    DC's - Repeating a hole - is it possible ???
    15 Posts 9 Posters 8.0k Views 9 Watching
    • H Offline
      Howard leslie
      With Dynamic Components, does anybody know how to, or if its possible to repeat a hole ???
      See attached for a quick explanation of the task (its not a DC at the moment).
      Any thoughts / ideas most welcome.
      Regards
      Howard L'
      repeating_holes.skp
        Jim
        It may be possible, but it won't be easy.
        To start, each hole would need to consist of 2 half-hole components (one on each side) because a component can only cut through one face.
        I can't even wrap my brain around it before my coffee... but for whatever reason, the hole copies do not cut the face...
        repeating_holes[a].skp
        • H Offline
          Howard leslie
          Jim,
          Thanks very much for your reply.
          Yes, its a very tricky problem
          The main problem is trying to create something that doesn't exist - a hole !!!
          A Possible Workaround
          I'm thinking along the lines now of creating the holes as solid cylinders on a layer that can be turned off eg called "Hide" and the main body as a solid rectangle (as before). (Not REALLY solids obviously but you get the idea).
          That way you can repeat the holes (cylinders). (Cylinder = Potential Hole if you like).
          Once the components length has been defined and cylinders automatically repeated, edit component by selecting all cylinders.
          Then use Bool Tools (Thank you Dale) or manually cut out the Holes
          Long Term - possibly add a behaviour to DCs for Holes ??? Is this possible ???
          Just some thoughts anyway
          Thanks once again
          Howard L'
          • P Offline
            prismcnd
            I'm running into the same problem trying to recreate a dynamic component of a steel stud that places holes as the stud gets longer in the correct spots for the carrying channel
            “Whatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
            • Chris FullmerC Offline
              IT doesn't work to just create a component with a hole in it that repeats? I would swear that I've done this, but I guess not.
              Chris
              All my Plugins I've written
                remus
                prismcnd, from the sounds of it you could solve your problem by having one piece of channel with a hole in it and then have filler sections in between that change length with the overall length of the component. Its not going to be much fun to do the positioning, but it should work.
                  lucifer1101
                  what i would suggest you do is make a couple of models starting with 1 hole then moving up to maximum holes and just have it as an option and use hide model stuff...
                  that would probably be easyier....
                  Some of my 3d
                    Jim
                    Chris
                    Please try it also - maybe I've done it wrong.
                      Oh, I was looking at it as a single component. Not a series of holes. I thought the board with holes in it was the component. But is it really just supposed to be a hole that can be applied to any surface?
                      Chris
                        Here is my DC and it works. But I tihnk it is not what you were intending.
                        Chris
                        hole.skp
                        • H Offline
                          Howard leslie
                          Chris,
                          Your DC is really cunning and certainly works - but it is still a workaround.
                          However, I'm not sure if there is any other way (at present) in SketchUp to reproduce holes / cut outs using Dynamic Components without some sort of workaround.
                          For anybody who hasn't downloaded the *.skp, Chris's method boxes the holes off into their own square compartments and then copies these compartments.
                          One disadvantage with this method is that on export (eg to Autocad), the square compartments will be revealed (ie the linework of the individual boxes) and the method is a bit fiddly as there is quite a lot of geometry - top, bottom, sides, individual boxes, hidden elements etc - even for a simple example as we have here. However, you can adjust the DC if you want to change the size of the component by entering a value in the dialog box.
                          As explained above I was thinking along the lines of having the DC copy cylinders (cylinders = holes). Again its a workaround - so not ideal.
                          The geometry would be much cleaner and simpler - just a rectangle and cylinders. However, you'd then have to punch out the holes or delete the circular faces afterwards manually (or you could use Bool Tools here to help). Also, it would be a one way trip. Once the cylinders were used to cut the rectangular block you wouldn't be able to resize / edit the DC as the cylinders are now gone.
                          Could SU in the future have a special geometry class that is a cookie cutter / drill ???
                          ie you would define a cylinder, square, star shape / any shape - which could then be used to perform cut-outs from other geometry ???
                          Maybe a tough nut to crack for the Google SU Team ???
                          Keep fingers crossed for future versions.
                          Chris, thanks once again for your thoughts / ideas on this
                          Regards
                          Howard L'
                          • P Offline
                            Phil Rader AIA
                            Rick at Smusterd might know of a way I think his Windowizer does some repeating and cutting but it's not a dynamic component.
                            http://www.philrader.com
                            • P Offline
                              prismcnd
                              i second the notion of using a shape hidden in the sketchup file as the template for those cutouts, as not all cutouts would be cylindrical in fashion
                                Maybe this can help you 😉
                                you have Opener By Didier Bur who pierce any "surfaces" to the "next" one!
                                So repeat your "surfaces" by any methods
                                Select all them and in one click ou have all your holes 😉
                                Edit : sorry I have not seen that was about Dynamic components 😒
                                http://forums.sketchucation.com/download/file.php?id=28002
                                • K Offline
                                  kharstin
                                  The component cylinder idea works. Thanks so much for figuring this out. I have this problem a lot.
                                  Best,
                                  Ken Harstine
                                  @howard leslie said:
                                  Jim,
                                  Thanks once again
                                  Howard L'
