Screen distorted_URGENT HELP!
HI all, urgently need help.
im using window XP - sketchup pro 6. with irender lite
PRoblem : whenever i used a commands the screen is distorted [refer pic] it only happen recently(2 week ago). i try some old drawing.. same thing happen. no matter wat commands it will be distorted. when no commands is applied everything is fine.
need serious help >.<"
Did you install a new mouse? I had this problem a while back and it was the software for the mouse. I uninstalled that software and just let XP run the mouse, problem fixed.
Hope that helps.
i did had a new mouse.. but i did not install the mouse software[auto detect]
any 1 can come out with the solution. i need to used it urgently
What video card do you have, looks like you have a Nvidea card right?
Go into your preferences and in your openGL settings turn off the AA and see how that works.
HI Solo , i try yur suggestion and off the open Gl accelerator
The distorted stop.. but whenever i turn the view. the screen froze and
everything is very very slow.
Any other solution. with open Gl maintain.
grafic card : nvidia Gforce 8500 GT -
Did you try turning of anti aliasing or did you just turn of 'hardware acceleration'?
If the latter, try the former.
hmm.. i try turn off hardware acceleration.. no distorted but it to jumpy to draw.
using OPen Gl hardware acceleration 16x True color Medium 0x anti-alias
problem still occur.. blur whenever i used a commands except Paint
Do you have updated drivers? as this looks exactly like the problem I had two years ago when they first launched the 8800 gtx card and I had to wait for months until updated drivers were available.
Hmm. i downloading the driver now.. 112mb .>.<" will take awhile..
will keep update if it work.. thx again solos -
h4zel,
I had the same problem a number of months back.
The following soved the problem for meRe: Nvidia GeForce 8700MGT
by CHARLIE__V on Sun Jan 11, 2009 9:12 amHello all,
Anyone running an Nvidia GeForce 8700MGT with hardware acceleration enabled ?I searched and found that an older driver for the 8800 allows for HA, but no such driver for the 8700.
EDIT:
Well for those interested....looks like I may have solved/answered my own question.
Seems I had a combination of option settings selected that were causing me grief.In the Nvidia control panel I needed to have the image setting set to
Let 3D app DecideAnd in SU preferences....Open GL....Capabilities....use an option with
Anti Alias set to 0xSLI Enabled/Disabled does not seem to make a difference.
Above settings are with Dell driver 176.78_Dec21_2008
TIA.....
best,
CharlieSpecs:
Dell
XPS M1730, Intel Core 2 Extreme X9000(2.8GHz, 800Mhz 6M L2 Cache)
NVIDIA SLI Dual GeForce 8700MGT with 512MB GDDR3
4GB, DDR2, 667MHz
320GB 7200RPM Hard Drive
OS: XP Pro SP3 -
HI charlie, i will try out yur way.. hope it work..
recently been busy no time to try on it yet..
will let u know if it work
Try changing Styles/Edit/Face Settings/Transparency Quality ->faster.
Also turn off; Model Info/Rendering/Use Anti-Aliased Textures ->turn it off -
HI all,
Hey charlie. yur method work.after i set it. no problem so far good to go ^.^ thx for all the valuable comment every 1
Hi h4zel
Forceware version 169.21 should certainly work out for you. Google search for this and you'll get the download. I had this same problem with my 8600GT & 8800GT cards in my home & office computers respectively. The problem disappeared after I installed this older version of drivers (Windows XP).
Hope this helps.
With best regards
PRSS
