    Screen distorted_URGENT HELP!
    14 Posts 7 Posters 1.5k Views 7 Watching
    • H Offline
      h4zel
      HI all, urgently need help.
      im using window XP - sketchup pro 6. with irender lite
      PRoblem : whenever i used a commands the screen is distorted [refer pic] it only happen recently(2 week ago). i try some old drawing.. same thing happen. no matter wat commands it will be distorted. when no commands is applied everything is fine.
      need serious help >.<"
      distorted
      • boofredlayB Offline
        boofredlay
        Did you install a new mouse? I had this problem a while back and it was the software for the mouse. I uninstalled that software and just let XP run the mouse, problem fixed.
        Hope that helps.
        • H Offline
          h4zel
          i did had a new mouse.. but i did not install the mouse software[auto detect]
          any 1 can come out with the solution. i need to used it urgently 😞
          • soloS Offline
            solo
            What video card do you have, looks like you have a Nvidea card right?
            Go into your preferences and in your openGL settings turn off the AA and see how that works.
            http://www.solos-art.com
            • H Offline
              h4zel
              HI Solo , i try yur suggestion and off the open Gl accelerator
              The distorted stop.. but whenever i turn the view. the screen froze and
              everything is very very slow.
              Any other solution. with open Gl maintain. 😎
              grafic card : nvidia Gforce 8500 GT
                remus
                Did you try turning of anti aliasing or did you just turn of 'hardware acceleration'?
                If the latter, try the former.
                • H Offline
                  h4zel
                  hmm.. i try turn off hardware acceleration.. no distorted but it to jumpy to draw.
                  using OPen Gl hardware acceleration 16x True color Medium 0x anti-alias
                  problem still occur.. blur whenever i used a commands except Paint 😐
                  • soloS Offline
                    solo
                    Do you have updated drivers? as this looks exactly like the problem I had two years ago when they first launched the 8800 gtx card and I had to wait for months until updated drivers were available.
                    • H Offline
                      h4zel
                      Hmm. i downloading the driver now.. 112mb .>.<" will take awhile..
                      will keep update if it work.. thx again solos
                        Charlie__V
                        h4zel,
                        I had the same problem a number of months back.
                        The following soved the problem for me
                        Re: Nvidia GeForce 8700MGT
                        by CHARLIE__V on Sun Jan 11, 2009 9:12 am
                        Hello all,
                        Anyone running an Nvidia GeForce 8700MGT with hardware acceleration enabled ?
                        I searched and found that an older driver for the 8800 allows for HA, but no such driver for the 8700.
                        EDIT:
                        Well for those interested....looks like I may have solved/answered my own question.
                        Seems I had a combination of option settings selected that were causing me grief.
                        In the Nvidia control panel I needed to have the image setting set to
                        Let 3D app Decide
                        And in SU preferences....Open GL....Capabilities....use an option with
                        Anti Alias set to 0x
                        SLI Enabled/Disabled does not seem to make a difference.
                        Above settings are with Dell driver 176.78_Dec21_2008
                        TIA.....
                        best,
                        Charlie
                        Specs:
                        Dell
                        XPS M1730, Intel Core 2 Extreme X9000(2.8GHz, 800Mhz 6M L2 Cache)
                        NVIDIA SLI Dual GeForce 8700MGT with 512MB GDDR3
                        4GB, DDR2, 667MHz
                        320GB 7200RPM Hard Drive
                        OS: XP Pro SP3
                        • H Offline
                          h4zel
                          HI charlie, i will try out yur way.. hope it work..
                          recently been busy no time to try on it yet..
                          will let u know if it work πŸ˜›
                            dlomas
                            Try changing Styles/Edit/Face Settings/Transparency Quality ->faster.
                            Also turn off; Model Info/Rendering/Use Anti-Aliased Textures ->turn it off
                            • H Offline
                              h4zel
                              HI all,
                              Hey charlie. yur method work.after i set it. no problem so far good to go ^.^ thx for all the valuable comment every 1 πŸ‘
                              • P Offline
                                PRSS
                                Hi h4zel
                                Forceware version 169.21 should certainly work out for you. Google search for this and you'll get the download. I had this same problem with my 8600GT & 8800GT cards in my home & office computers respectively. The problem disappeared after I installed this older version of drivers (Windows XP).
                                Hope this helps.
                                With best regards
                                PRSS
