    [Plugin] HoverSelect - v1.5a - 07 Oct 17
    81 Posts 34 Posters 149.1k Views 34 Watching
    • fredo6F
      @mitcorb said:
      So... this is not a good idea?
      It is...
      I may end up doing it in my redesign of HoverSelect
      • B
        blakelywallace
        Hey Fredo,
        Any news on the addition of a lasso selection tool? Would be super handy...
        Many thanks for all your hard work πŸ˜„
        • H
          hebeijianke
          When I use this tool "Selection by rectangle:"
          If I select a line that is hiden
          It does not work
          • fredo6F
            @hebeijianke said:
            It does not work
            By default, the rectangle selection selects only on visible edges (like the Eraser tool).
            To include all edges, you have to use the Shift modifier (pressed or in toggle mode). The green rectangle border gets thicker and the hidden edges are highlighted.
            • H
              hebeijianke
              I see πŸ˜„
              • dereiD
                derei
                Script doesn't work for me, I mean it doesn't select anything. I have the menu, i can "use" the selection tool, but it doesn't select any edge. Compatibility issue with SU8 maybe?
                DESIGNER AND ARTIST DEREI.UK
                • OxerO
                  Oxer
                  Hi Fredo and thanks for the plugin!
                  I have translated the plugin to Spanish language this is the file:
                  HoverSelect Spanish Language
                    amuyobo
                    Just started using Sketchup - this plugin is an absolute must! Thank You!
                    • CarrozzaC
                      Carrozza
                      I have pretty much the same problems as Dereeei (see above): when I activate the plugin and click-hover on edges nothing get selected.
                      What's worst, in rare occasions it works, it seems mostly after having performed a rectangle select action.
                      What works flawlessly is the click-on-face selection, but that's the less useful feature because for what I understand it pretty much replicate the native double-click Sketchup funcionality.
                      Could someone please help me make this great plugin work?
                      Cheers!
                      • fredo6F
                        Just in case, did you check the edge property filter? By default, HoverSelect does not select Smooth edges (even if they appear as plain edges). But you can change the filter.
                        • CarrozzaC
                          Carrozza
                          I thing filters are correct (all four button pressed); I can say it because when I disable some type of edges there's a forbid sign near the cursor while overing excluded edge types.
                          I made tests in a few different situations and models, but no luck so far.
                          In case it matters here are all the plugins installed:
                          Chris's Shape Bender.
                          Didier's Projections.
                          Diggory's Recurve.
                          Fredo's Bezier Spline, Curviloft, Hover Select, Scale, Joint PushPull, Round Corner, Tools on surface.
                          ThomThom's Cleanup.
                          I have Sketchup 8 running on Windows 7 64 bit, graphics card is Nvidia GeForce GT 525M (mobile).
                          Thanks for your great plugins and your help.
                          • CarrozzaC
                            Carrozza
                            Fredo, is there hope you'll look into this issue?
                            Unfortunately selecting only edges without faces is a real pain in Sketchup...
                            • fredo6F
                              I'll see what I can do quickly and come back
                              • irwanwrI
                                irwanwr
                                i'll try to learn and use this one too. IA.
                                thank you Fredo
                                • SwissmountainS
                                  Swissmountain
                                  Hey Fredo, same problem over here on Mac OSX Snowleopard, Sketchup 8.0.11751 & LibFredo6 - v4.4m - 14 Apr 12
                                  I see the menu but can't select anything, there is no selection rectangle either.
                                  Thank you for everything you do
                                  Ciao
                                  Cogito ergo dum-di-dum
                                  • fredo6F
                                    Does this problem happen only with HoverSelect or all my plugins?
                                    If so, this may come from a conflict with some other plugins (like some versions of Podium and Matchbox)
                                    • SwissmountainS
                                      Swissmountain
                                      All your other plugins work like a charm on my machine Fredo, thank you for the update to the round corner and curviloft scripts earlier this year!
                                      The hoverselect sounds like an amazing tool for speeding up more organic modeling approaches which require selection and scaling of splines, I would love to make it a part of my toolbox.
                                      • fredo6F
                                        NEW RELEASE: HoverSelect v1.2a - 27 Nov 13
                                        HoverSelect 1.2a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                                        • fredo6F
                                          NEW RELEASE: HoverSelect v1.3a - 20 Oct 14
                                          HoverSelect 1.3a is required for the support of usernames with non-ascii characters in Sketchup 2014.
                                          • G
                                            greatoe
                                            Ciao
                                            This issue still remains. Mac OSX El Capitan 10.11, Sketchup 2015.
                                            • 3 / 5
