    Processing language :for artists, architects...
    16 Posts 8 Posters 2.0k Views 8 Watching
    • tbdT
      tbd
      you can try also Processing for Javascript so you can play inside your browser with no additional plugins required - http://processingjs.org/exhibition
      ps. dont try in IE ๐Ÿ˜‰
      http://plugins.ro
      • L
        linea
        Can anybody elaborate a bit more on what this is / does?
        • C
          cornel
          ๐Ÿ˜’ Using โ€œProcessingโ€ or similar, for Antichrist (ultra-expert in IT) it's very easy to โ€œgive breath to the image of the beastโ€! (See Revelation 13:15)
          Cornel
            In fact with "Processing" you can mix any supports(drawings 2d, 3D, images, sounds, videos, texts, interactions users) and control all the process!
            You can explore any research domains following your imagination!
            Free and participative as code yet created is free access for anybody!
            The only little problem is that you must learn and write a language for assemble old codes or your news lines!
            (but more easy than all others existing )
            Have fun with it! โ˜€
            here many videos of possibilities
            You will be surprise by the diversity of applications ๐Ÿ˜„
            • Chris FullmerC
              That is incorrect.
              • C
                cornel
                Chris,
                that is a technical possibility.
                Spiritual, it's much more easier... to realize such 'performance' ๐Ÿ˜ฎ
                • L
                  linea
                  hmmm the reply was more theosophical than I expected Cornel but each to their own. Can somebody just tell me what it does is simple terms? I figure it requires programming skills related so I'll probably have no use for it but it would be nice to know.
                    So look this (without interaction), or this (with interaction)
                    And you have source, so you will have a view of the language
                    Similar than basic not more no less ๐Ÿ˜‰
                    More examples (java P5)on the site
                    PS And why not read "the Welcome to Processing" by the Authors? ๐Ÿ˜’ Interresting even you will don't program ๐Ÿ˜„
                    Seems better than all I can tell ๐Ÿ’š
                    Don't start by trying to build a cathedral
                    sure ๐Ÿ˜„
                      for example
                      here the video
                      here the prog online
                      here the code
                        @Mitcorb
                        I don't know what to say ๐Ÿ˜ณ (I have not the last version of Java and all works fine for me ๐Ÿ˜‰
                        If you have Windows
                        I believe that better is to load version "Windows + Java" even Java is yet installed inside your computer ๐Ÿค“
                        Hope this help ๐Ÿ˜’
                        @Tim
                        This prog is amazing : you can find any sort of visual + sounds + interactions ๐Ÿ˜ฎ
                        This site gives a thousand of it! + source code โ˜€
                        • Chris FullmerC
                          Its parametric art. The programmer writes parameters that define how the art will form itself. The example image Pilou put up is from my favorite aplet. Its beautiful to watch it unfold. There are some other great ones on the complexification site. I like his style. I first found the site about 5 years ago and I've always wanted to make one since. I've tried a few times in SU w/Ruby with no luck. Maybe its time to try again now that I can do a little more with Ruby.
                            Cool examples functions (explore Horizontal and vertical menus)
                            All animated or mouse reactive mode
                              monk77
                              Processing ! ๐Ÿ˜Ž
                              and "Open Source" so you can use any works, modify,...etc drawing, 3D, Images, sound, videos, interaction! โ˜€
                              Thank you for your suggestion. This is a really funny tool. Today I draw my new website-logo (a simple bee) with processing.
                              http://img232.imageshack.us/img232/9461/youtubeg.png
                              It's very interesting to learn coding with a tool like this. I guess, I will order the book of Ira Greenberg about processing.
                              It is similar to Adobe Macromedia Flash. Also a great feature is adding OpenGL-Libraries. This makes scenes and animations very smooth.
                              Cheers
                              monk77
                              my sketchup-animations
