    Let's have a Hardware speed test for SU
    132 Posts 72 Posters 90.3k Views 72 Watching
      I got new Notebook so here's the results
      • jeff hammondJ Offline
        jeff hammond
        @wacov said:
        :shock:
        Does SU run better on Macs? Or is it your RAM? Because... 150 fps... ? Wow...
        i'm not sure because i've never used windows for comparison.. there was an export test around here a while ago in which the macs were able to export jpgs at more than twice the size as windows but other than that, i haven't seen anything alluding to SU being better with OS X..
        in fact, there are often things i see that work on PCs that i can't do.
        dotdotdot
        • F Offline
          francois le francais
          MY CONFIG : macbook pro - mid 2009 unibody 15" 4GbRam 512Mo 9600MGT HD500gb 5400rpm - snow leopard 10.6.1
          I ve run the cube test with each graphic configuration on the same machine running sketchup pro 7.0, and results are quite surprising :
          9400M : 5.336s - 27.4665s (shadows on) -- with SU7.1= 1.228 - 1.229(shadows on)
          9600M GT : 5.327s - 27,669s (shadows on) --with SU7.1= 1.324 - 1.225(shadows on)
          I've run the same test with my architecture diploma file (40000m2 hotel+parking+many cars+trees and textures = 4mb files)
          9400M : 6.572s - 99.579s (shadows on) --with SU7.1= 4.774 - 5.074(shadows on)
          9600M GT : 6.601s - 101.156s (shadows on) --with SU7.1= 5.034 -5.225(shadows on)
          That confirms my impression, I can't notice any difference between running sketchup with 9400 and with 9600. 😞 What do u think about that ? Could some mac users confirm these results ?
          And 7.1pro version is really impressive. 😍
          related link (hardware recommendation) :
          http://forums.sketchucation.com/viewtopic.php?f=15&t=10750&st=0&sk=t&sd=a&start=285
          • P Offline
            Pete
            Here are results form Macbook Pro 13"
            Strangely, I was getting 15-16 fps then I turned on shadows and it increased??
            • AnssiA Offline
              Anssi
              My results, first test with no shadows
              This one with shadows on
              • core i7-860, 2.8GHz
              • 8 GB memory
              • Nvidia QuadroFX 1800 graphics card with 768 Mb memory
              • 1080 x 1920 screen, SU maximized
              • Windows 7 Pro 64-bit
              • pyrolunaP Offline
                pyroluna
                sweet...
                and the GPU is an NVidia Quadro FX 770M... is that any good? πŸ˜†
                oh and with shadows off, the time was 1.141. Average frame=0.016 sec., 63.1 fr/s
                  joppermann
                  Ok. Not sure how to do screen shots but I will just give you the info.
                  Without shadows.
                  72 frames displayed in 3.420 seconds
                  average frame = 0.047 seconds
                  21.1 frames/second
                  With shadows.
                  72 frames displayed in 1.373 seconds
                  average frame = 0.019 seconds
                  52.5 frames/second
                  AMD phenom II x4 black edition 3.0ghz
                  8 gigs DDR2
                  ATI HD4850 1024
                  1920x1080
                  win 7 64 home prem
                  • V Offline
                    Vicspa
                    • U Offline
                      Ultimatez 32
                      Here's the results using my new laptop πŸ˜„
                      ultimatez
                      Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                      • jim smithJ Offline
                        jim smith
                        Toshiba A300 Satellite, 2 years old dual core intel, 3 gig ram, 32 bit windows 7, ATI mobility card
                        "Out of clutter find simplicity,
                        from discord find harmony,
                        In the middle of difficulty lies opportunity"
                        Albert Einstein
                        • bmikeB Offline
                          bmike
                          Dell M6400 with NVIDIA Quadro FX2700.
                          Stats went up after I went into the NVIDIA control panel and changed the 3d settings to 'Let Application Control' or somesuch.
                          mike beganyi design + consulting llc
                            red44
                            Anyone got a new Mac Pro to test?
                              red44
                              New Imac 27 inch as spec'ed here http://store.apple.com/nz/configure/MB953X/A?mco=MTM3NjczMzI with 8Gb Ram & i7 processor. Running SU 7.1 on Snow Leopard.
                              Shadows on - (47-53*) frames per second
                              Shadows off - 22 frames per second**
                              compared to old G5 PPC Dual 2.3Ghz, with 2.5Gb RAM NVidia GeForce 6600 GPU
                              Shadows on - 30 frames per second
                              Shadows off - 14.6 frames per second
                              and 1st gen Macbook Pro - (ATI Radeon X1600 2Ghz Intel Core Duo, 2Gb Ram Leopard, SU 7.1)
                              Shadows on - 27.3 frames per second
                              Shadows off - 9.2 frames per second
                              Pretty impressive improvement I guess, but can't help wondering what the Mac Pro might be capable of... No software/OpenGL issues yet to report but will post back if I find any....
                              *Is SU caching something here? Upon repeated testing I'm getting different results (shadows on = same as shadows off & frame rate increases to 53), even after closing SU and reopening Test file... Am I missing something here?
                              **The results on the Imac back up Jopperman's results with similarly spec'ed Graphics card (512Mb difference on GPU) and RAM but on a different operating system and other hardware specifically CPU...
                              • BoxB Offline
                                For reference I just tested my Asus Eeepc running XP and SU7.1.
                                The test shows it is pretty slow but it all works if you want something portable..
                                http://i155.photobucket.com/albums/s296/storeben/SU/Test.jpg
                                I've opened two very high poly models, and they certainly orbit and zoom quite happily, I imagine any work on them would take forever though.
                                  SnowTiger
                                  It appears I don't know how to get both images to upload in the same post ... so here's the other one.
                                    SnowTiger
                                    I hate to say it.. but I will.
                                    I seem to be "smoking" all you fellers.
                                    Here's my score.
                                    BTW - I am running Vista Ultimate with 4 Gigs Ram and 2x (PCIE SLI) Nvidea 8800GT's
                                    "EDIT" .. I guess I haven't "smoked" everyone. I didn't notice there are 6 pages to this Thread ..... DOH !
                                      SnowTiger
                                      And this is with Shadows ON
                                      PS> Sorry I don't know how to post multiple images in the same Reply Post. !!!
                                        You just add another one...
                                        BTW Chris; you must have given some wrong email address the other day as it was returned to me...
                                        • G Offline
                                          glenn
                                          Hey,
                                          Anyone try this test with SU8 yet?
                                          I"m interested to see speed compared to 7.1
                                          Thanks,
                                          Glenn
                                          • bmikeB Offline
                                            bmike
                                            @glenn said:
                                            Hey,
                                            Thanks,
                                            Glenn
                                            tried. does not work, get an argument error.
                                            looks like the file / code will need to tweak.
                                            • 6
                                            • 7
                                            • 4 / 7
