    [Plugin] Exploded Arc Centerpoint Finder UPDATE May 23, 2013
    59 Posts 31 Posters 67.4k Views 31 Watching
    • Chris FullmerC Offline
      ok, now updated so that when it is used in group/component edit mode, it will add the construction point inside the group that is being edited. Thanks for pointing that out Thom.
      So re-download it from the first post in the thread.
      Chris
      All my Plugins I've written
        πŸ‘
          August
          Thanks Chris,
          I found this to be a very readable script for learning a little more Ruby. It's pretty clear from context what it's doing as far as finding a perpendicular direction, creating a temporary "z" from the original two edges, etc. I assume the ".cross" function is the Cross-product from vector algebra, which I vaguely remember, but I'll have to look up what that actually is and why it's called "cross".
          Thanks again,
          August
          β€œAn idea, like a ghost, must be spoken to a little before it will explain itself.”
          [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
          • K Offline
            kostas_designer
            i know it may seem stupid, but why can't i see the context "point at center" menu when i right-click on an arc? 😳
              You have to first enable the sketchup ruby script examples from Window > Preferences > Extensions > Ruyb Script Examples (or might be the one called Utilities tools). Enable them both, then you should get the point at center option.
              Chris
              • jeff hammondJ Offline
                jeff hammond
                Chris
                ha!
                i never knew this function came with SU.. i've been using jim f's arc_centerpoint.rb for a couple of years now.
                β˜€
                dotdotdot
                  Jim
                  Hehe, and I wrote that before I realized Point at Center came with SketchUp!
                  • K Offline
                    kostas_designer
                    Chris
                    ha!
                    β˜€
                    Me too, seems that the ways of SU are infinite! πŸ˜„
                    Thanks for the tip, Chris.
                    • boofredlayB Offline
                      boofredlay
                      I just wanted to thank you again for this Chris. It is a very useful tool. πŸ‘
                        Oh good, glad its helpful!
                        Chris
                        • bazB Offline
                          baz
                          Great tool, thanks Chris.
                          baz
                          • W Offline
                            watkins
                            Dear Chris,
                            I made a request a little time ago for an icon to go with this script. I use your centrepoint finder so often that an icon would be very useful (and yes, TIG, I know I could assign a shortcut...)
                            Many thanks,
                            Bob
                            • jamalitoJ Offline
                              jamalito
                              hello Chris thank for this Plugin but after I updated my SU8 to SU8m2 it was not work when I run in form plugin menu show to me this window I don't know what is meaning ?
                              note I removed it and instal it again but same problem 😒
                              Albert Einstein:
                              ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                              • mitcorbM Offline
                                mitcorb
                                Hi, jamalito:
                                It appears you have preselected a non exploded arc. Chris's plugin is for calculating a centerpoint of 2 or more unconnected or nonwelded segments. Use Sketchup's native Point at Center or Jim's Autocenterpoint.
                                • G Offline
                                  GM2013
                                  Had this very handy plugin installed previouslyu but I had to reintall Sketchup today.
                                  I tried installing via the Sketchucation plugin store but it didn't work so I manually placed it in the plugin folder and but doesn't appear in the plugins menu.
                                  Am I doing something wrong?
                                    Yes.
                                    You didn't actually install the plugin. files with the .rbz extension are intended to be installed via Install Extensions under Preferences>Extensions. Put the file back into your Downloads folder, or wherever it was downloaded to. Open Preferences and go to Extensions. Click on the Install Extension button, navigate to the file, choose it and open it. Most plugins will work after this install but it won't hurt to close SketchUp and reopen it.
                                    BTW, could you please complete your profile? Which version of SketchUp are you using?
                                    • TIGT Online
                                      Dave just beat me to it...
                                      BUT since I had typed this here's my equivalent text...
                                      You must be doing something wrong πŸ˜’
                                      Installs fine for me ???
                                      I assume you are on v8 or v2013 your User-Profile is incomplete...
                                      If it's v8 you need the latest version to be able to AutoInstall RBZ archives.
                                      If you have manually put the tool's RB file into the Plugins folder and restarted SketchUp then the tool should appear in the submenu Plugins > Chris Fullmers Tools...
                                      If it's not in there you haven't actually installed it right... πŸ˜•
                                      If it is, then it has loaded.
                                      Some common reasons:
                                      • You left it inside the RBZ - SketchUp only auto-loads RB/RBS files it finds within the Plugins folder as it starts...
                                      • You don't have Properties > Security permissions set to FULL, which allows you to add files to the Plugins folder.
                                        If so it might look like you added it but a 'Compatibility Files...' link/button in the top-bars of the Windows Explorer window for Plugins is a give-away that its actually in a VirtualStore - from where it won't load when SketchUp starts !
                                        Fix your permissions.
                                        Also set SketchUp.exe to always run as administrator in Properties > Compatibility...
                                      • N Offline
                                        ncas
                                        Is there a version for SU 8?
                                        • TIGT Online
                                          What makes you think it's not v8 compatible ?
                                          The previous post explained how to install it in v8 - but you do need the latest v8 version with the Preferences > Extensions > Install... button.
                                          If you don't have that, then get the latest v8 installer from here:
                                          http://help.sketchup.com/en/article/60107
                                          Note how version 8 will no longer be supported after 20 May 2015, so keep a copy of the downloaded installer !
                                          • 3 / 3
