    Processing language :for artists, architects...
    16 Posts 8 Posters 1.9k Views 8 Watching
      linea
      Can anybody elaborate a bit more on what this is / does?
        cornel
        ๐Ÿ˜’ Using โ€œProcessingโ€ or similar, for Antichrist (ultra-expert in IT) it's very easy to โ€œgive breath to the image of the beastโ€! (See Revelation 13:15)
        Cornel
          In fact with "Processing" you can mix any supports(drawings 2d, 3D, images, sounds, videos, texts, interactions users) and control all the process!
          You can explore any research domains following your imagination!
          Free and participative as code yet created is free access for anybody!
          The only little problem is that you must learn and write a language for assemble old codes or your news lines!
          (but more easy than all others existing )
          Have fun with it! โ˜€
          here many videos of possibilities
          You will be surprise by the diversity of applications ๐Ÿ˜„
          • Chris FullmerC Offline
            That is incorrect.
              cornel
              Chris,
              that is a technical possibility.
              Spiritual, it's much more easier... to realize such 'performance' ๐Ÿ˜ฎ
                linea
                hmmm the reply was more theosophical than I expected Cornel but each to their own. Can somebody just tell me what it does is simple terms? I figure it requires programming skills related so I'll probably have no use for it but it would be nice to know.
                  So look this (without interaction), or this (with interaction)
                  And you have source, so you will have a view of the language
                  Similar than basic not more no less ๐Ÿ˜‰
                  More examples (java P5)on the site
                  PS And why not read "the Welcome to Processing" by the Authors? ๐Ÿ˜’ Interresting even you will don't program ๐Ÿ˜„
                  Seems better than all I can tell ๐Ÿ’š
                  Don't start by trying to build a cathedral
                  sure ๐Ÿ˜„
                    for example
                    here the video
                    here the prog online
                    here the code
                      @Mitcorb
                      I don't know what to say ๐Ÿ˜ณ (I have not the last version of Java and all works fine for me ๐Ÿ˜‰
                      If you have Windows
                      I believe that better is to load version "Windows + Java" even Java is yet installed inside your computer ๐Ÿค“
                      Hope this help ๐Ÿ˜’
                      @Tim
                      This prog is amazing : you can find any sort of visual + sounds + interactions ๐Ÿ˜ฎ
                      This site gives a thousand of it! + source code โ˜€
                        Its parametric art. The programmer writes parameters that define how the art will form itself. The example image Pilou put up is from my favorite aplet. Its beautiful to watch it unfold. There are some other great ones on the complexification site. I like his style. I first found the site about 5 years ago and I've always wanted to make one since. I've tried a few times in SU w/Ruby with no luck. Maybe its time to try again now that I can do a little more with Ruby.
                          Cool examples functions (explore Horizontal and vertical menus)
                          All animated or mouse reactive mode
                            monk77
                            Processing ! ๐Ÿ˜Ž
                            and "Open Source" so you can use any works, modify,...etc drawing, 3D, Images, sound, videos, interaction! โ˜€
                            Thank you for your suggestion. This is a really funny tool. Today I draw my new website-logo (a simple bee) with processing.
                            http://img232.imageshack.us/img232/9461/youtubeg.png
                            It's very interesting to learn coding with a tool like this. I guess, I will order the book of Ira Greenberg about processing.
                            It is similar to Adobe Macromedia Flash. Also a great feature is adding OpenGL-Libraries. This makes scenes and animations very smooth.
                            Cheers
                            monk77
                            my sketchup-animations
