    [Plugin] HoverSelect - v1.5a - 07 Oct 17
    81 Posts 34 Posters 147.4k Views 34 Watching
      blakelywallace
      Hey Fredo,
      Any news on the addition of a lasso selection tool? Would be super handy...
      Many thanks for all your hard work πŸ˜„
      • H Offline
        hebeijianke
        When I use this tool "Selection by rectangle:"
        If I select a line that is hiden
        It does not work
        • fredo6F Offline
          @hebeijianke said:
          It does not work
          By default, the rectangle selection selects only on visible edges (like the Eraser tool).
          To include all edges, you have to use the Shift modifier (pressed or in toggle mode). The green rectangle border gets thicker and the hidden edges are highlighted.
          • H Offline
            hebeijianke
            I see πŸ˜„
            • dereiD Offline
              derei
              Script doesn't work for me, I mean it doesn't select anything. I have the menu, i can "use" the selection tool, but it doesn't select any edge. Compatibility issue with SU8 maybe?
              DESIGNER AND ARTIST DEREI.UK
              • OxerO Offline
                Oxer
                Hi Fredo and thanks for the plugin!
                I have translated the plugin to Spanish language this is the file:
                HoverSelect Spanish Language
                  amuyobo
                  Just started using Sketchup - this plugin is an absolute must! Thank You!
                  • CarrozzaC Offline
                    Carrozza
                    I have pretty much the same problems as Dereeei (see above): when I activate the plugin and click-hover on edges nothing get selected.
                    What's worst, in rare occasions it works, it seems mostly after having performed a rectangle select action.
                    What works flawlessly is the click-on-face selection, but that's the less useful feature because for what I understand it pretty much replicate the native double-click Sketchup funcionality.
                    Could someone please help me make this great plugin work?
                    Cheers!
                    • fredo6F Offline
                      Just in case, did you check the edge property filter? By default, HoverSelect does not select Smooth edges (even if they appear as plain edges). But you can change the filter.
                      • CarrozzaC Offline
                        Carrozza
                        I thing filters are correct (all four button pressed); I can say it because when I disable some type of edges there's a forbid sign near the cursor while overing excluded edge types.
                        I made tests in a few different situations and models, but no luck so far.
                        In case it matters here are all the plugins installed:
                        Chris's Shape Bender.
                        Didier's Projections.
                        Diggory's Recurve.
                        Fredo's Bezier Spline, Curviloft, Hover Select, Scale, Joint PushPull, Round Corner, Tools on surface.
                        ThomThom's Cleanup.
                        I have Sketchup 8 running on Windows 7 64 bit, graphics card is Nvidia GeForce GT 525M (mobile).
                        Thanks for your great plugins and your help.
                        • CarrozzaC Offline
                          Carrozza
                          Fredo, is there hope you'll look into this issue?
                          Unfortunately selecting only edges without faces is a real pain in Sketchup...
                          • fredo6F Offline
                            I'll see what I can do quickly and come back
                            • irwanwrI Offline
                              irwanwr
                              i'll try to learn and use this one too. IA.
                              thank you Fredo
                              • SwissmountainS Offline
                                Swissmountain
                                Hey Fredo, same problem over here on Mac OSX Snowleopard, Sketchup 8.0.11751 & LibFredo6 - v4.4m - 14 Apr 12
                                I see the menu but can't select anything, there is no selection rectangle either.
                                Thank you for everything you do
                                Ciao
                                Cogito ergo dum-di-dum
                                • fredo6F Offline
                                  Does this problem happen only with HoverSelect or all my plugins?
                                  If so, this may come from a conflict with some other plugins (like some versions of Podium and Matchbox)
                                    Swissmountain
                                    All your other plugins work like a charm on my machine Fredo, thank you for the update to the round corner and curviloft scripts earlier this year!
                                    The hoverselect sounds like an amazing tool for speeding up more organic modeling approaches which require selection and scaling of splines, I would love to make it a part of my toolbox.
                                    • fredo6F Offline
                                      NEW RELEASE: HoverSelect v1.2a - 27 Nov 13
                                      HoverSelect 1.2a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                                      • fredo6F Offline
                                        NEW RELEASE: HoverSelect v1.3a - 20 Oct 14
                                        HoverSelect 1.3a is required for the support of usernames with non-ascii characters in Sketchup 2014.
                                          greatoe
                                          Ciao
                                          This issue still remains. Mac OSX El Capitan 10.11, Sketchup 2015.
                                          • fredo6F Offline
                                            Could you open the Ruby Console to chcek if there is an error message displayed.
                                            • 3 / 5
