    Sketchup registry key ?
    27 Posts 11 Posters 16.3k Views 11 Watching
    • Didier BurD
      Didier Bur
      Thanks all,
      OK for SU7, but my installer must work for SU6 as well.
      The key for skp file association doesn't give any info on where the soft is installed.
      And the key
      HKEY_LOCAL_MACHINE\SOFTWARE\Google\Google SketchUp 6\6.4.112
      has an 'undefined value'.
      I've checkeed other softs (Google Earth, Google Updater, Google Desktop...) and they all have a key named "installdir".
      Please Scott, would you like to ask the experts, please ? πŸŽ‰
      DB
      • scottliningerS
        scottlininger
        From Steve P., our installer expert:
        For SU6:
        HKEY_LOCAL_MACHINE\SOFTWARE \Microsoft\Windows
        CurrentVersion\Uninstall{98736A65-3C79-49EC-B7E9-A3C77774B0E6}\InstallLocation
        For SU7:
        HKEY_LOCAL_MACHINE\SOFTWARE\Google\Google SketchUp 7\InstallLocation
        Cheers,
        • Scott Lininger
          SketchUp Software Engineer
          Have you visited the Ruby API Docs?
        • Didier BurD
          Didier Bur
          1000 thanks
          DB
            Matt666
            I confirm I have this key for SU6 on my computer.
            Frenglish at its best !
            My scripts
            • F
              fizgig
              Does anyone have any tips for making a ruby script installer for windows? I need to be able to copy a directory to the c:\ and then copy a loader script into the plugins folder.
                There are lots of free apps out there to do this for you...
                • F
                  fizgig
                  Not sure why my first pass at searching here came up dry. Must have misspelled something. Anyhow, this post seems very interesting: http://forums.sketchucation.com/viewtopic.php?f=180&t=11338&p=78374&hilit=+installer#p78374
                  • T
                    tomasz
                    Does anyone know how recognize which SU version is installed on MAC?
                    I want to find out a folder where install a plugin to.
                    • Chris FullmerC
                      Which do you want? The SU version number or the path to the plugins folder?
                      • T
                        tomasz
                        I want to build a dmg installer and want to figure out what versions of SU are installed on a system.
                        So essentially I want both, please. πŸ˜„
                        • Dan RathbunD
                          Dan Rathbun
                          @fizgig said:
                          Does anyone have any tips for making a ruby script installer for windows? I need to be able to *copy a directory to the c:* and then copy a loader script into the plugins folder.
                          Fiz, 99% of users HATE (and don't want,) software installed in the root directory of our boot drives!
                          Plugins should be usually be installed in a subfolder of Plugins. (If it's a stanalone plugin that adds some functionality to Sketchup, such as a tool or report generator.)
                          IF it's an 'behind the scenes' enhancement used by MANY plugins, (which would not appear on a menu,) it might go in a subfolder of another Sketchup folder such as Tools (in order to prevent menu building scripts from putting it on a menu.) BUT in this case, you should ask the user to confirm or specify a different folder (as some users also HATE non-Google scripts down in the Tools folder heirarchy.)
                          I'm not here much anymore.
                            Ditto that - don't want things installed in my πŸ˜„ root.
                            • T
                              tomasz
                              Will checking whether a folder "/Library/Application Support/Google SketchUp 6 (or 7)/SketchUp" exists be enough?
                              • Chris FullmerC
                                I don't tihnk so. I think they can change their installation path.
                                There is a registry type setting that gets put in place for them that keeps track of where they installed their SU. You mgiht need to get Google involved since no one else seems to have this info off the top of their head. Butyou should just be able to check their plist or registry or whatever it is called for the SU directories, and install into whichever you want.
                                  The version is obtained using:
                                  Sketchup.version
                                  Gets the current version of Sketchup in decimal form.
                                  Returns:
                                  the decimal form of the version
                                  OR
                                  Sketchup.version_number
                                  Get the current version of Sketchup as a whole number for comparisons.
                                  The Plugins path is obtained using:
                                  Sketchup.find_support_file
                                  The find_support_files method is used to retrieve the relative path and name of a file within the SketchUp installation directory.
                                  Forward slashes must be used to delimit between directory names.
                                  Arguments:
                                  filename
                                  Name of the filename you want to find.
                                  directory
                                  (optional) directory relative to the SketchUp installation directory.
                                  Returns:
                                  path
                                  Example:
                                  the entire path if successful. If unsuccessful, the method returns false.
                                  help_file=Sketchup.find_support_file("help.html","Plugins/")
                                  OR
                                  Sketchup.find_support_files
                                  The find_support_files method is used to retrieve the relative path and name of all matching files within the SketchUp installation directory.
                                  Arguments:
                                  filename
                                  directory
                                  Returns:
                                  array
                                  an array of files. If unsuccessful, the method returns false.
                                  Example
                                  array=Sketchup.find_support_files("filename","directory")
                                  What's making this so complicated ???
                                  • Chris FullmerC
                                    Its for an installer, not a ruby script I think.
                                      Aaahhh...
                                      πŸ˜•
                                      • F
                                        filcole
                                        I used WiX (http://wix.sourceforge.net) to create an MSI installer for Sketchup. It can detect the registry setting HKLM\Software\Google\Google Sketchup 7\InstallLocation and install the plugin in the plugins sub-folder.
                                        WiX is a pain in the arse to learn and use, but it's the only open source installer that creates MSIs that I could find.
                                          Jim
                                          What is a MSI, how it it different/better than what is made by Inno for example?
                                          Installing Ruby scripts in most cases is simply a matter of copying files to the correct location, and possibly registering an uninstaller. It has always been hard for me to justify creating a half-meg installer (or more) for a plug-in that is a few Kb. (Although a meg is not as big as it used to be.)
                                          Does there exist some sort of .zip installer?
                                          • T
                                            tomasz
                                            I have already created Win installer using NSIS. It reads SU installation locations from the registry. It has small overhead over compressed data size (34 KB with default options).
                                            Thanks TIG for such a comprehensive explanation, but I need it for an installer.
                                            I want to let a MAC user chose for which already installed SU version have my plugin added.
