    Joint push pull making SU splat
    8 Posts 3 Posters 716 Views 3 Watching
      Rudbeckia
      why does this keep happening, any ideas?
        Rudbeckia
        okay its happeing 100% of the time now, what up with that???
        • Chris FullmerC Offline
          Could you upload a model that it is going it on? Also, if its ok, I'll move this to the ruby forum where it will probably get better attention.
          Chris
          All my Plugins I've written
            Rudbeckia
            Chris
            okay, yes will upload, sorry in wrong forum i feel like forever a newbie
            it called the end (last project of semester πŸ˜„
            i am useing from countours to create each contour that i cant connect, then I want to push pull to connect, i do not want a smooth topo map thats why i did not use "from contours" on the whole thing
            so i select the faces that i cant use normal push pull, select joint push pull, and i need to just move them like 2' or so and its splats every time
            theend.skp
            • jeff hammondJ Offline
              jeff hammond
              yikes! πŸ˜„
              i think you'd be better of by getting rid of all the hidden/softened lines and doing a normal push/pull.. probably the easiest way to go about it would be to select only the perimeter of the individual pieces (double click then single click the face)..
              copy/move it up to the right height and make a new face on it.. delete the one below then use regular push/pull to get the bottom back where you'd like..
              fwiw, jpp didn't splat on my system but it did struggle.
              [EDIT].. 😳 that's definitely the harder way.. just select the faces that won't push/pull and delete them.. connect two vertexes on the perimeter and it will fill back in (these shapes are flat.. no need to have a gazillion faces when one will do fine)
              dotdotdot
                Rudbeckia
                yikes! πŸ˜„
                okay you are right, MUCH easier, no need for joint push pull
                thanks!!!
                just curious though if i need to use it again, it is normal to make the program crash alot
                  jeff hammond
                  it seems pretty stable to me on my computer.. it didn't crash when i used it on the file you posted (and what's happening when JPPing one of those elevations is basically like trying to push/pull 500 separate faces at once)..
                  i use it with confidence but anytime i'm about to save myself 20+ minutes worth of manual drawing by doing it in one click via a ruby, i'll make sure to save the file first.
                  dotdotdot
                    Rudbeckia
                    thanks for the info!!
