    Gif Animation
    extensions
    19 Posts 10 Posters 3.4k Views 10 Watching
    • thomthomT
      Can anyone recommend free/cheap application which I can use to make a .gif SU animation?
      • ely862meE
        ely862me
        AVD Video Processor
        Elisei (sketchupper)
        Come and See EliseiDesign
        • ton baetenT
          ton baeten
          On my Mac I have GIFfun from STONEdesign (http://www.stone.com).
          Pretty nice piece of software, easy to work with, with nice results and.....it is free!!
          Just used it to make a 3D animated Gif based 100% on 38 SU scenes.
          I cann't show you the result (yet). My client doesn't allow me, because it is going to be used
          on the opening page of his new website which is still 'under contruction'.
          Maybe something for you too.
          greetings,
          Ton
          • thomthomT
            Hmm... my main system is PC. I do have a mac, but it's an old Mac Mini G4 (the second edition). Not sure if it's the best machine for the job... Will have to have a look.
            • EdsonE
              Edson
              if you have photoshop you already have one.
              http://www.mahfuz.arq.br
              • thomthomT
                Yea? It can compile an animation from a series of images?
                • jeff hammondJ
                  jeff hammond
                  i know you could do it with the older versions of PS (via image ready) but didn't they take that out?
                  dotdotdot
                  • thomthomT
                    Yea, that's what I was thinking. I have CS4, and I don't find any Image Ready.
                      A curiosity 😉
                      Microsoft Gif Animator 3.17 🤓
                      HL Gif Animator 3.17
                      HL Free Gif Animator is a tool for creating animations that can be put into websites in GIF format. It is especially useful for webmasters. The software has build-in library of ready made figures, scenes and textures]
                      • EdsonE
                        Edson
                        it is in the View menu. in case it is not there, choose a workspace in which it does.
                        and, if you enter "animation cs3 tutorial" in google you'll find several good ones.
                        • thomthomT
                          I find in Brodge that if I make the exported SU animation frames into a stack I get a play button which plays an animation from the frames. But I've not managed to get this into PS...
                          • S
                            sepo
                            You can also use Gimp..open source soft.
                            • thomthomT
                              GIMP also makes animated gifs? And it can compile the series of images from an SU animation?
                              • FrederikF
                                Frederik
                                Another great - and free - application capable of making animated gif's is Virtualdub... 😉
                                Cheers
                                Kim Frederik
                                • S
                                  sepo
                                  Yes it does. Check this
                                  http://www.instructables.com/id/How-to-create-gif-animations/
                                  • Chris FullmerC
                                    Here's how to do it in Photoshop CS3 (the first version without Image-ready, so therefore its all built into Photoshop).
                                    Basic instructions
                                    • Use File>Open to opent he first image in the animation, and check "Image Sequence".
                                    • To save it as an animted .gif file, you have to use File>Save for Web & Devices.
                                    Slightly more Detailed instructions
                                    • Export a series of animation images from SU. I prefer .png. Save them all to their own special folder.
                                    • In photoshop, go to File>Open. Select the first image and check the box for "Image Sequence".
                                    • It might ask what framerate to use. Enter the framerate that was exported from SU.
                                    • Open Window>Animations window. Now you should have a single layer with a little film clicp icon on it, and you should have the animation window open. You can click on the play button in the animation window to see your animation in action.
                                    • Now save the .gif file by going to File>Save for Web and Devices.
                                    • In this window, play with the color reduction algorithm, amount of colors used in the animation, transparency, interlaced.
                                    • Change looping from "Once" to "Forever".
                                    That about does it. I'm sure there's more complex stuff to do, but that should be the basics to get anyone started.
                                    Chris
                                    All my Plugins I've written
                                    • GaieusG
                                      And this is how Gimp would do it (two scenes to and fro).
                                      Thanks Sid (I didn't know that)
                                      • thomthomT
                                        That was the last piece of the puzzle! 😄 👍
                                        Thanks guys for the various solutions!
                                        • Chris FullmerC
                                          For me it was the "Save for Web & Devices" that stumped me at first. Because even once you get it imported, it seems all but impossible to save it as an animated .gif. It lets you export to any filetype, or regular save as a ./gif that is not animated, but the animated .gif type is ONLY available in the "save for web & devices" window. Maybe they fixed that silliness though for CS4, I have only done it in CS3.
                                          Glad its wokring now. I really keep meaning to look into GiMP too,
                                          Chris
