    Sketchup registry key ?
    27 Posts 11 Posters 14.1k Views 11 Watching
      Sketchup before version 7 didn't have such a registry key.
      But the SU7 key can be found in HKLM\Software\Google\Google Sketchup 7\InstallLocation
        On my Windows7 64bit it's HKLM\Software\**Wow6432Node**\Google\Google Sketchup 7\InstallLocation
          However, for SU6, you might be able to detect the installation path by checking the registry for the .skp file association.
          • scottliningerS Offline
            scottlininger
            Hey Didier,
            I don't know the answer to that off the top of my head. Let me know if you have any trouble with Thom's answer and I'll ask the experts (not me!) πŸ˜‰
            This would be a good addition to the FAQ section of the documentation site. I'll add a note to get this done...
            Cheers,
            • Scott Lininger
              SketchUp Software Engineer
              Have you visited the Ruby API Docs?
            • Didier BurD Offline
              Didier Bur
              Thanks all,
              OK for SU7, but my installer must work for SU6 as well.
              The key for skp file association doesn't give any info on where the soft is installed.
              And the key
              HKEY_LOCAL_MACHINE\SOFTWARE\Google\Google SketchUp 6\6.4.112
              has an 'undefined value'.
              I've checkeed other softs (Google Earth, Google Updater, Google Desktop...) and they all have a key named "installdir".
              Please Scott, would you like to ask the experts, please ? πŸŽ‰
              DB
                scottlininger
                From Steve P., our installer expert:
                For SU6:
                HKEY_LOCAL_MACHINE\SOFTWARE \Microsoft\Windows
                CurrentVersion\Uninstall{98736A65-3C79-49EC-B7E9-A3C77774B0E6}\InstallLocation
                For SU7:
                HKEY_LOCAL_MACHINE\SOFTWARE\Google\Google SketchUp 7\InstallLocation
                Cheers,
                • Scott Lininger
                  Didier Bur
                  1000 thanks
                  DB
                    Matt666
                    I confirm I have this key for SU6 on my computer.
                    Frenglish at its best !
                    My scripts
                    • F Offline
                      fizgig
                      Does anyone have any tips for making a ruby script installer for windows? I need to be able to copy a directory to the c:\ and then copy a loader script into the plugins folder.
                        There are lots of free apps out there to do this for you...
                        • F Offline
                          fizgig
                          Not sure why my first pass at searching here came up dry. Must have misspelled something. Anyhow, this post seems very interesting: http://forums.sketchucation.com/viewtopic.php?f=180&t=11338&p=78374&hilit=+installer#p78374
                            tomasz
                            Does anyone know how recognize which SU version is installed on MAC?
                            I want to find out a folder where install a plugin to.
                            Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                            • Chris FullmerC Offline
                              Which do you want? The SU version number or the path to the plugins folder?
                                tomasz
                                I want to build a dmg installer and want to figure out what versions of SU are installed on a system.
                                So essentially I want both, please. πŸ˜„
                                • Dan RathbunD Offline
                                  Dan Rathbun
                                  @fizgig said:
                                  Does anyone have any tips for making a ruby script installer for windows? I need to be able to *copy a directory to the c:* and then copy a loader script into the plugins folder.
                                  Fiz, 99% of users HATE (and don't want,) software installed in the root directory of our boot drives!
                                  Plugins should be usually be installed in a subfolder of Plugins. (If it's a stanalone plugin that adds some functionality to Sketchup, such as a tool or report generator.)
                                  IF it's an 'behind the scenes' enhancement used by MANY plugins, (which would not appear on a menu,) it might go in a subfolder of another Sketchup folder such as Tools (in order to prevent menu building scripts from putting it on a menu.) BUT in this case, you should ask the user to confirm or specify a different folder (as some users also HATE non-Google scripts down in the Tools folder heirarchy.)
                                  I'm not here much anymore.
                                    Ditto that - don't want things installed in my πŸ˜„ root.
                                      tomasz
                                      Will checking whether a folder "/Library/Application Support/Google SketchUp 6 (or 7)/SketchUp" exists be enough?
                                        I don't tihnk so. I think they can change their installation path.
                                        There is a registry type setting that gets put in place for them that keeps track of where they installed their SU. You mgiht need to get Google involved since no one else seems to have this info off the top of their head. Butyou should just be able to check their plist or registry or whatever it is called for the SU directories, and install into whichever you want.
                                          The version is obtained using:
                                          Sketchup.version
                                          Gets the current version of Sketchup in decimal form.
                                          Returns:
                                          the decimal form of the version
                                          OR
                                          Sketchup.version_number
                                          Get the current version of Sketchup as a whole number for comparisons.
                                          The Plugins path is obtained using:
                                          Sketchup.find_support_file
                                          The find_support_files method is used to retrieve the relative path and name of a file within the SketchUp installation directory.
                                          Forward slashes must be used to delimit between directory names.
                                          Arguments:
                                          filename
                                          Name of the filename you want to find.
                                          directory
                                          (optional) directory relative to the SketchUp installation directory.
                                          Returns:
                                          path
                                          Example:
                                          the entire path if successful. If unsuccessful, the method returns false.
                                          help_file=Sketchup.find_support_file("help.html","Plugins/")
                                          OR
                                          Sketchup.find_support_files
                                          The find_support_files method is used to retrieve the relative path and name of all matching files within the SketchUp installation directory.
                                          Arguments:
                                          filename
                                          directory
                                          Returns:
                                          array
                                          an array of files. If unsuccessful, the method returns false.
                                          Example
                                          array=Sketchup.find_support_files("filename","directory")
                                          What's making this so complicated ???
                                            Its for an installer, not a ruby script I think.
