    Flip issue
    10 Posts 5 Posters 924 Views 5 Watching
      anglaret
      Hello
      I have a little problem when I flip doors I have drawn in 2d drawings
      The curve remain apparent after flipping the object.
      Thank you for any advice
        lucifer1101
        make it a group then flip it, then delete the original then explode it...
        Some of my 3d
          anglaret
          thanks lucifer
          That does not make the job, but thank you; don't worry I will go on making my actual process: flip, then delete the remaining arc, then eventually rebuilt the erased area of the room.
          Marc
            mac1
            @anglaret said:
            Hello
            Marc[attachment=0:1ute8b4z]<!-- ia0 -->flip.JPG<!-- ia0 -->[/attachment:1ute8b4z]
            anglaret:
            Could not duplicate your problem using SU-6 & 7 free. Downloaded your jpg to SU then traced your geometry and then hid the jpg and things looked fine. The only way I could make it look like your case was to not hide the jpg then one can see both. Is there something amiss with how your are using the 2 d drawing your created in I assume different than SU??
            Just a thought: Also try turning hardware accel fast feed back off and and see if you get a different result.
              anglaret
              mic
              thanks for advice but acceleration does not change anything
              To re-create, put the object to flip inbetween walls
              The object alone flip OK
              See the image
              Marc
              • jim smithJ Offline
                jim smith
                anglaret,
                Maybe this will help. Use the mirror plugin instead of flipping.
                select the door and swing arc.
                click the mirror plugin
                click the midpoint of the line between swing and door
                use inference to draw a vertical and click enter
                click yes when it asks to erase original
                I have attached a small "jing" movie of the process. Never posted a "Jing" before so I hope it attaches and plays.
                2009-06-05_1843.swf
                "Out of clutter find simplicity,
                from discord find harmony,
                In the middle of difficulty lies opportunity"
                Albert Einstein
                  jim smith
                  anglaret,
                  Sorry - This doesn't seem to open. I need a tutorial on uploading the Jing files!!
                  Albert Einstein
                    Seeing that this is a door symbol - and that it's something that most likely is needed many places: why not make it into a component? then you can reuse it menu times and flip without any problems.
                      anglaret
                      thanks tomtom
                      I suppose you are right, but a component does not brake an area betwen 2 rooms (to change floors coverings for example)
                      I suppose I will go on with that thing
                      Marc
                        You could leave a line to separate the rooms. That's how I would do it.
