    🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    Processing language :for artists, architects...
    16 Posts 8 Posters 1.1k Views 8 Watching
      Processing ! 😎
      and "Open Source" so you can use any works, modify,...etc drawing, 3D, Images, sound, videos, interaction! ☀
      Processing is an open source programming language and environment for people who want to program images, animation, and interactions. It is used by students, artists, designers, researchers, and hobbyists for learning, prototyping, and production. It is created to teach fundamentals of computer programming within a visual context and to serve as a software sketchbook and professional production tool. Processing is an alternative to proprietary software tools in the same domain.
      Of course it's better if you know to program but it's very easy against other languages!
      Truly amazing 😮
      For example this guy Jared Tarbell explore complexity 😲 (scroll many videos inside)
      http://www.complexification.net/gallery/machines/substrate/substrate3001.jpg
        Tim Danaher
        Hah! Pilou,
        I'm actually translating a book about the CAAD department at the ETH, Zürich and their use of a Processing-based program in developing urban design strategies... fascinating stuff.
        Cheers,
        Tim
        http://vizarch.blogspot.com
        • mitcorbM Offline
          mitcorb
          Pilou:
          I could not get the Java applets to proceed. And, I have the latest Java updates.
          mitcorb
          • tbdT Offline
            tbd
            you can try also Processing for Javascript so you can play inside your browser with no additional plugins required - http://processingjs.org/exhibition
            ps. dont try in IE 😉
            SketchUp Ruby Consultant | Podium 1.x developer
            http://plugins.ro
              linea
              Can anybody elaborate a bit more on what this is / does?
                cornel
                😒 Using “Processing” or similar, for Antichrist (ultra-expert in IT) it's very easy to “give breath to the image of the beast”! (See Revelation 13:15)
                Cornel
                  In fact with "Processing" you can mix any supports(drawings 2d, 3D, images, sounds, videos, texts, interactions users) and control all the process!
                  You can explore any research domains following your imagination!
                  Free and participative as code yet created is free access for anybody!
                  The only little problem is that you must learn and write a language for assemble old codes or your news lines!
                  (but more easy than all others existing )
                  Have fun with it! ☀
                  here many videos of possibilities
                  You will be surprise by the diversity of applications 😄
                  • Chris FullmerC Offline
                    That is incorrect.
                    All my Plugins I've written
                      cornel
                      Chris,
                      that is a technical possibility.
                      Spiritual, it's much more easier... to realize such 'performance' 😮
                        linea
                        hmmm the reply was more theosophical than I expected Cornel but each to their own. Can somebody just tell me what it does is simple terms? I figure it requires programming skills related so I'll probably have no use for it but it would be nice to know.
                          So look this (without interaction), or this (with interaction)
                          And you have source, so you will have a view of the language
                          Similar than basic not more no less 😉
                          More examples (java P5)on the site
                          PS And why not read "the Welcome to Processing" by the Authors? 😒 Interresting even you will don't program 😄
                          Seems better than all I can tell 💚
                          Don't start by trying to build a cathedral
                          sure 😄
                            for example
                            here the video
                            here the prog online
                            here the code
                              @Mitcorb
                              I don't know what to say 😳 (I have not the last version of Java and all works fine for me 😉
                              If you have Windows
                              I believe that better is to load version "Windows + Java" even Java is yet installed inside your computer 🤓
                              Hope this help 😒
                              @Tim
                              This prog is amazing : you can find any sort of visual + sounds + interactions 😮
                              This site gives a thousand of it! + source code ☀
                                Its parametric art. The programmer writes parameters that define how the art will form itself. The example image Pilou put up is from my favorite aplet. Its beautiful to watch it unfold. There are some other great ones on the complexification site. I like his style. I first found the site about 5 years ago and I've always wanted to make one since. I've tried a few times in SU w/Ruby with no luck. Maybe its time to try again now that I can do a little more with Ruby.
                                Chris
                                  Cool examples functions (explore Horizontal and vertical menus)
                                  All animated or mouse reactive mode
                                    monk77
                                    Processing ! 😎
                                    Thank you for your suggestion. This is a really funny tool. Today I draw my new website-logo (a simple bee) with processing.
                                    http://img232.imageshack.us/img232/9461/youtubeg.png
                                    It's very interesting to learn coding with a tool like this. I guess, I will order the book of Ira Greenberg about processing.
                                    It is similar to Adobe Macromedia Flash. Also a great feature is adding OpenGL-Libraries. This makes scenes and animations very smooth.
                                    Cheers
                                    monk77
                                    my sketchup-animations
