    Sometimes push/pull tool doesnt work
    20 Posts 7 Posters 1.3k Views 7 Watching
      donaldaugustsson
      I problem with the push/pupp-tool... and some other like scale. Sometimes they doesnt work!! Usally they work if you change the angle of view or pan around... but with some surfaces it never work!
      i´m just playing around with a model and the areas in the red rectangles cant be changed...for exampel
      thank in advance! ...and sorry for my bad english 😉
        remus
        I think the problem your referring to is to do with the geometry adjacent to the face you want to push/pull. You can usually solve this simply by grouping the face you want to push, pushing it and then exploding the group.
          donaldaugustsson
          Thanks you but it doesnt seem to work anyway 😞 Doh!
          This problem is on another model so maybe it can be another problem? ...but the tool seem a little bit randomly!! Annoying!
          btw, i really like your rendering! Do you have more information about which renderingengines you use, because you used several?
            lucifer1101
            you could always try pressing ctrl while using the push pull tool, it works for me when the geometry forbds the push pull....
            Some of my 3d
              Post the skp file of your no "Push Pull" volume 😉
                donaldaugustsson
                Here are the latest model that i played aorund with... i must do something wrong 😄
                testmodellen push pull tool.skp
                • ely862meE Offline
                  ely862me
                  what is ,actually,the problem? what areas u want to push/pull?
                  they work for me..
                  Elisei (sketchupper)
                  Come and See EliseiDesign
                    Then all will works fine ☀ ;
                      SFX Group
                      Ive noticed this, one thing i found (50%) of the time is the angle you are looking at that face, it seems the mouse sometimes needs to point at the connecting EDGE of that face to allow you to push or pull it, however i am sure there is 1 face you cant push or pull, and thats the ORGINAL face you created then pulled it from there.... Just my guess but i bet i'm right.
                      Many Thanks
                      Many Thanks
                      Ashley
                      © Copyright 2014 - http://www.ashleygriffin.co.uk
                        SFX Group
                        I found another way to get around this..... instead of "push/pull" you can also "edit group" or "explode" and then select the WHOLE FACE and pull it to where you want with the MOVE/COPY, however you need to be carful as you can pull it anywhere unlike "push" which will only go in 2 directions (forward and back).
                        Still works though when you can push/pull. Only really good when your lining stuff up (like i do all the time) as it will snap to the surface (assuming you have those options to see in VIEW).
                        Many Thanks
                        Many Thanks
                        Ashley
                          donaldaugustsson
                          Wie! Thank you SFX Group! I love you 😉
                          I thought the angle could affect the tool but i never found out how it worked out... but now i know!
                          /Happy
                            SFX Group
                            There’s something else i have noticed, this "cant select a face to push pull", it seems may also be a openGL support issue.
                            I found if I turn off Hardware Acceleration in the preferences THEN i can select the face as i should be able to...
                            Looking at another graphics card that supports openGL better.
                            Many Thanks
                            Ashley
                            /Happy
                            Many Thanks
                            Ashley
                              donaldaugustsson
                              ok, i have ATI Radeon graphiccard and it have been alot of problem with that card... what card do you recommend, cause i am tired of a the problem
                                donaldaugustsson
                                ARGH! ... tried making some different models and after a while the push/pull-tool doesnt work on the existing objects. It only works if your doing a new box... and then you can use the tool one time...something is wrong with my computer, program or it might be just me...
                                  SFX Group
                                  Well at the moment, the Matrox G400 and G550 (both had openGL as would run Quake III, was going to put one of those in.
                                  I might give one a wizz in the test machine (VERY slow XP P3 box) as i have a few special BIOS TV G400 dual head cards to see how they get on, if it works well on there then will look at a G550 LP card (as i have 2U server size cases).
                                  Many Thanks
                                  Many Thanks
                                  Ashley
                                    SFX Group
                                    well this is a shock, Matrox G400 DUAL HEAD (although this has a special BIOS for TV output) it’s very slow (no Hardware Acceleration), the same machine with a NVIDIA GeForce T4 (old card) went like a rocket (has Hard Acceleration) in software.
                                    Its way quicker than my Core2DUO 2.4Ghz running XP64bit, this machine I tested it on is a P3 800Mhz.... so it’s all to do with graphics cards...
                                    Will keep you posted.
                                    Many Thanks
                                    Many Thanks
                                    Ashley
                                    • AnssiA Offline
                                      Anssi
                                      The last time I tried a Matrox card (I admit it was some years ago) with an OpenGL application I got a blue screen. They are best known for their 2D image quality but have not recently been mentioned as usable in 3D design.
                                      Anssi
                                        donaldaugustsson
                                        ... now it seems that i only can use the push/pulltool just one time with each object...
                                        now i starting to hate sketchup
                                          SFX Group
                                          I'm looking at a ASUS Nvidia card, there fairly cheap (US $30-40 on eBay), small price to pay for working kit...
                                          I do agree its abit of a downer but not much you can do about it if manufactures are not supporting certain programming systems (openGL).
                                          Many Thanks
                                          Many Thanks
                                          Ashley
                                            SFX Group
                                            UPDATE:
                                            Ive just bought a ASUS Nvidea EN9400GT (1Gb RAM), was cheap (UK £40), installed and working, has corrected my "selection" problem and is now super fast....
                                            I was on an Intel Board which that inbuilt unit was 512Mb RAM (so wasnt a slow unit) however seems to be all about the OpenGL componant of the graphics board.
                                            Many Thanks
                                            Many Thanks
                                            Ashley
