    Let's have a Hardware speed test for SU
    132 Posts 72 Posters 105.4k Views 72 Watching
    • bazB
      baz
      [/quote]
      Now, on SU7.1, using the same setup (At a higher resolution):
      That's a massive difference!
      The message? Get 7.1. NOW.[/quote]
      I got the message, wow!
      Baz
      shad off V7.0
      shad off, V7.1
      • G
        glenn
        Interesting test results:
        XP sp3, duo 2.8, 4gb ram, 8500gt 512mb
        Ran it with SU7.1, then saved it as SU6 and ran it with v6.4
        Glenn
        • G
          glenn
          hmmmm...I can't upload multiple images?
          ok, got it, sorry.
          • brodieB
            brodie
            I got 21.1 fps with shadows off.
            Computer specs are in my signature below
            -Brodie
            • GaieusG
              Glenn,
              Now that's some impressive speed increase (of course, there areno textures in the model and such but still)
              Brodie;
              OK-ok... there are your computer specs but we don't know (just suspect maybe) what SU version you have!
              • jeff hammondJ
                i didn't run this pre su7.1 but i'm willing to assume a huge difference since upgrading...
                with an older quad mac..
                with shadow ON:
                shadows OFF:
                • W
                  Wacov
                  Does SU run better on Macs? Or is it your RAM? Because... 150 fps... ? Wow...
                  • U
                    Ultimatez 32
                    Here's something odd.....I tried the test on 2 models, one the test model and the other one my roller coaster model. Here's the result.....quite suprising:
                    coaster model
                    test model
                    The picture below shows my computer stats...... πŸ˜•
                    It's a laptop by the way
                    Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                    • GaieusG
                      How about the video card and OpenGL hardware support ("acceleration" in Preferences > OpenGL)?
                        I got new Notebook so here's the results
                        • jeff hammondJ
                          @wacov said:
                          :shock:
                          i'm not sure because i've never used windows for comparison.. there was an export test around here a while ago in which the macs were able to export jpgs at more than twice the size as windows but other than that, i haven't seen anything alluding to SU being better with OS X..
                          in fact, there are often things i see that work on PCs that i can't do.
                          • F
                            francois le francais
                            MY CONFIG : macbook pro - mid 2009 unibody 15" 4GbRam 512Mo 9600MGT HD500gb 5400rpm - snow leopard 10.6.1
                            I ve run the cube test with each graphic configuration on the same machine running sketchup pro 7.0, and results are quite surprising :
                            9400M : 5.336s - 27.4665s (shadows on) -- with SU7.1= 1.228 - 1.229(shadows on)
                            9600M GT : 5.327s - 27,669s (shadows on) --with SU7.1= 1.324 - 1.225(shadows on)
                            I've run the same test with my architecture diploma file (40000m2 hotel+parking+many cars+trees and textures = 4mb files)
                            9400M : 6.572s - 99.579s (shadows on) --with SU7.1= 4.774 - 5.074(shadows on)
                            9600M GT : 6.601s - 101.156s (shadows on) --with SU7.1= 5.034 -5.225(shadows on)
                            That confirms my impression, I can't notice any difference between running sketchup with 9400 and with 9600. 😞 What do u think about that ? Could some mac users confirm these results ?
                            And 7.1pro version is really impressive. 😍
                            related link (hardware recommendation) :
                            http://forums.sketchucation.com/viewtopic.php?f=15&t=10750&st=0&sk=t&sd=a&start=285
                            • P
                              Pete
                              Here are results form Macbook Pro 13"
                              Strangely, I was getting 15-16 fps then I turned on shadows and it increased??
                              • AnssiA
                                Anssi
                                My results, first test with no shadows
                                This one with shadows on
                                • core i7-860, 2.8GHz
                                • 8 GB memory
                                • Nvidia QuadroFX 1800 graphics card with 768 Mb memory
                                • 1080 x 1920 screen, SU maximized
                                • Windows 7 Pro 64-bit
                                • pyrolunaP
                                  pyroluna
                                  sweet...
                                  and the GPU is an NVidia Quadro FX 770M... is that any good? πŸ˜†
                                  oh and with shadows off, the time was 1.141. Average frame=0.016 sec., 63.1 fr/s
                                    joppermann
                                    Ok. Not sure how to do screen shots but I will just give you the info.
                                    Without shadows.
                                    72 frames displayed in 3.420 seconds
                                    average frame = 0.047 seconds
                                    21.1 frames/second
                                    With shadows.
                                    72 frames displayed in 1.373 seconds
                                    average frame = 0.019 seconds
                                    52.5 frames/second
                                    AMD phenom II x4 black edition 3.0ghz
                                    8 gigs DDR2
                                    ATI HD4850 1024
                                    1920x1080
                                    win 7 64 home prem
                                    • V
                                      Vicspa
                                      • U
                                        Ultimatez 32
                                        Here's the results using my new laptop πŸ˜„
                                        ultimatez
                                        • jim smithJ
                                          jim smith
                                          Toshiba A300 Satellite, 2 years old dual core intel, 3 gig ram, 32 bit windows 7, ATI mobility card
                                          "Out of clutter find simplicity,
                                          from discord find harmony,
                                          In the middle of difficulty lies opportunity"
                                          Albert Einstein
                                          • bmikeB
                                            bmike
                                            Dell M6400 with NVIDIA Quadro FX2700.
                                            Stats went up after I went into the NVIDIA control panel and changed the 3d settings to 'Let Application Control' or somesuch.
                                            • 4 / 7
