on SU8.
                • N Offline
                  naikrovek
                  SketchUp 8:
                  Not bad for a $500 PC and $50 video card.
                  • Wo3DanW Offline
                    Wo3Dan
                    How come my old dusty machine is performing rather well? / what am I doing "wrong"?
                    (PC=5.5 years of age, almost retired)
                    Micromaxx/Medion
                    AMD Athlon 64/3000+
                    Clockspeed 2.00GHz 1.5GB
                    NVIDIA GeForce FX5700
                    With SU8 pro (didn't test SU7) and testing the original file:
                    1. nothing changed (hidden geometry and shadows off) => around ~62.7 frames/second
                      (shadows on didn't seem to matter that much, same results => ~62.5 frames/second)
                      2)edges+profiles on, hidden geometry (and shadows) displayed => ~35.8 frames/second
                    ~ indicates that I did run the code line multiple times.
                    After changes to settings like 'hidden geometry' only the first run drops down frame rate.
                    After that a constant higher rate as stated above.
                    • fuzzionF Offline
                      fuzzion
                      To lazy to cut n paste.
                      72 frames displayed in 3.963sev
                      Avg. frames = 0.055 seconds
                      18.3 frames/sec
                      System spec
                      2 year old FX gateway laptop
                      64bit VIsta
                      6gb 1066mhz dual chan ram
                      centrino 2, dual core 2.33ghz , not sure about fsb
                      9800 GTS 1GB Nvidia card
                      Intel Chipset
                      "Only the dead have seen the end of war" - Plato
                        mac1
                        wo3dan
                        So much for all the hype about new machines. Are you running on a AGP_ bus also? Try toggling the transparency select on the face styles and see if it makes much difference. It did for me
                        fussion
                        It appears you are running too slow for these test conditions. Do you have problems with model display?? Suggest you run the GLview 322.exe and see what type of OpenGL you really have. Also toggle the transparency on the face styles and see if that makes any difference for you. My testing showed the extents of the model play a roll. Make sure to hit zoom extents before running test
                        • jujuJ Offline
                          juju
                          SU 8.0.4811
                          • KrisidiousK Offline
                            Krisidious
                            mine... I'm depressed, although I do have 4 monitors.
                            By: Kristoff Rand
                              bentleykfrog
                              Wow, some unusual results here. I've had some discrepancy between Sketchup v.8.0.4811 and Sketchup v.7.1.6860
                              Under v.7.1.6860 I got:
                              Sketchup 7.1.6860 test result
                              But under v.8.0.4811 I got:
                              Sketchup 8.0.4811 test result
                              After some troubleshooting, I found that disabling "Enable Transparency" in the Styles window gave this result in v.8.0.4811:
                              Sketchup 8.0.4811 (No Transparency) test result
                              Its unusual, I disabled "Enable Transparency" under 7.1.6860 and there was no noticable difference in the animations performance, but this is different for 8.0.4811. I'm not sure what is going on here but for consistency in results I think the style in the file should be updated to disable the transparency.
                              Here's my stats:
                              Mac Pro (1,1) with a modified 8 core x5355 @ 2.66 GHz (2 processors)
                              16gb DDR2 ECC ram
                              Ati Radeon HD 5770 (apple version)
                              SATA II
                              Windows 7 Ultimate 64bit
                                Masta Squidge
                                since i like this kind of stuff...
                                Q6600 quad core @ 3.2 GHZ.
                                EVGA GTX465SC core unlocked to 448 cores and overclocked 10%
                                No shadows:
                                Shadows:
                                  masrulpilami
                                  does anyone know how to test it in SU8?=D
                                    Exactly the same as in SketchUp 7
                                      Krisidious
                                      new upgrade... I5 2500k with 2 GTX 470s
                                      1 gtx 470
                                      2 gtx 470 running sli
                                      stats
                                      By: Kristoff Rand
                                      • bazB Offline
                                        baz
                                        New puter. I think the graphics card is letting me down cos results are similiar to older machines.
                                          Krisidious
                                          well baz that perplexed me. becuase if I'm not mistaken the GeForce 210 is a rather low end card right? like $50.00? and your score is smoking mine. so I figuired it had to be the I7 2600... but I'm running the I52500k unlocked at like 4.8ghz... although you seem to have 8 cores... you'll have to inform me on how that is? but anyway. I went into the nvidia control panel under 3D settings and turned everything up on the global settings...
                                          this improved my score by 100%
                                          I would be interested to know if the rest of you have these settings turned on... if my assumption is correct, the FPS in SketchUp comes more from the CPU than the video card.
                                          Baz, do you have hardware acceleration on?
                                          By: Kristoff Rand
                                          • bazB Offline
                                            baz
                                            Hi Kris, yes h/ware acceleration is on. Also I never touch the card properties, I choose 'let the application decide'. I have no idea why it's showing 8 cores. And yes the card is budget.
                                            baz
                                            • 5 / 7
