    DC's - Repeating a hole - is it possible ???
    Scheduled Pinned Locked Moved Dynamic Components
    15 Posts 9 Posters 8.1k Views 9 Watching
    • H Offline
      Howard leslie
      Jim,
      Thanks very much for your reply.
      Yes, its a very tricky problem
      The main problem is trying to create something that doesn't exist - a hole !!!
      A Possible Workaround
      I'm thinking along the lines now of creating the holes as solid cylinders on a layer that can be turned off eg called "Hide" and the main body as a solid rectangle (as before). (Not REALLY solids obviously but you get the idea).
      That way you can repeat the holes (cylinders). (Cylinder = Potential Hole if you like).
      Once the components length has been defined and cylinders automatically repeated, edit component by selecting all cylinders.
      Then use Bool Tools (Thank you Dale) or manually cut out the Holes
      Long Term - possibly add a behaviour to DCs for Holes ??? Is this possible ???
      Just some thoughts anyway
      Thanks once again
      Howard L'
        prismcnd
        I'm running into the same problem trying to recreate a dynamic component of a steel stud that places holes as the stud gets longer in the correct spots for the carrying channel
        “Whatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
        • Chris FullmerC Offline
          IT doesn't work to just create a component with a hole in it that repeats? I would swear that I've done this, but I guess not.
            remus
            prismcnd, from the sounds of it you could solve your problem by having one piece of channel with a hole in it and then have filler sections in between that change length with the overall length of the component. Its not going to be much fun to do the positioning, but it should work.
              lucifer1101
              what i would suggest you do is make a couple of models starting with 1 hole then moving up to maximum holes and just have it as an option and use hide model stuff...
              that would probably be easyier....
              Some of my 3d
                Jim
                Please try it also - maybe I've done it wrong.
                  Oh, I was looking at it as a single component. Not a series of holes. I thought the board with holes in it was the component. But is it really just supposed to be a hole that can be applied to any surface?
                    Here is my DC and it works. But I tihnk it is not what you were intending.
                    hole.skp
                    • H Offline
                      Howard leslie
                      Chris,
                      Your DC is really cunning and certainly works - but it is still a workaround.
                      However, I'm not sure if there is any other way (at present) in SketchUp to reproduce holes / cut outs using Dynamic Components without some sort of workaround.
                      For anybody who hasn't downloaded the *.skp, Chris's method boxes the holes off into their own square compartments and then copies these compartments.
                      One disadvantage with this method is that on export (eg to Autocad), the square compartments will be revealed (ie the linework of the individual boxes) and the method is a bit fiddly as there is quite a lot of geometry - top, bottom, sides, individual boxes, hidden elements etc - even for a simple example as we have here. However, you can adjust the DC if you want to change the size of the component by entering a value in the dialog box.
                      As explained above I was thinking along the lines of having the DC copy cylinders (cylinders = holes). Again its a workaround - so not ideal.
                      The geometry would be much cleaner and simpler - just a rectangle and cylinders. However, you'd then have to punch out the holes or delete the circular faces afterwards manually (or you could use Bool Tools here to help). Also, it would be a one way trip. Once the cylinders were used to cut the rectangular block you wouldn't be able to resize / edit the DC as the cylinders are now gone.
                      Could SU in the future have a special geometry class that is a cookie cutter / drill ???
                      ie you would define a cylinder, square, star shape / any shape - which could then be used to perform cut-outs from other geometry ???
                      Maybe a tough nut to crack for the Google SU Team ???
                      Keep fingers crossed for future versions.
                      Chris, thanks once again for your thoughts / ideas on this
                      Regards
                      Howard L'
                        Phil Rader AIA
                        Rick at Smusterd might know of a way I think his Windowizer does some repeating and cutting but it's not a dynamic component.
                        http://www.philrader.com
                          prismcnd
                          i second the notion of using a shape hidden in the sketchup file as the template for those cutouts, as not all cutouts would be cylindrical in fashion
                            Maybe this can help you 😉
                            you have Opener By Didier Bur who pierce any "surfaces" to the "next" one!
                            So repeat your "surfaces" by any methods
                            Select all them and in one click ou have all your holes 😉
                            Edit : sorry I have not seen that was about Dynamic components 😒
                            http://forums.sketchucation.com/download/file.php?id=28002
                              kharstin
                              The component cylinder idea works. Thanks so much for figuring this out. I have this problem a lot.
                              Best,
                              Ken Harstine
                              @howard leslie said:
                              Jim,
                              Thanks once again
                              Howard L'
