    [Plugin] HoverSelect - v1.5a - 07 Oct 17
    81 Posts 34 Posters 147.4k Views 34 Watching
    • fredo6F Offline
      fredo6
      @thomthom said:
      How do you actually draw filled shapes to the viewport?
      just use view.draw or view.draw2d with GL_POLYGON, GL_QUADS codes.
      Note that there is a bug in SU API for the 3D drawing (i.e. view.draw), which does not take into account the color set by view.drawing_color and always draws in black. I have signaled it to the SU team.
      Fredo
        Ah, I was struggling with that. And drawing a polygon over a face causes z-fighting. 😕 Which there was a nice way to highlight faces...
        • wind-borneW Offline
          wind-borne
          Just joined recently to enter the wild, wacky world of ruby. Ran across this thread and realized this might be something i would use regularly, but only a couple of the functions work, no hovering, rectangle or lasso selecting. Clicking an edge, very difficult; clicking a face does select edges easily.
          Your other tools I downloaded work fantastic.😄
          Thanks in advance if you can steer me in right direction. 😆
          "To read between the lines was easier than to follow the text."OSX 10.11.6
          %(#BF80BF)[SU 8 pro
          • fredo6F Offline
            fredo6
            The script is now translated to Chinese, thanks to the effort of the CLT Team at SketchupBar.
            see main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=18916&hilit=plugin#p155058
            • U Offline
              unclex
              Where put the LANG?
              • mitcorbM Offline
                mitcorb
                From what I can tell, this is a tool for edge selection only.
                I could sure use a Hoverselect Only Faces as a way to select faces exposed to the camera. Otherwise, you box select every thing in the box from here to the horizon, then you have to unselect the stuff on the other side of the mesh that you discover after orbiting the model.
                One good use for a Hoverselect face tool is to then apply Joint Push Pull to those selected faces.
                • mitcorbM Offline
                  mitcorb
                  So... this is not a good idea?
                  • fredo6F Offline
                    fredo6
                    It is...
                    I may end up doing it in my redesign of HoverSelect
                    Fredo
                      blakelywallace
                      Hey Fredo,
                      Any news on the addition of a lasso selection tool? Would be super handy...
                      Many thanks for all your hard work 😄
                      • H Offline
                        hebeijianke
                        When I use this tool "Selection by rectangle:"
                        If I select a line that is hiden
                        It does not work
                        • fredo6F Offline
                          fredo6
                          @hebeijianke said:
                          It does not work
                          By default, the rectangle selection selects only on visible edges (like the Eraser tool).
                          To include all edges, you have to use the Shift modifier (pressed or in toggle mode). The green rectangle border gets thicker and the hidden edges are highlighted.
                          Fredo
                          • H Offline
                            hebeijianke
                            I see 😄
                            • dereiD Offline
                              derei
                              Script doesn't work for me, I mean it doesn't select anything. I have the menu, i can "use" the selection tool, but it doesn't select any edge. Compatibility issue with SU8 maybe?
                              DESIGNER AND ARTIST DEREI.UK
                              • OxerO Offline
                                Oxer
                                Hi Fredo and thanks for the plugin!
                                I have translated the plugin to Spanish language this is the file:
                                HoverSelect Spanish Language
                                http://www.oxervision.blogspot.com/
                                  amuyobo
                                  Just started using Sketchup - this plugin is an absolute must! Thank You!
                                  • CarrozzaC Offline
                                    Carrozza
                                    I have pretty much the same problems as Dereeei (see above): when I activate the plugin and click-hover on edges nothing get selected.
                                    What's worst, in rare occasions it works, it seems mostly after having performed a rectangle select action.
                                    What works flawlessly is the click-on-face selection, but that's the less useful feature because for what I understand it pretty much replicate the native double-click Sketchup funcionality.
                                    Could someone please help me make this great plugin work?
                                    Cheers!
                                    • fredo6F Offline
                                      fredo6
                                      Just in case, did you check the edge property filter? By default, HoverSelect does not select Smooth edges (even if they appear as plain edges). But you can change the filter.
                                      Fredo
                                      • CarrozzaC Offline
                                        Carrozza
                                        I thing filters are correct (all four button pressed); I can say it because when I disable some type of edges there's a forbid sign near the cursor while overing excluded edge types.
                                        I made tests in a few different situations and models, but no luck so far.
                                        In case it matters here are all the plugins installed:
                                        Chris's Shape Bender.
                                        Didier's Projections.
                                        Diggory's Recurve.
                                        Fredo's Bezier Spline, Curviloft, Hover Select, Scale, Joint PushPull, Round Corner, Tools on surface.
                                        ThomThom's Cleanup.
                                        I have Sketchup 8 running on Windows 7 64 bit, graphics card is Nvidia GeForce GT 525M (mobile).
                                        Thanks for your great plugins and your help.
                                        • CarrozzaC Offline
                                          Carrozza
                                          Fredo, is there hope you'll look into this issue?
                                          Unfortunately selecting only edges without faces is a real pain in Sketchup...
                                          • fredo6F Offline
                                            fredo6
                                            I'll see what I can do quickly and come back
                                            Fredo
                                            • 3 / 5
