    Sketchup registry key ?
    27 Posts 11 Posters 15.7k Views 11 Watching
    • scottliningerS Offline
      scottlininger
      Hey Didier,
      I don't know the answer to that off the top of my head. Let me know if you have any trouble with Thom's answer and I'll ask the experts (not me!) πŸ˜‰
      This would be a good addition to the FAQ section of the documentation site. I'll add a note to get this done...
      Cheers,
      • Scott Lininger
        SketchUp Software Engineer
        Have you visited the Ruby API Docs?
      • Didier BurD Offline
        Didier Bur
        Thanks all,
        OK for SU7, but my installer must work for SU6 as well.
        The key for skp file association doesn't give any info on where the soft is installed.
        And the key
        HKEY_LOCAL_MACHINE\SOFTWARE\Google\Google SketchUp 6\6.4.112
        has an 'undefined value'.
        I've checkeed other softs (Google Earth, Google Updater, Google Desktop...) and they all have a key named "installdir".
        Please Scott, would you like to ask the experts, please ? πŸŽ‰
        DB
          scottlininger
          From Steve P., our installer expert:
          For SU6:
          HKEY_LOCAL_MACHINE\SOFTWARE \Microsoft\Windows
          CurrentVersion\Uninstall{98736A65-3C79-49EC-B7E9-A3C77774B0E6}\InstallLocation
          For SU7:
          HKEY_LOCAL_MACHINE\SOFTWARE\Google\Google SketchUp 7\InstallLocation
          Cheers,
          • Scott Lininger
            Didier Bur
            1000 thanks
            DB
              Matt666
              I confirm I have this key for SU6 on my computer.
              Frenglish at its best !
              My scripts
              • F Offline
                fizgig
                Does anyone have any tips for making a ruby script installer for windows? I need to be able to copy a directory to the c:\ and then copy a loader script into the plugins folder.
                  There are lots of free apps out there to do this for you...
                  • F Offline
                    fizgig
                    Not sure why my first pass at searching here came up dry. Must have misspelled something. Anyhow, this post seems very interesting: http://forums.sketchucation.com/viewtopic.php?f=180&t=11338&p=78374&hilit=+installer#p78374
                      tomasz
                      Does anyone know how recognize which SU version is installed on MAC?
                      I want to find out a folder where install a plugin to.
                      • Chris FullmerC Offline
                        Which do you want? The SU version number or the path to the plugins folder?
                          tomasz
                          I want to build a dmg installer and want to figure out what versions of SU are installed on a system.
                          So essentially I want both, please. πŸ˜„
                          • Dan RathbunD Offline
                            Dan Rathbun
                            @fizgig said:
                            Does anyone have any tips for making a ruby script installer for windows? I need to be able to *copy a directory to the c:* and then copy a loader script into the plugins folder.
                            Fiz, 99% of users HATE (and don't want,) software installed in the root directory of our boot drives!
                            Plugins should be usually be installed in a subfolder of Plugins. (If it's a stanalone plugin that adds some functionality to Sketchup, such as a tool or report generator.)
                            IF it's an 'behind the scenes' enhancement used by MANY plugins, (which would not appear on a menu,) it might go in a subfolder of another Sketchup folder such as Tools (in order to prevent menu building scripts from putting it on a menu.) BUT in this case, you should ask the user to confirm or specify a different folder (as some users also HATE non-Google scripts down in the Tools folder heirarchy.)
                            I'm not here much anymore.
                              Ditto that - don't want things installed in my πŸ˜„ root.
                                tomasz
                                Will checking whether a folder "/Library/Application Support/Google SketchUp 6 (or 7)/SketchUp" exists be enough?
                                  I don't tihnk so. I think they can change their installation path.
                                  There is a registry type setting that gets put in place for them that keeps track of where they installed their SU. You mgiht need to get Google involved since no one else seems to have this info off the top of their head. Butyou should just be able to check their plist or registry or whatever it is called for the SU directories, and install into whichever you want.
                                    The version is obtained using:
                                    Sketchup.version
                                    Gets the current version of Sketchup in decimal form.
                                    Returns:
                                    the decimal form of the version
                                    OR
                                    Sketchup.version_number
                                    Get the current version of Sketchup as a whole number for comparisons.
                                    The Plugins path is obtained using:
                                    Sketchup.find_support_file
                                    The find_support_files method is used to retrieve the relative path and name of a file within the SketchUp installation directory.
                                    Forward slashes must be used to delimit between directory names.
                                    Arguments:
                                    filename
                                    Name of the filename you want to find.
                                    directory
                                    (optional) directory relative to the SketchUp installation directory.
                                    Returns:
                                    path
                                    Example:
                                    the entire path if successful. If unsuccessful, the method returns false.
                                    help_file=Sketchup.find_support_file("help.html","Plugins/")
                                    OR
                                    Sketchup.find_support_files
                                    The find_support_files method is used to retrieve the relative path and name of all matching files within the SketchUp installation directory.
                                    Arguments:
                                    filename
                                    directory
                                    Returns:
                                    array
                                    an array of files. If unsuccessful, the method returns false.
                                    Example
                                    array=Sketchup.find_support_files("filename","directory")
                                    What's making this so complicated ???
                                      Its for an installer, not a ruby script I think.
                                        Aaahhh...
                                        πŸ˜•
                                        • F Offline
                                          filcole
                                          I used WiX (http://wix.sourceforge.net) to create an MSI installer for Sketchup. It can detect the registry setting HKLM\Software\Google\Google Sketchup 7\InstallLocation and install the plugin in the plugins sub-folder.
                                          WiX is a pain in the arse to learn and use, but it's the only open source installer that creates MSIs that I could find.
                                            Jim
                                            What is a MSI, how it it different/better than what is made by Inno for example?
                                            Installing Ruby scripts in most cases is simply a matter of copying files to the correct location, and possibly registering an uninstaller. It has always been hard for me to justify creating a half-meg installer (or more) for a plug-in that is a few Kb. (Although a meg is not as big as it used to be.)
                                            Does there exist some sort of .zip installer?
