    Sometimes push/pull tool doesnt work
    20 Posts 7 Posters 1.9k Views 7 Watching
      SFX Group
      I found another way to get around this..... instead of "push/pull" you can also "edit group" or "explode" and then select the WHOLE FACE and pull it to where you want with the MOVE/COPY, however you need to be carful as you can pull it anywhere unlike "push" which will only go in 2 directions (forward and back).
      Still works though when you can push/pull. Only really good when your lining stuff up (like i do all the time) as it will snap to the surface (assuming you have those options to see in VIEW).
      Many Thanks
      Many Thanks
      Ashley
      © Copyright 2014 - http://www.ashleygriffin.co.uk
        donaldaugustsson
        Wie! Thank you SFX Group! I love you 😉
        I thought the angle could affect the tool but i never found out how it worked out... but now i know!
        /Happy
          SFX Group
          There’s something else i have noticed, this "cant select a face to push pull", it seems may also be a openGL support issue.
          I found if I turn off Hardware Acceleration in the preferences THEN i can select the face as i should be able to...
          Looking at another graphics card that supports openGL better.
          Many Thanks
          Ashley
          /Happy
          Many Thanks
          Ashley
            donaldaugustsson
            ok, i have ATI Radeon graphiccard and it have been alot of problem with that card... what card do you recommend, cause i am tired of a the problem
              donaldaugustsson
              ARGH! ... tried making some different models and after a while the push/pull-tool doesnt work on the existing objects. It only works if your doing a new box... and then you can use the tool one time...something is wrong with my computer, program or it might be just me...
                SFX Group
                Well at the moment, the Matrox G400 and G550 (both had openGL as would run Quake III, was going to put one of those in.
                I might give one a wizz in the test machine (VERY slow XP P3 box) as i have a few special BIOS TV G400 dual head cards to see how they get on, if it works well on there then will look at a G550 LP card (as i have 2U server size cases).
                Many Thanks
                Many Thanks
                Ashley
                  SFX Group
                  well this is a shock, Matrox G400 DUAL HEAD (although this has a special BIOS for TV output) it’s very slow (no Hardware Acceleration), the same machine with a NVIDIA GeForce T4 (old card) went like a rocket (has Hard Acceleration) in software.
                  Its way quicker than my Core2DUO 2.4Ghz running XP64bit, this machine I tested it on is a P3 800Mhz.... so it’s all to do with graphics cards...
                  Will keep you posted.
                  Many Thanks
                  Many Thanks
                  Ashley
                  • AnssiA Offline
                    Anssi
                    The last time I tried a Matrox card (I admit it was some years ago) with an OpenGL application I got a blue screen. They are best known for their 2D image quality but have not recently been mentioned as usable in 3D design.
                    Anssi
                      donaldaugustsson
                      ... now it seems that i only can use the push/pulltool just one time with each object...
                      now i starting to hate sketchup
                        SFX Group
                        I'm looking at a ASUS Nvidia card, there fairly cheap (US $30-40 on eBay), small price to pay for working kit...
                        I do agree its abit of a downer but not much you can do about it if manufactures are not supporting certain programming systems (openGL).
                        Many Thanks
                        Many Thanks
                        Ashley
                          SFX Group
                          UPDATE:
                          Ive just bought a ASUS Nvidea EN9400GT (1Gb RAM), was cheap (UK £40), installed and working, has corrected my "selection" problem and is now super fast....
                          I was on an Intel Board which that inbuilt unit was 512Mb RAM (so wasnt a slow unit) however seems to be all about the OpenGL componant of the graphics board.
                          Many Thanks
                          Many Thanks
                          Ashley
