    Sketchup registry key ?
    27 Posts 11 Posters 15.7k Views 11 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      I have to build an automatic installer (setup) for a plugin and was searching for the registry key of the install folder of Google Sketchup.
      I've browsed the registry with regedit but found nothing. 😞
      Anyone knows where it is (if it exists) ?
      Scott, you should know that ! πŸ’­
      Thanks in advance,
      DB
        Sketchup before version 7 didn't have such a registry key.
        But the SU7 key can be found in HKLM\Software\Google\Google Sketchup 7\InstallLocation
          On my Windows7 64bit it's HKLM\Software\**Wow6432Node**\Google\Google Sketchup 7\InstallLocation
            However, for SU6, you might be able to detect the installation path by checking the registry for the .skp file association.
            • scottliningerS Offline
              scottlininger
              Hey Didier,
              I don't know the answer to that off the top of my head. Let me know if you have any trouble with Thom's answer and I'll ask the experts (not me!) πŸ˜‰
              This would be a good addition to the FAQ section of the documentation site. I'll add a note to get this done...
              Cheers,
              • Scott Lininger
                SketchUp Software Engineer
                Have you visited the Ruby API Docs?
                Didier Bur
                Thanks all,
                OK for SU7, but my installer must work for SU6 as well.
                The key for skp file association doesn't give any info on where the soft is installed.
                And the key
                HKEY_LOCAL_MACHINE\SOFTWARE\Google\Google SketchUp 6\6.4.112
                has an 'undefined value'.
                I've checkeed other softs (Google Earth, Google Updater, Google Desktop...) and they all have a key named "installdir".
                Please Scott, would you like to ask the experts, please ? πŸŽ‰
                DB
                  scottlininger
                  From Steve P., our installer expert:
                  For SU6:
                  HKEY_LOCAL_MACHINE\SOFTWARE \Microsoft\Windows
                  CurrentVersion\Uninstall{98736A65-3C79-49EC-B7E9-A3C77774B0E6}\InstallLocation
                  For SU7:
                  HKEY_LOCAL_MACHINE\SOFTWARE\Google\Google SketchUp 7\InstallLocation
                  Cheers,
                  • Scott Lininger
                    Didier Bur
                    1000 thanks
                    DB
                      Matt666
                      I confirm I have this key for SU6 on my computer.
                      Frenglish at its best !
                      My scripts
                      • F Offline
                        fizgig
                        Does anyone have any tips for making a ruby script installer for windows? I need to be able to copy a directory to the c:\ and then copy a loader script into the plugins folder.
                          There are lots of free apps out there to do this for you...
                          • F Offline
                            fizgig
                            Not sure why my first pass at searching here came up dry. Must have misspelled something. Anyhow, this post seems very interesting: http://forums.sketchucation.com/viewtopic.php?f=180&t=11338&p=78374&hilit=+installer#p78374
                              tomasz
                              Does anyone know how recognize which SU version is installed on MAC?
                              I want to find out a folder where install a plugin to.
                              • Chris FullmerC Offline
                                Which do you want? The SU version number or the path to the plugins folder?
                                All my Plugins I've written
                                  tomasz
                                  I want to build a dmg installer and want to figure out what versions of SU are installed on a system.
                                  So essentially I want both, please. πŸ˜„
                                  • Dan RathbunD Offline
                                    Dan Rathbun
                                    @fizgig said:
                                    Does anyone have any tips for making a ruby script installer for windows? I need to be able to *copy a directory to the c:* and then copy a loader script into the plugins folder.
                                    Fiz, 99% of users HATE (and don't want,) software installed in the root directory of our boot drives!
                                    Plugins should be usually be installed in a subfolder of Plugins. (If it's a stanalone plugin that adds some functionality to Sketchup, such as a tool or report generator.)
                                    IF it's an 'behind the scenes' enhancement used by MANY plugins, (which would not appear on a menu,) it might go in a subfolder of another Sketchup folder such as Tools (in order to prevent menu building scripts from putting it on a menu.) BUT in this case, you should ask the user to confirm or specify a different folder (as some users also HATE non-Google scripts down in the Tools folder heirarchy.)
                                    I'm not here much anymore.
                                      Ditto that - don't want things installed in my πŸ˜„ root.
                                        tomasz
                                        Will checking whether a folder "/Library/Application Support/Google SketchUp 6 (or 7)/SketchUp" exists be enough?
                                          I don't tihnk so. I think they can change their installation path.
                                          There is a registry type setting that gets put in place for them that keeps track of where they installed their SU. You mgiht need to get Google involved since no one else seems to have this info off the top of their head. Butyou should just be able to check their plist or registry or whatever it is called for the SU directories, and install into whichever you want.
                                          Chris
                                            The version is obtained using:
                                            Sketchup.version
                                            Gets the current version of Sketchup in decimal form.
                                            Returns:
                                            the decimal form of the version
                                            OR
                                            Sketchup.version_number
                                            Get the current version of Sketchup as a whole number for comparisons.
                                            The Plugins path is obtained using:
                                            Sketchup.find_support_file
                                            The find_support_files method is used to retrieve the relative path and name of a file within the SketchUp installation directory.
                                            Forward slashes must be used to delimit between directory names.
                                            Arguments:
                                            filename
                                            Name of the filename you want to find.
                                            directory
                                            (optional) directory relative to the SketchUp installation directory.
                                            Returns:
                                            path
                                            Example:
                                            the entire path if successful. If unsuccessful, the method returns false.
                                            help_file=Sketchup.find_support_file("help.html","Plugins/")
                                            OR
                                            Sketchup.find_support_files
                                            The find_support_files method is used to retrieve the relative path and name of all matching files within the SketchUp installation directory.
                                            Arguments:
                                            filename
                                            directory
                                            Returns:
                                            array
                                            an array of files. If unsuccessful, the method returns false.
                                            Example
                                            array=Sketchup.find_support_files("filename","directory")
                                            What's making this so complicated ???
                                            • 1 / 2
