    [Plugin] Exploded Arc Centerpoint Finder UPDATE May 23, 2013
    59 Posts 31 Posters 71.4k Views 31 Watching
    • Chris FullmerC Offline
      Great, thanks Christophe! I've updated the first post to also include a link to the French version.
      • jeff hammondJ Offline
        @chris fullmer said:
        Name: Arc Centerpoint Finder
        Version: v1.0
        wow! nice one.
        perfect little timesaver.
        thank you
          There's a wee bug. It adds the CPoint in model.entities instead of model.active_entities - so if you use this inside a group/component it's not added to the correct context.
            Panga
            Chris, you're a mind reader...I was looking for this function for a long time. Thanks for your help in our sketchup's lives !!
              Oh darn, there was a little while there where I think I forgot about .active_entities and just added everything to the .entities collection. I'll fix it and get it uploaded later today,
                ok, now updated so that when it is used in group/component edit mode, it will add the construction point inside the group that is being edited. Thanks for pointing that out Thom.
                So re-download it from the first post in the thread.
                  ๐Ÿ‘
                    August
                    Thanks Chris,
                    I found this to be a very readable script for learning a little more Ruby. It's pretty clear from context what it's doing as far as finding a perpendicular direction, creating a temporary "z" from the original two edges, etc. I assume the ".cross" function is the Cross-product from vector algebra, which I vaguely remember, but I'll have to look up what that actually is and why it's called "cross".
                    Thanks again,
                    August
                    โ€œAn idea, like a ghost, must be spoken to a little before it will explain itself.โ€
                    [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                      kostas_designer
                      i know it may seem stupid, but why can't i see the context "point at center" menu when i right-click on an arc? ๐Ÿ˜ณ
                        You have to first enable the sketchup ruby script examples from Window > Preferences > Extensions > Ruyb Script Examples (or might be the one called Utilities tools). Enable them both, then you should get the point at center option.
                          ha!
                          i never knew this function came with SU.. i've been using jim f's arc_centerpoint.rb for a couple of years now.
                          โ˜€
                            Jim
                            Hehe, and I wrote that before I realized Point at Center came with SketchUp!
                              kostas_designer
                              ha!
                              โ˜€
                              Me too, seems that the ways of SU are infinite! ๐Ÿ˜„
                              Thanks for the tip, Chris.
                              • boofredlayB Offline
                                boofredlay
                                I just wanted to thank you again for this Chris. It is a very useful tool. ๐Ÿ‘
                                  Oh good, glad its helpful!
                                  • bazB Offline
                                    baz
                                    Great tool, thanks Chris.
                                    baz
                                    • W Offline
                                      watkins
                                      Dear Chris,
                                      I made a request a little time ago for an icon to go with this script. I use your centrepoint finder so often that an icon would be very useful (and yes, TIG, I know I could assign a shortcut...)
                                      Many thanks,
                                      Bob
                                      • jamalitoJ Offline
                                        jamalito
                                        hello Chris thank for this Plugin but after I updated my SU8 to SU8m2 it was not work when I run in form plugin menu show to me this window I don't know what is meaning ?
                                        note I removed it and instal it again but same problem ๐Ÿ˜ข
                                        Albert Einstein:
                                        ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                                        • mitcorbM Offline
                                          mitcorb
                                          Hi, jamalito:
                                          It appears you have preselected a non exploded arc. Chris's plugin is for calculating a centerpoint of 2 or more unconnected or nonwelded segments. Use Sketchup's native Point at Center or Jim's Autocenterpoint.
                                            GM2013
                                            Had this very handy plugin installed previouslyu but I had to reintall Sketchup today.
                                            I tried installing via the Sketchucation plugin store but it didn't work so I manually placed it in the plugin folder and but doesn't appear in the plugins menu.
                                            Am I doing something wrong?
                                            • 3 / 3
